Kocnice: Bed-in procedura kod novih diskova
Postovi: 13474
Re: Kocnice: Bed-in procedura kod novih diskova
http://youtu.be/Pi4BAuMjpbE
Postovi: 28267
nidza napisao:Laki, pročitaj link sa powerbrake sajta, koristan je. Veoma je bitno da pločice dobro naležu na disk, ne samo zbog veće sile trenja, nego zbog ravnomernog zagrevanja diska. Definitivno period naleganja materijala mora da postoji i par stotina kilometara pažnje nije neki deranžman sa sistem koji treba da te bezbedno zaustavlja desetinama hiljada kilometara posle.
Bas tu i pise da treba 6 puta zakociti naglo( sa 60-70% snage, da se ne pali ABS), da bi se postigla temperatura.
Naravno, posle 300km :)
Inace, to prvo uhodavanje kocnica sluzi, ne za prenos materijala, nego za ono sto je KDman rekao, da plocice i diskovi lepo nalegnu jedni na druge.
Pre Bed-in Cycle:
Drive slowly for 1 week (at least 300km’s) after fitting new discs and pads. Use moderate brake applications during this time and try to avoid long brake applications from speeds in excess of 100 kph. Normal urban commuting, using your brakes from moderate speeds about once per kilometre is ideal. Long stretches of open road driving do not count, as the brakes are not being used. Increase following distances during this time making provision for “green fade” in an emergency stop. Never left foot brake or drag the brakes! None of the MTR temperature recording paints should have changed during this period.
At the end of the first week it should be clearly visible that the pad friction material has achieved maximum contact area with the disc surface. The ‘pad track area’ of the disc should have none of the silver disc coating left on it and should be an even light-grey colour.
Bed-in Cycle:
Drive slowly for a few kilometres, using the brakes gently to bring them up to a moderate operating temperature.
Perform 6 consecutive brake applications of increasing intensity from 100 km/h down to 30 km/h. If wheel lock-up (or ABS activation) is referred to as a 100% brake effort then you should be aiming to build up to a 60 - 70% brake effort for the last 2 applications. The applications should be performed consecutively, accelerating normally back up to 100 km/h after each application, before braking again.
If possible, do NOT come to a complete stop throughout the 6 brake applications described above. Doing so canl result in ‘pad etching’ during which friction material is unevenly deposited onto the brake disc causing DTV and brake judder. The will be visible as the outline of a brake pad on the disc surface. (To learn more about pad etching and DTV click here)
It is normal to experience a strong smell and even see a small amount of smoke rising from the brakes from the 4th application onwards. This is not a problem. Be prepared to experience “green fade” from the 4th application onwards.
Drive on, using the brake as little as possible, for a number of kilometres allowing the brakes to cool substantially in the air-stream before parking the vehicle and allowing the brakes to cool completely. This cooling cycle is important.
Gradually build up your driving style over the next 500 - 700 km's while keeping an eye on the MTR temperature measuring paints on the discs. If the red paint turns white, you are running your discs over 610 deg C and disc life will be reduced as a result.
McGruja napisao:Da li ste menjali diskove, a plocice ostavili jer su presle samo 2-3.000 km?
I da li radite bed in diskova?
Da, i obrnuto.
Nista ne smeta ako je iole kvalitetno.
Bed in radim prema proceni, obicno da ako se setim (najcesce je to slucaj).
II brzina, oko 50km/h stisnem kocnicu levom, gas desnom i oko 3-4km lagano pritisnute kocnice.
Moze i po 1-2km pa pauza i opet kao metod.
Bitno je samo da se otkinu oni povrsinki hrapavi komadici koji ostanu posle proizvodnje, koji ne vidimo golim okom jer su mikroskopski malecen grbice.
Ovo je dovoljno jednom uraditi, bed in traje oko 5-10 minuta i to je cela mudrolija.
I moze posle toga normalno se koci koliko treba jer je ovo nepovratan proces.
