2019 Renault Clio
Re: 2019 Renault Clio
Ne mogu da procenim da li je nov model. Možda je neko požurio sa naručuvanjem modela.
https://www.miniaturendekimpe.be/index. ... duct=41992
https://www.svetauticek.cz/www-svetauti ... -Premium-X
Uporedo generacije.
Uporedo generacije.
So far, the Clio already had a 3-cylinder block, in the person of the 0.9 Tce 90 H4Bt which developed as its indicated 90 ch. On the Clio and on the Twingo. As we announced almost a year ago (see a new Engine 1.0 tec at Renault), this 900 cm3 will be replaced by a slightly larger block, which will reach 999 cm3. Still of fitted of 3 cylinders, this block will not be a real revolution since it will be well on derived from an already existing engine, namely the new 4 cylinders 1.3 TCe H5Ht and not the current 3 cylinders.
Always equipped with a turbo, it will be equipped with an indirect injection and will be slightly more powerful, notably by winning 10hp. For the basic version. But above all, while the 110hp version of the 0.9 TCe was not offered at Renault, this time this block could be available in 117ch., with direct injection as well as on the MICRA.
https://www.planeterenault.com/1-gamme/ ... io-5-h5dt/
- Day Walker
- Postovi: 23561
- Garaža: BMW X3
Uistinu lep!
- igor_harris
- Postovi: 2210
- Pridružio se: 12 Jan 2017, 13:47
- Garaža: 2004 Mazda 3 (1.6CD)
Gepek veci nego kod Megana. Ja ne znam ko je tu lud...
- Risto
- Postovi: 6023
- Lokacija: Klagenfurt, AT
Auto spolja izgleda fenomenalno
Enterijer mi se manje svideo ali bi se navikao brzo... Napravili su manji a širi auto, dobar fazon, širina donosi dosta kod komfora plus veći gepek.
