Mercedes - generalna tema
Re: Mercedes - generalna tema
2.0 motor u A45, CLA 45 i njihovim S verzijama ce imati 388 i 422ks, 475 i 500Nm.
- starac vujadin
- Postovi: 11473
Pozdrav za Veyron, Chiron i Michelin koji testiraju da li mogu ili ne mogu 400km/h, da li mogu 500km/h, hoće li gume izdržati ili neće izdržati, prave simulacije...
736ks i 433km/h na starom autobanu sa običnim gumama...
Da, da, svaka im cast, htjeli su jos vise ali krenu rat.
- passenger
- Postovi: 14231
2-3 litra motor? Koji motor je imao?
Potencijalno 50 ljudi mrtvo da se desila nesreća
- starac vujadin
- Postovi: 11473
Engine: MD 25 DAB/3 60 Degree V12
Engine position: Front longitudinal
Aspiration: Twin Roots superchargers
Valvetrain: DOHC 4 valves per cylinder
Displacement: 5,576.75 cc / 340.31 in³ (82.0 x 88.0 mm)
Compression: 9.17:1
Power: 541 kW (736 PS; 725 hp) @ 5800 rpm
Power/displacement 131.97 PS (97.06 kW; 130.16 hp) per litre
Power/weight: 621.1 PS (456.8 kW; 612.6 hp) per tonne
Transmission: 4-speed manual
Engine cooling: Ice supplemented normal coolant as air intakes were kept very small to improve aerodynamic flow over and around the car
Inače, taj dan su Mercedes i Auto Union imali pokušaje obaranja rekorda, pa je priliko pokušaja poginuo čuveni Bernd Rosemeyer u Auto Unionu kada je dostigao skoro istu brzinu i pokušao da je nadmaši, ali se pokvarilo vreme.
Compression: 9.17:1
- passenger
- Postovi: 14231
Pa to, 5.5 litra motor, a ovamo piše Klasa D 2-3 litra, pa ne razumem.
Xeroj, jel znaš u koje sve modele se ugradjuje ovaj novi 2.0d sa 194ks, i da je kombinaciji sa 9G tronic?
Evo jos vise:HKS napisao:Da, da, svaka im cast, htjeli su jos vise ali krenu rat.
"The massive 44.5 litre Daimler-Benz DB 603inverted V12 was selected to power the record-setting car. The engine was an increased displacement derivative of the famous DB-601 aircraft engine that powered the Messerschmitt Bf 109 fighter in production at the time, with the DB 603 ending up as the largest displacement inverted V12 aviation engine in production for Germany during the World War II years. The DB-603 fitted was just the third prototype (V3) engine of this variant and tuned up to 3,000 hp (2,237 kW; 3,042 PS), roughly twice the power of the Bf 109 or the Supermarine Spitfire. The engine ran on a special mixture of methyl alcohol (63%), benzene (16%), ethanol (12%), acetone (4.4%), nitrobenzene (2.2%), avgas (2%), and ether (0.4%) with MW (methanol-water) injection for charge cooling and as an anti-detonant."
Ovo je bila zvijer.
- passenger
- Postovi: 14231
Bolji onaj iza
