Porsche Macan
- passenger
- Postovi: 14231
Re: Porsche Macan
https://www.youtube.com/watch?v=HgVue72wqnI
Reply from Porsche:
REPLY FROM PORSCHE:
''The brake intervention shown in the video is a deliberately applied intervention to prevent the car from rolling over. This is called Active Rollover Prevention (ARP). The precise, momentary application of brake force to the front wheel at the outside of the bend down to the low slip range minimises cornering forces to avoid critical or instable driving conditions such as oversteer, rollover or detachment of the tyre from the wheel. Situations such as these may not be controllable by the driver.
The video shows that an understeer response is selected on purpose since it is significantly easier for the driver to control than oversteer. The function shown and the resulting driving response are explicitly desired to increase driving safety in such a highly dynamic driving manoeuvre.
In the SUV segment, Active Rollover Prevention (ARP) is state-of-the-art technology and is also used by other vehicle manufacturers.
The intensity of ARP intervention is dependent on vehicle speed and steering angle speed, among others. This means that ARP brake intervention is diminished accordingly at reduced vehicle speed or steering angle speeds. On the other hand, it means that the driving style adopted by Teknikens Värld was very demanding and resulted in the safety function being triggered.
Active Rollover Prevention is permanently active, irrespective of whether Porsche Stability Management (PSM) is on or off. If PSM is on, ARP intervention is significantly diminished since PSM brake interventions to stabilise the vehicle occur much earlier or are superimposed.
The function (ARP) is applied for a maximum of 300 milliseconds, depending on the driving situation. This short intervention ensures the directional stability of the vehicle. Lateral displacement is negligible. For this reason we do not regard this driving state as critical. As the video shows, lane changing can be completed stably and safely. What is more critical in this situation is if the vehicle were to roll over or the rear were to break away. The vehicle demonstrated none of these instable states (rollover, oversteer, wheel lift) at any time.
Porsche uses a comprehensive dynamics test programme which the Macan completed successfully. The driving manoeuvres performed include double lane change according to ISO, slalom with 10 x 18 metres and 10 x 36 metres, the VDA obstacle avoidance test which is very similar to the Teknikens Värld ”moose test”, and the NHTSA rollover safety test. All Porsche cars are designed for maximum safety based on these and other world-wide tests.
Hermann-Josef Stappen, Porsche''
Off topic
[video]https://www.youtube.com/watch?time_cont ... aIcvFJM4DU[/video]
Reply from Porsche:
REPLY FROM PORSCHE:
Off topic
Re: Porsche Macan
- Ji 4Tze
- Postovi: 8246
Re: Porsche Macan
I posle Opel ima previše dugmića..
- Ivan
- Postovi: 9931
Re: Porsche Macan
I posle takvi otvori u ventilaciji kriminalni...
- Day Walker
- Postovi: 23569
- Garaža: BMW X3
- passenger
- Postovi: 14231
Re: Porsche Macan
Su ti otvori ventilacije slični kao na Kodijaku?
Re: Porsche Macan
Ovaj Macan Turbo PP je u sustini Turbo GTS. Odnosno, sva ona unapredjenja sasije, kao i dodatno spustena sasija sto je vazilo za GTS koje su ga izdvajale i cinilo omiljenim Macanom su ubacena i u ovaj Turbo, tako da je ovo sada bez dileme najbolji Macan, nema vise ko sta preferira.Geza napisao:Macan Turbo Performance Package, 440 KS
https://newsroom.porsche.com/en/product ... 12842.html
- Postovi: 15754
Re: Porsche Macan
Macan, Special Edition
Re: Porsche Macan
Smejurija...
Re: Porsche Macan
Ne kontam opste sta je ovo?
Bezveze izgleda, al pedja sto ne ostavi link ka informacijama.
- Postovi: 15754
Re: Porsche Macan
Ah da, Link
Re: Porsche Macan
Lepo izgleda ova kombinacija GTS beli sa crnim Spider felnama.
- Postovi: 24968
Re: Porsche Macan
Jedino sto crna toliko skrije detalje da je tesko prepoznati bilo sta. Mozda bi neka tamno siva bolje stajala.
Re: Porsche Macan
Ne, bilo ih je u svim bojama (iza se nazire
Sive i srebrne su bezveze, najbolje su ova bela sa crnim felnama, bela sa turbo 21 felnama i zatamnjenim farovima, i ne zaboraviti exluzivnu karmin crvenu sa ovim crvnim Spider felnama.
