Vazduhoplovi
Heineken
Postovi: 6488
Lokacija: Šid, Srbija
Re: Vazduhoplovi
Post od Heineken »
Iz drugacijeg ugla
Slikafree image hosting
Postovi: 49248
Re: Vazduhoplovi
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
Post od Harvey Specter »
e sta se sve nece desiti u Indiji :)
Cargo loader ‘falls asleep’ on IndiGo flight en route Abu Dhabi
A Mumbai airport cargo loader “fell asleep” in the belly cargo area of an IndiGo aircraft that flew to Abu Dhabi, according to sources.
Aviation safety regulator DGCA has taken note of the incident and initiated an investigation into it. The loader was subsequently brought back to India on the return leg of the flight.
Speaking to The Indian Express, Director-General of DGCA Arun Kumar said, “On Sunday, an IndiGo A320 aircraft was scheduled to operate as flight 6E-1835 (Mumbai to Abu Dhabi). Post loading of baggage in aircraft, one of the loader engaged on the aircraft relaxed in baggage compartment 1 and fell asleep behind the baggage. The cargo door was closed after the hold staff marked the head count. The loader woke up as the aircraft took off from Mumbai airport. This was detected at Abu Dhabi and medical examination of the loader was conducted by Abu Dhabi authorities. The examination revealed that his physical condition was stable and normal. After getting the requisite clearances from local authorities at Abu Dhabi, he was sent back as a passenger to Mumbai on the return flight.’’
Postovi: 13829
Re: Vazduhoplovi
jocas napisao:Danas niški aerodromSlikaSlikaSlika
U ovakvoj zgradi je baba zivela. Vratio si me 20 godina.
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
Ryanair Boeing 737-800 gura zaglavljenu rudu ispod motora od vucnog vozila, dok taksira na Frankfurtu, 17.12.2021. godine. Ne znam kako nisu provaliali da vuku ili im niko nije odmah javio, a i kako je uopste ruda dospela ispod motora je pitanje.
snork
Postovi: 4967
Re: Vazduhoplovi
Post od snork »
Ha, zanimljivo. :)
Pitanje za one koji su upućeni: da li su ove rude za vuču univerzalne? Sigurno nije ista za mali i veliki avion, ali pretpostavljam da ne mora biti baš za određeni tip? Putnički avioni ih verovatno ne nose sa sobom?
KC-135 tanker (B707) koji je bio na aero-mitingu 2. septembra 2012. na Batajnici je u "putničkoj kabini" imao rudu i jedan dugački drveni sanduk u kome ne znam šta je bilo :) I pomoćna sedišta celom dužinom, kao manje-više u svim vojnim transportnim avionima (neki imaju klupe). Slike:
Slika Slika Slika Slika
Mala digresija:
Prisutna posada nam je rekla da je avion 1965. godište. Ono što su takođe rekli - a svako upućeniji je i sam primetio je da su originalne P&W JT3D motore kasnije zamenili high-bypass CFM-56, kao i da sada postoji "delimični glass kokpit" (dodati ekrani, ali zadržani mnogi analogni instrumenti). Tada sam mislio da je ovo jedan od starijih KC-135, a prema ovome ispada da je najmlađi, tj. da je taj konkretan primerak (reg. broj. 14840) poslednji proizveden: https://www.thisdayinaviation.com/tag/64-14840/
Ono što je bilo zanimljivo je da, od svih aviona kojima je moglo da se priđe na statičkoj postavci tog dana, jedino motor br. 2 ovog aviona nije imao pokriven usis (ali je bio pod budnim okom njihovog čoveka koji je posetiocima objašnjavao detalje ;) ). Prvi stepen (fan) se polako okretao na ne toliko jakom vetru i škripao kao nepodmazana kapija (tako ugašen, i on je bio nepodmazan). Facinantno je kako fanovi, kompresori i turbine rade sa malim momentima sile, a snagu postižu zahvaljujući velikom broju obrtaja. CFM-56 je konkretno two-shaft motor, unutrašnje vratilo spaja stepene kompresora visokog pritiska i stepene turbine visokog pritiska, a spoljašnje stepene kompresora niskog pritiska i stepene turbine niskog pritiska, na koje je preko para zupčanika (otprilike 2.5:1 smanjenje obrtaja) spojen jednostepeni fan. I celo to kolo niskog pritiska se polako okretalo na slabom vetru. :)
Rusi su posebno poznati po tome kako za vreme svakog iole dužeg stajanja stavljaju čepove u motore (u njihovoj varijanti metalni i crveno ofarbani). Da li bi dali da im posetioci pipaju fan? :D Verovatno ne...
Postovi: 13474
Re: Vazduhoplovi
Naleteo na YouTube
zuzazu
Postovi: 4656
Re: Vazduhoplovi
Post od zuzazu »
snork napisao: 20 Dec 2021, 21:17 Ha, zanimljivo. :)
Sve je tako kako si rekao.
Ovo sa rudom je interesantan incident, ne nadjoh nigde sta se zapravo desilo.
Postovi: 49248
Re: Vazduhoplovi
Može i u temu Šta voze poznati.
Postovi: 21135
Re: Vazduhoplovi
Promena na čelu Er Srbije, odlazi Dankan Nejsmit
https://novaekonomija.rs/vesti-iz-zemlj ... an-nejsmit
zuzazu
Postovi: 4656
Re: Vazduhoplovi
Post od zuzazu »
Kada pomisliš da ne može gore…
Harvey Specter
Postovi: 145
Garaža: Škoda Fabia
Re: Vazduhoplovi
Slazem se, al kad se malo bolje pogleda njegova biografija (Al Italia, Malev, Czech Airlines), mozda je sa razlogom postavljen, sto bi rekli Pravi covek, za pravi posao :o
Postovi: 21135
Re: Vazduhoplovi
Kabal
Postovi: 3198
Garaža: Volvo XC60 D5 AWD
Re: Vazduhoplovi
Post od Kabal »
B92: Novi ruski putnički avion obavio prvi let http://www.b92.net/biz/vesti/svet/novi- ... et-2078346
Postovi: 32930
Re: Vazduhoplovi
Bio sam preksinoć na aerodromu da sačekam nekog. Rekonstrukcija u punom jeku. Samo što je donji parking nedovoljan pa čim se napuni onda je red do autoputa. Da bi neko ušao na parking mora neko da izađe. A nije baš da izlaze svaki čas. Tako da sam parkirao sa strane i nadao se da me neće komunalci kazniti za tih pola sata.
