Dacia Sandero 2013
Postovi: 23569
Re: Dacia Sandero 2013
Misliš kao prava Dacija? :mrgreen:
Postovi: 20954
methane.master napisao: 1.5 dci je u MB išao as-is.
Info je od ljudi iz Mercedesa, sa prezentacija.
Ima nešto i ovde:
http://media.daimler.com/marsMediaSite/ ... id=9904036
Numerous components are specific to Mercedes-Benz, for example the OM 607 has the engine mountings of the M 270 petrol engine, as well as a special two-mass flywheel. The starter flanged onto the transmission, the alternator and the refrigerant compressor also come from the Mercedes modular system, and are driven by a belt with six grooves.
Like all Mercedes engines, the OM 607 was required to absolve the extensive engine test programme involving bench-testing and endurance runs. The application effort devoted to the OM 607 by Mercedes-Benz was very considerable. In a joint project team of Mercedes and Renault personnel the engine was especially improved with respect to NVH and driveability. Coordination work also went into the ECO start/stop function included as standard. This Mercedes-specific feature also operates at temperatures down to minus 10 degrees Celsius, for example, and can therefore make a more frequent contribution to fuel economy.
Postovi: 14524
Malopre video facelift običnog Sandera na autoputu, nove štopaljke pozadi sa 4 LE diode u svakoj, LED dnevna svetla napred i još poneki sitan novi detalj - vrlo fino, osveženo i korektno prema starim kupcima... :)
Postovi: 32700
Garaža test: Dacia Sandero 0.9 TCE Easy R
http://blog.garaza.rs/garaza-test-dacia ... ce-easy-r/
Postovi: 14524
Fino.
Sve bolje i bolje aute prave. :)
Postovi: 32700
Realno veliki napredak u odnosu na prvu generaciju, još sa ovim fl opet bolje. Teško je reći da li bi bio moj izbor za 10k evra, koliko košta testirani primerak, ali u suštini ne bih se ni žalio da ga posedujem.
Postovi: 14524
Za nekog ko želi novo (a da je što jeftinije) i namerava da to vozi 10 godina, jako dobar izbor. Samo ne sa tim menjačem. :)
Postovi: 9683
Mogu da zamislim kakva je katastrofalna kombinacija 0.9 i taj nakalemljeni menjac :glavomuzid:
Postovi: 13456
Zar nije bila priča da će EDC da ubace u Dačiju?
dačia ubrzava isto kao reno megane sa 300 ccm više :mrgreen:
oba automatici
Postovi: 9683
0.9 ima ogroman turbo lag. Obrtni moment mu pocinje posle 2500rpm, tako da stavljanje bilo kog automatskog menjaca je losa kombinacija.
Moj 0.9 je bio znacajnije tezi od ovog sandera, mozda u sanderu se bolje ponasa ali opet bez manuelca nista.
Postovi: 32700
@Darko
Katastrofa je kad sedneš prvi put, ali kad ga voziš malo i skontaš kako radi onda nije uopšte tako loš. Razvio ga je ZF, koliko sam saznao na netu, tako da nije loš, samo ne može da se meri sa savremenim automatikom. Motor je po meni odličan.
Postovi: 13703
Samo dci :D
Postovi: 9683
Postovi: 48955
FL za Brazil.
