Vazduhoplovi
Re: Vazduhoplovi
Ovo mi nije jasno, ko ce putovati ali eto.
https://www.nezavisne.com/ekonomija/pri ... ran/540932
BRABUS
Postovi: 550
Re: Vazduhoplovi
Post od BRABUS »
Azilanti :D
Postovi: 49214
Re: Vazduhoplovi
Boeing finally admits safety flaws in implementing 737 MAX software
https://www.rt.com/news/460655-boeing-a ... lert-flaw/
Boeing chief Dennis Muilenburg said his company failed to properly implement a safety alert feature on its 737 MAX aircraft, grounded globally in wake of two deadly plane crashes.
“We clearly fell short … The implementation of that software, we did not do it correctly,” Muilenburg told CBS News Tuesday.
“Our engineers discovered that,” he said, adding that the company was working to resolve the issue.
Dennis Muilenburg says the company is learning from the accidents, and vows to make improvements.
The safety feature can notify pilots of problems early in a flight, and possibly could have prevented the crash of Ethiopian Airlines flight 302 in March, Chris Brady, the author of Boeing’s 737 Technical Guide, told the BBC.
“I'm fairly confident that the Ethiopian Airlines flight probably would not have crashed if they had had the AOA disagree alert,” Brady said, referring to the safety software.
The crash, which killed all 157 passengers, is now being investigated, but the prime suspect is the malfunction of the aircraft’s flight control system. A doomed Lion Air flight out of Indonesia, also a 737 MAX, is said to have experienced a similar problem last October before it crashed, killing the 189 people onboard.
Boeing said last month that the alert, which could have prompted pilots to follow a different emergency procedure, “has not been considered a safety feature on airplanes and is not necessary for the safe operation of the airplane.”
The US Federal Aviation Administration concluded in an internal investigation earlier this month that the agency failed to properly oversee Boeing’s safety tests for the 737 MAX, deferring to the company’s own experts and allowing the defective systems through the agency’s approval process.
Postovi: 7784
Re: Vazduhoplovi
Pre neki dan taksiramo po Beogradsko aerodromu i gledam pistu i oznake. Sve je izbekelo, ništa se više ne vidi. Nekako nisam sedeo do prozora prošlih par puta. Stvarno se ofucao ozbiljno, ili nesto rade :)
Verstuurd vanaf mijn H3113 met Tapatalk
Postovi: 21110
Re: Vazduhoplovi
Trebalo bi da se radi nešto.
blaugrana
Postovi: 7477
Re: Vazduhoplovi
Post od blaugrana »
Bojim se da ne rade, jer sam isto tako doziveo kao Ljuba pre 4 meseca.
Re: Vazduhoplovi
https://samchui.com/2019/06/01/venezola ... POGKbdU5kw
VENEZOLANA BOEING 737 SUFFERS UNCONTAINED ENGINE FAILURE
snork
Postovi: 4967
Re: Vazduhoplovi
Post od snork »
Zamor materijala. Verovatno su se raspale lopatice fena, kompresora, ili turbine. Ipak se vrte od 1978. godine, ako motor nije menjan (ne verujem baš da u zemlji pod sankcijama vode računa o isteku resursa).
Mada, P&W JT8D motore mogu kupiti bukvalno svuda. Išao je i u DC-9 (dva komada) i u B727 (tri komada). Mislim da je JAT svojevremeno uz ove avione prodao i nekoliko novih rezervnih motora.
Re: Vazduhoplovi
Dobre info hvala :pivo:
U 7:45 mi poletao avion, ja ušao na parking sat vremena pre leta. WizzAir bukvalno pola sata pre leta možeš da dodješ ako imaš ručni prtljag.
Re: Vazduhoplovi
Standardno lom kod mene :)
BRABUS
Postovi: 550
Re: Vazduhoplovi
Post od BRABUS »
Boeing warns of potential wing faults in some 737 jets
https://www.bbc.com/news/business-48503610
klisko
Postovi: 666
Re: Vazduhoplovi
Post od klisko »
passenger napisao:Standardno lom kod mene :)
Opasno sam se iznervirao pre par dana. Karta košta preko 500 evra, a onda 80% aviona dobije buđavi sendvič, a četiri, pet redova preskoče. Nije mi do sendviča, ali bezobrazluk mi smeta, kakav god da je. Vajni švajcarci.
Edit: odnosi se na swiss air, ništa na račun passengera
Re: Vazduhoplovi
ciganisanja uvek bilo :)
ovo je moje standardno uzimanje na letu, 6.5 eura i 1.5-2 eura bakšiš:
sendvič (ćuretina, šunka ili kačkavalj za vegiz)
sok (7up, pepsi, schweppes, a pola eura više za red bull)
i ''gratis'' uz ovo gore kupljeno čokoladica (snickers, kit kat, valjda twix i još par ima).
Postovi: 25121
Re: Vazduhoplovi
Danas propelerac.
Re: Vazduhoplovi
A gde? Kako bih voleo :)
Zuzu, umeš da teraš ti ove elise?
