Fotografija
Re: Koji foto-aparat koristite?
Ne.
Vec sam dao definicije klasa aparata. Ne bih da se ponavljam, ali ajde:
http://en.wikipedia.org/wiki/Point-and-shoot_camera
A point-and-shoot camera, also called a compact camera, is a still camera designed primarily for simple operation
http://en.wikipedia.org/wiki/Prosumer
For example, a prosumer grade digital camera is a "cross" between consumer grade and professional grade.
Ili:
"The size and form of the Prosumer camera is smaller than a Digital SLR camera. Prosumer camera is light and equipped with a super zoom lens. "
"Prosumer camera is a combination / cross between a DSLR cameras (often referred to as the camera "PRO / professional") with a pocket camera (the camera is often called "consumer")."
Ovakve aparate niko ne naziva kompaktima niti to jesu. Velicina senzora je nebitna jer imas APS-C senzor u kompakt telu - sta je to? Kompakt ili?
Naprimer definisite ovo:
http://www.dpreview.com/reviews/sonydscr1/
(po nidzi do je kompakt). PAZLJIVO pogledajte specifikacije.
DSLR:
http://en.wikipedia.org/wiki/Digital_si ... lex_camera
A digital single-lens reflex camera (also called a digital SLR or DSLR) is a digital camera combining the optics and the mechanisms of a single-lens reflex camera with a digital imaging sensor, as opposed to photographic film.
Mirrorless:
http://en.wikipedia.org/wiki/Mirrorless ... ens_camera
The mirrorless interchangeable-lens camera (MILC) is a class of digital system cameras. This type of cameras provide interchangeable lens mount. They do not have a mirror reflex optical viewfinder.
Micro 4/3:
http://en.wikipedia.org/wiki/Micro_Four_Thirds_system
The Micro Four Thirds system (MFT) is a standard created by Olympus and Panasonic, and announced on August 5, 2008,[1] for mirrorless interchangeable lens digital cameras and camcorders design and development.[2]
MFT shares the original image sensor size and specification with the Four Thirds system, designed for DSLRs. Unlike Four Thirds, the MFT system design specification does not provide space for a mirror box and a pentaprism, allowing smaller bodies to be designed, and a shorter flange focal distance and hence smaller lenses to be designed. Virtually any lens can be used on MFT camera bodies, as long as an adapter exists.
Itd itd itd.
Ili:
DSLR:
Mirrorless:
Micro 4/3:
Itd itd itd.
@Sloba, tako nekako, u njima ces u najvecem broju slucajeva naci male senzore iz kompakta.
Sada se u par modela pojavio nesto veci senzor, mislim da je recimo Sony RX 10, ali se postavlja pitanje cene.
Ne znam gde bi Wiki uklopio moj RX 100, jer po njihovim definicijama, bar po jednom parametru ne uklapa se u njihovu podelu po grupama.
To je DP Review podelio drugacije, cak organizujuci ankete medju najbrojnijom fotografskom populacijom, kako nazvati koju klasu aparata.
To i ja kazem, sad su klase aparata ispomerane pojavom vecih i APS-C i FF senzora u malom, "kompakt" kucistu koje je bilo rezervisano za spenadla senzore. Sad i Nikon ima sistem 1...
I upravo to kazem, velicina senzora ne odredjuje klasu. Pogotovo tek sad.
Veličina senzora je obično prvi (naravno ne i jedini) parametar po kome se vidi koliko je neka sprava ozbiljna.
Tapatalk 4
Tapatalk 4
U sustini da, samo i ne mora da znaci. Imas mnostvo losih aparata sa velikim senzorima.
Ali uglavnom sto veci senzor ipak znaci i veci kvalitet fotke.
Ja sam progledao kad smo na poslu pre 10 godina dobili Canon EOS 10D, prvi DSLR koji sam koristio.
Inace, dok sam radio u PC Press-u, sve komponente, konfiguracije, monitore i ostalu skalameriju sam u studiju slikao (pocetkom dvehiljaditih) sa G1 (Canon Powershot G1). Bio je otkrovenje a samo 3,2mp. Fotke slikane njim su cak isle bez problema na naslovnu stranu PC-a. Doduse, studio je studio, ali svejedno.
Inace, koji ste prvi digitalac imali?
Ja ovaj:
http://www.dpreview.com/products/Olympu ... /oly_d620l
Ja ovaj:
- Saša
- Postovi: 14518
Re: Одг: Koji foto-aparat koristite?
Pazi kada je i meni to bio bio prvi digitalni fotoaparat, samo je imao oznaku Camedia C-1400L, Olympus, naravno. Mislim da su isti fotoaparati, samo različite oznake.
A 10D imam takođe na poslu i još se koristi, i to intenzivno.
HP Photosmart 720 Camera
još živ i potpuno ispravan. Slike su bile odlične. Posle njega pocrkalo 4-5 bižuterija komada, kompakta.
Ovo je bio kvalitet.
- Prikačeni fajlovi
- hp_photosmart_720_front.jpg (24.57 KiB) Pogledano 1703 puta
N95 je bio kasnije. I dalje ga tašta koristi.
Nikad nisam imao kompakt fotic, ljubav prema fotografiji sam otkrio uz N95 (koji btw pravi vrhunske fotografije s obzirom na datum izlaska i na to da je mobilni telefon u pitanju), posle sam uzeo 450D.
- BAJKER
- Postovi: 6086
Prvi digitalac odlicni malisa sa svim manuelnim mogućnostima podešavanja Canon Power shot A80 kupljen 2003 godine
Drugi je bio prosumer s kojim nisam bio baš zadovoljan kvalitetom slike koju je davao Canon Power shot S2is kupljen 2005godine.
Treći je bio moj prvi DSLR kupljen 2006 godine, sa ovim sam tek bio extra zadovoljan, sa dokupljenih druga dva objektiva činilo je kvantni skok u pogledu mogućnosti fotografisanja. Četri godine smo se družili i onda ga je zamenio sadašnji 40D
Da to je taj, oznaka C-1400L je za EU trziste bila.Saša napisao:Pazi kada je i meni to bio bio prvi digitalni fotoaparat, samo je imao oznaku Camedia C-1400L, Olympus, naravno. Mislim da su isti fotoaparati, samo različite oznake.A 10D imam takođe na poslu i još se koristi, i to intenzivno.
Posle je dosao G1, koristio sam i Nikon E3100, Canon EOS 10D, Nikon D200, Canon EOS 30D... sad EOS 650D, imam i pomenuti Fuji S6500FD, na poslu jos koristim i 5D MK2...
- Gaginh0
- Postovi: 9915
- Garaža: Nemam garažu :(
Re: Fotografija
Moj skromni doprinos. Slikano LG L9 telefonom.
Re: Fotografija
Interesantan ulov tamo gde je ovo baš velika retkost.
