Alfa Romeo - generalna tema
Postovi: 25061
Re: Alfa Romeo - generalna tema
Tema je kao sto znate AR. :back2topic:
Postovi: 49064
Novi motori za Giuliettu i MiTo.
Alfa Romeo has introduced two new engine versions in Italy for the Giulietta MY2014 and MiTo MY2014.
The Giulietta gets a new 2.0-liter JDTM turbodiesel unit producing 175PS (173hp), in combination with the 6-speed double-clutch TCT gearbox. Available only for the Distinctive and Exclusive top trim levels, the Alfa Romeo Giulietta with the new engine is priced from €30,450 ($41,745) and €31,900 ($43,730), respectively.
The new diesel engine features the third generation common rail injection system and a small turbocharger. Peak torque is 350 Nm (258 lb-ft) at 1,750 rpm, allowing the Giulietta to sprint from 0 to 100 km/h (62 mph) in 7.8 seconds and to reach a top speed of 219 km/h (136 mph). Average fuel economy is 4.4 l/100 km (53.4 mpg US), while CO2 emissions are rated at 116 g/km.
The Alfa Romeo MiTo also gets a new engine version, the 140PS (138hp) 1.4-liter MultiAir TBi, combined with the Alfa TCT. The engine is only available for the Distinctive trim level and is priced from €21,100 ($28,945). With the new unit, the MiTo sprints from 0 to 100 km/h (62 mph) in 8.1 seconds and hits 209 km/h (130 mph). Combined fuel consumption is 5.4 l/100 km (43.5 mpg US), with CO2 emissions of 124 g/km.
Postovi: 28265
Uff,taj Mito,mislim da je najlepsi auto B segmenta,ikada izbacen.
:plusone:
Postovi: 23570
prelep auto :doubleup:
Heineken
Postovi: 6461
Lokacija: Šid, Srbija
Post od Heineken »
:plusone:
Rakhil
Postovi: 8340
Post od Rakhil »
Ja bih mogao reci: subjektivno simpatican, objektivno gadan.
Vidjam ovih dana dosta Alfi 156 Q4, one kvazi SUV varijante. Smesan auto, ali opet interesantan. Kako se to pokazalo u upotrebi, vredi li cemu?
Postovi: 49064
Ako Laki prvi odgovori, odmah ćeš znati.
XM
Postovi: 11467
Postoji 156 q4 koji ej kao obični karavan, a postoji i 156 Crosswagon koja je izdignuta i ima plastične oplate. Crosswagon nije smešan nego vrlo šmekerski auto s naluksuznijim i najkvalitetnijim enterijerom u 156 i izuzetno bogatom opremom. Ima 4wd pogon sa 3 diferencijala što je izuzetno napredno. Taj pogon je daleko naporediniji od tadašnje konkurencije. S druge strane ima multilink vešanje i alu ramena koji nisu pogodni za ozbiljni off road, ali tome nije ni namenjen.
Rakhil
Postovi: 8340
Post od Rakhil »
Mislim na Crosswagon, i primetio sam preprcan enterijer, ali smesan jeste. Izgleda ko kad dete obuje tatine cipele pa seta po kuci.
Postovi: 11467
Pa, dobro ako ti je smešan ok... :kezo:
Rakhil
Postovi: 8340
Post od Rakhil »
E nek si mi rekao... :kezo:
Postovi: 11467
Nije "nek si mi rekao" ;) , nego bi teško s estetske strane bilo ko mogao da kaže da je taj auto "smešan" i smislu da je neskladan.
A valjda bi se za sve ove godine našao neko i da to kaže, a nije...mada dobro, ne mora to da bude merilo.
Rakhil
Postovi: 8340
Post od Rakhil »
Ja uvek mogu da se pozovem na licno misljenje i ukus i da time prekinem raspravu. Mogu i da vrlo argumentovano objasnim, necu reci i dokazem, svoju tvrdnju o neskladu tog auta. Pri tome, nisam opterecen nekim predrasudama ka Alfi, naprotiv. Ali ne vidim neku poentu: nit ce meni biti lepse da isterujem svoje, niti ces ti promeniti misljenje, niti ce forum postati bogatiji od toga. Samo, ova recenica ti je teski fail: "A valjda bi se za sve ove godine našao neko i da to kaže, a nije...".
Postovi: 11467
U principu se nikad ne pozivam na većinsko mišljenje da bi podržalo moju tvrdnju (što sam u nastavku rečenice i rekao), kao što ni subjektivni doživljaj ne prenosim u objektivnu ravan i ne smatram ga referentnim. Mislim da ta moja rečenica mnogo dalje od faila nego tvoja da auto liči na dete u cipelama za odrasle.
Voleo bih da mi "argumentovano objasniš" u čemu je nesklad kod Crosswagona, da batalimo priču o ukusima?
Ako te mrzi, sve je ok. ;)
