Opel Omega: 3000, EVO500, Lotus
- profesorPROST
- Postovi: 3281
- kvcali
- Postovi: 3007
- Pridružio se: 13 Jan 2012, 10:02
- Garaža: Omega B2 2.0
- Lokacija: Kraljevo
Re: Opel Omega: 3000, EVO500, Lotus
- kvcali
- Postovi: 3007
Evo jedan zanimljiv sajt iz severnih predela
http://www.lotusomega.se/public_html/specification.htm
I neke detaljnije karakteristike, prosto neverovatne brojke za auto od 20 godina
377 bhp at 5200rpm.
568 Nm/5500rpm (557 Nm / 4200 rpm,406 Nm / 2000 rpm )
0-100km/h 5.4s
0-200km/h 17.3s
0-100-0km/h 8.6s
0-60mp/h (97km/h) 4.9s
0-100mp/h (161km/h) 11.0s
0-402.33m 13.5s
286km/h
In-line six cylinder 3615cc.Double overhead camshafts,
4valve/cylinder. Lotus-Delco electronic multipoint fuel injection.
Twin Garret T25 Turbochargers each with liquidcooled-
intercoolers 0.7 bar turbopressure.
Reinforced iron cylinderblock,graphite coated pistons,forged-
crankshaft ,reinforced special connecting rods, hardened-
camshafts and modified lubrication system with oil spray
on pistons from underneath.
Rear differential with 45% slip function from Australia
GM Holden Commondore
Front:MacPherson struts with coil springs and triangle -arms,
anti-rollbars. Rear: Multi-links,coilsprings, anti-roll bars.
Gas shock absorbers, with pneumatic self-levelling.
Recirculating ball, rack and pinion, speedsensitive, 2.6 turns
lock-to-lock
AC, Full leather, hard wood, 17" wheels.
Front 8.5-17 235/45-17
Rear 9.5-17 265/40-17
Ventilated discbrakes front and rear Front 330mm with
4-piston racing calipers. Rear 300mm dual-piston racing-
calipers. ABS
Length: 477cm, Width: 181cm Height: 143cm
Wheelbase: 273cm , Track: f 149cm, r 154cm
Weight: 1650kgs(empty). Fuel tank 75litres
377 bhp at 5200rpm.
0-100km/h 5.4s
0-200km/h 17.3s
0-100-0km/h 8.6s
0-402.33m 13.5s
286km/h
lock-to-lock
calipers. ABS
- starac vujadin
- Postovi: 11448
To je cuveni klip...cuven skoro kao klipovi Ghost Ridera.
