Tjunerske kuće (zajednička tema)
Scuderia
Postovi: 13495
Re: Alpina XD3 Biturbo Diesel
Post od Scuderia »
Mnogo mi ruzni oni mansoryji, bilo mi zao tamo da ga postavljam :kezo: :kezo:
kvcali
Postovi: 3007
Garaža: Omega B2 2.0
Lokacija: Kraljevo
Re: Tjunerske kuće (zajednička tema)
Post od kvcali »
Opel Astra J Kissling :djavo:
Postovi: 23579
Zahebo si me za mili sekund... taman sam kopirao :palica:
Nema trunke rdje :o :doubleup:
:mrgreen:
Postovi: 22133
Ovo ja priznajem kao tjuning, kada od prosečnog auta praviš superauto. Tjuning kada od 700 konja praviš 1500 za auto za običan saobraćaj je potpuna idijotarija. Na stranu što se toliko trude da im se kola ističu da idu u ružne krajnosti.
Tapatalk HD
Nije bas prava tema jer je solo rezija ali ne znam gde da ga stavim...
Konverzija 335i E91 u M3.
This Mineral White E91 M3 was built by M3POST member HAMDAN1000 and also features a full S65 V8 and DCT transmission fitted into what was originally a 335i touring.
As you can see, it features full M3 body panels, hood, mirror and a custom rear M3 bumper. The interior features BMW Performance seats and BMW alcantara steering wheel.
Total build time and cost for this radical conversion? Nearly 5 months and over £40,000 pounds!
Postovi: 49239
Brabus tunes the GL 63 AMG and ML 63 AMG to 700 HP
Heading to next month's IAA in Frankfurt
Brabus has announced plans to showcase at IAA next month the B63S – 700 WIDESTAR kit available for the GL 63 AMG and ML 63 AMG.
Both high-performance SUVs are powered by a V8 5.5-liter bi-turbo engine which has received gold heat reflection insulation, two bespoke turbos with larger compressor units and a free-low metal catalyst system with 75mm downpipes. Brabus also installed a stainless steel sport exhaust with controlled butterfly valve and they also remapped injection and ignition systems.
As a result, the GL 63 AMG is now capable of churning 700 HP (515 kW) at 5,300 rpm which makes it 143 HP (105 kW) more powerful than the standard model. The ML 63 AMG produces the same 700 HP, representing an increase of up to 175 HP (129 kW). Both vehicles come with an electronically-limited torque of 960 Nm (708 lb-ft) available from 2,000 rpm.
The engine is mated to an AMG SPEEDSHIFT PLUS 7G-TRONIC which allows the GL 63 AMG to hit 62 mph (100 km/h) in 4.6 seconds, while the ML 63 AMG will do it 0.2 seconds faster thanks to its lower weight. In order to protect the tires, Brabus has limited top speed of both models to 186 mph (300 km/h).
Aside from the reworked power unit, the cars come with a widebody kit with larger front and rear spoilers, 22-inch alloy wheels available in five different styles, along with several other exterior enhancements. There's also a control module for the AIRMATIC air suspension which can bring the cars closer to the road, thus lowering the center of gravity and improving handling.
WCF
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
GL :klanjamse:
Risto
Postovi: 6023
Post od Risto »
felne na S klasi :ludilo:
kvcali
Postovi: 3007
Lokacija: Kraljevo
Post od kvcali »
Postovi: 49239
Alpina B4 Biturbo.
Postovi: 11473
kvcali
Postovi: 3007
Lokacija: Kraljevo
Post od kvcali »
Nardo edition
1.8T 550ks
0-100km/h 5s
0-200km/h 12s
max. 309.6km/h
http://www.youtube.com/watch?v=mfGFaKwLWR0
kapor
Postovi: 1613
Garaža: renault clio rs 172
Lokacija: beograd
Post od kapor »
Jel ovo nisu imali para za Superleggera pa stavili nalepnice na tockove. :kezo:
