Zatamnjena stakla
- Vladapetr
- Postovi: 9821
Re: Zatamnjena stakla
Što bi se razlikovalo? Jel si zagledao nekad kako izgleda folija na zadnjem staklu?
Na ovom delu je uvek sivkast sloj jer se folija ne zalepi za staklo zbog mnoštva crnih tačkica:
I nisam iskreno. Znam da kod ovih sa strane bude manji ili veci prepust u zavisnosti od toga ko radi, ali na ovim ''fixnim'' staklima nikad nisam obratio paznju. Ali i dalje ne kontam tacno na cega mislis dok ne vidim
Jedino ova tanka siva linija oko celog stakla, ali ne znam da li je tako i fabricki.
Da to. Vidi se uvek kada su folije.
- Grujic
- Moderator
- Postovi: 13567
Ima oznaka na fabricki tamnim staklima
- zeljkokg76
- Postovi: 393
- Pridružio se: 19 Okt 2015, 18:49
- Garaža: Honda Civic 1.5T Sport plus, Mazda 2 1.3, Renault Clio IV 1.5 dci, Renault Megane 1.5 dci
- Lokacija: Крагујевац
Oznake su koliko mi se čini AS1,AS2,AS3 za fabrički tonirana tj zatamnjena stakla.
- Postovi: 24694
To je vise za tip stakla da li je laminirano za soferku ili kaljeno, providnost je svakako veca od 70% kada ima v znaci da je fabricki zatamljeno, bilo je vec reci o tome.
The AS number stands for American Standard, and is “AS” (or “American Standard”) followed by a number indicating the position in which the glass may be used, based on its optical quality. AS1 is the clearest glass (at least 70% light transmission), is laminated, and can be used anywhere in a motor vehicle (typically just the windshield), AS2 is tempered with at least 70% light transmissions, and can be used anywhere except the windshield, and AS3 can be used in certain locations in certain vehicles (and can be laminated or tempered, and has less than 70% light transmission). There are higher numbers used for other purposes, but are not normally encountered in cars. This number must be near the manufacturer’s name/logo, preferably below it (per Z26.1996 - See more at: http://www.carwindshields.info/windshieldmarkings#.dpuf
Inace nemaju sva kola te tackice, pa je kod nekih teze primetiti da li je folija.
Dovoljno je pogledati kako folija prelazi preko "odštampanih" oznaka koje se nalaze u uglu svakog stakla. Ne treba posebna ekspertiza.
Inače, uskoro započinjemo odiseju za legalizacijom folija na Jazzu. Videćemo kako ćemo proći kod Ivana iz Kumodraža i kod Delte za početak.
Meni malo fali da vratim folije napred i na šoferku ...
- RobiNS
- Postovi: 800
- Pridružio se: 30 Dec 2012, 09:03
- Garaža: Vitara 2019 Premium 1.0, Yamaha X Max 125
- Lokacija: Novi Sad - Rumenka
Neki dan sam se čuo sa Lacikom (iz Sr Kamenice) da pitam ima li pomaka - kaže još je u skuptinskoj proceduri ta izmena zakona...
al kaže - ljudi stavljaju folije i dalje čak i na šoferku...
bez ozira na sve...
Ko ume da se raduje – ima čemu da se raduje!
A ko ume da pati - često pati i bez razloga! D. Radović
- Uninuni
- Postovi: 913
- Pridružio se: 21 Jan 2013, 19:30
- Garaža: Fiat Bravo 1.9 2007, Mazda Cx 5 2,2 2017
- Lokacija: Novi Sad, Serbia
Sto bi znacilo da mi koji imamo ne treba da skidamo
Navodno u martu izmene zakona koje će pojednostaviti proceduru. Ali ako se raspusti skupština sutra od toga nema ništa.
- samo polako
- Postovi: 3361
Fine su to pare, ne ispušta se to nikome tako lako.