Koliko kapiram površine novih diskova i pločica su pod npr mikroskopom ozbiljno neravne i potrebno ih je "ošmirglati" jednu o drugu.
Meni je logično da se to radi blagim kočenjem, a ne stiskanjem ko manijak.
KDman
Postovi: 335
Pridružio se: 29 Jan 2014, 22:14
Post od KDman »
ljubitelj napisao: Bed in radim prema proceni, obicno da ako se setim (najcesce je to slucaj).
Svašta, i tako spališ nove ferode. I posle voziš 20 hiljada sa krš kočnicama.
Pa nisu to čoveče sinter ferode ili diskovi od karbonskih vlakana :glavomuzid:
Jesi li probao pa znas da se spali ili?
Naravno da se ne spali, naravno da se jedva oseti zagrevanje pipanjem rukom i naravno da se time moze otkloniti nesavrsenost povrsine.
Inace, nisam to ja izmislio vec samo primenjujem uputstvo koje su napisali fabricki inzenjeri u radionickom uputstvu (fabrickom).
I nalazim u praksi da ono sto si napisao se jos nije nikada dogodilo, u mom iskustvu, a da odradi posao koji je predvidjen.
Postovi: 10746
Tako sam po savetu starijeg drugara radio na svom prvom autu Z101 pre bezmalo 20 godina. Ne drži se tu kočnica sivonjski, već ovlaš. Nema šanse da se pregreju i spale kočnice. Nisam vozio baš par km, ali jedan km verovatno jesam.
Dzoni_m
Postovi: 2010
Garaža: BMW 118i, CX-60
Lokacija: DE
Post od Dzoni_m »
Ja sam to radio sa par snažnih kočenja. Ubrzam na nekih 80-90 snažno kočenje, i ponovim tu proceduru 3-4 puta. Odmah se oseća bolje da koci i sve je na svom mestu.
Postovi: 14756
par snaznih = jedan duzi :)
Postovi: 22134
Napraviste filozofiju.
Voziš auto par dana normalno, samo paziš da nemaš nagla kočenja, nego lagano sve i nema zime. Ne treba neki specijalan tretman, samo ne treba odmah niz Avalu.
Tapatalk Pro
Postovi: 11254
Post od Ogi »
Hajde da se nakalemim na ovu temu jer je najpribliznija onome sto hocu da pitam a da u imenu ima rec "kocnice" .
Poslednja 2-3 dana mi zadnje kocnice puno struzu sto najvise cujem onih poslednjih sekund, dva pre nego sto potpuno stanem a kada menjac ubacim u ler. Generalno ne znam koliko to traje jer uvek slusam radio i nisam obratio paznju na to mada se vec duze vreme cuju malo ali tome nisam pridavao znacaj ali mislim da je sada mnogo vise. Inace auto normalno koci.
Situacija sa plocicama je takva da su mi u Triu rekli da ce mi ih menjati ovog leta kada dodjem na redovan, da so do tada ok.
Da li je to do plocica ili mozda do diskova ? Oni su fabricki. Nista ne trese za sada, znaci nije da su se izdeformisali ali me ovo "plasi" da ne skenjam nesto pa da napravim vecu stetu tipa da su plocice mozda toliko se izlizave da sjebu diskove ali opet, u Triu su ih gledali pre 10 dana i rekli da mogu do leta sigurno...
Postovi: 25143
Hoce da se cuje kada se pojavi korozija nakon nekog vremena stajanja, pa dok se ne skine hoce malo da struze. Meni se to cesto desava jer se auto ne vozi po nekoliko dana.
Postovi: 11254
Post od Ogi »
Znam, hoce i posle pranja kada auto stoji preko noci pa ujutro ali auto se svaki dan vozi.
Postovi: 11256
Ma nista ne brini. Malo iz ostruzi kocenjem da skine malo povrsinske rdje ako se napravila.
Postovi: 10746
Pa, jbt, čovek kaže da nije to. Rdja se skine na prvom ćošku.
Sent from my Sony XPERIA M2 Aqua
