Zanimljivi oglasi
mrNitroSleeper
Postovi: 249
Pridružio se: 28 Maj 2014, 12:34
Lokacija: Neusatz
Re: Zanimljivi oglasi
Post od mrNitroSleeper »
https://bakersfield.craigslist.org/cto/ ... 99539.html
f this ad is still up, the M5 is still available! This M5 has been cared for beyond anything you'll find. It drives and operates beautifully! This car has been covered under a CPO warranty in addition to two other extended warranties thereafter. The extended warranties were NOT cheap and also required additional deductibles for approved work. Both extended warranties were maxed out in labor/parts costs totaling more than $70,000 that you don't have to pay for! No expense has ever been spared on this car. Everything that is known to go bad on this car has already been repaired in excellent fashion by either the BMW dealer or Autohaus Frankfurt. CLEAN TITLE WITH PINK SLIP IN HAND. NEVER SMOKED/NO PETS/NO ACCIDENTS with this car. Please don't contact me with offers to assist me with the sale, the car sells itself.
First things first, I have a manilla folder that's two inches thick worth of authorized repairs (included in the sale of course). I've uploaded pictures of the more expensive receipts but can't upload pictures of all of them, there's too many. Although other sellers may say work has been done on their vehicles, many do not have proof in the form of receipts etc. All of my receipts reflect the VIN number on my car, amongst other things.
Approved repairs/maintenance are as follows...
NEW ENGINE W/ MANY ASSOCIATED PARTS AND COMPONENTS (SEE RECEIPTS) $25,076
COMPLETE NEW TRANSMISSION W/ NEW CLUTCH, FLYWHEEL, FLUIDS AND COMPONENTS DONE ON 10/17/2016 (INCLUDED WARRANTY) VERY LITTLE MILES ON THESE!! $16,700
NEW SMG HYDRAULIC UNIT (WHOLE THING) $5100
(NEW DINAN LIMITED SLIP DIFFERENTIAL W/ NEW DIFFERENTIAL BUSHINGS/STEERING OIL & ASSOCIATED PARTS (LESS THAN 10,000 MILES AGO)
NEW OIL PAN, FRONT AXLE SUPPORT, LOWER ENGINE AND TRANSMISSION COVERS & OTHER COMPONENTS) $9260 (HAVE SINCE SWAPPED THE DINAN UNIT WITH OEM)
NEW AIR CONDITIONER COMPRESSOR W/ ASSOCIATED COMPONENTS/GASKETS $2476
NEW THROTTLE ACTUATORS $2000
NEW IDLE CONTROL VALVES $1495
NEW CCC MODULE (AUDIO DECK) $1452
NEW STARTER MOTOR DONE A FEW MONTHS AGO (EXPENSIVE REPAIR!) $1400
NEW FLEX DISC (GUIBO) FOR DRIVE SHAFT (RECENTLY DONE)
NEW CENTER SUPPORT BEARING FOR DRIVE SHAFT (RECENTLY DONE)
NEW INNER CV JOINT FOR DRIVE SHAFT (RECENTLY DONE) (JUST UNDER $1000 OUT OF MY POCKET FOR THIS AND THE TWO ABOVE)
NEW CONTROL ARM BUSHINGS $706
NEW IONIC CONTROL MODULE $612
DRIVER SIDE REAR HALFSHAFT (AXLE) REPLACED $500
NEW BRAKES AND ROTORS
NEW STEERING BUSHINGS $380
NEW ALTERNATOR $485
NEW OIL LEVEL SENSOR W/ GASKET RING $396
SPARK PLUGS REPLACED 1 YEAR AGO $220
2 NEW COILS REPLACED 1 YEAR AGO $240
NEW WINDSHIELD $240
NEW THERMOSTAT DONE A FEW MONTHS AGO W/ COOLANT FLUSH ($300)
NEW A/C BELT $178
BMC AIR FILTERS ($170 JUST CLEANED THEM 2 MONTHS AGO)
BATTERY REPLACED $386
FRONT SWAY BAR REPLACED $400
BILLET ALUMINUM POWER STEERING RESERVOIR INSTALLED $200
CAMBER KIT INSTALLED (TURNER MOTORSPORTS) $545
WHEEL SPACERS
EIBACH LOWERING SPRINGS (ALSO INCLUDING THE STOCK SPRINGS AS WELL IF YOU WISH TO REVERT BACK) $300
POWDER COATED OEM WHEELS $700
MATCHING FRONT KIDNEY GRILLS AND SIDES
QUALITY WINDOW TINT $350
EUROPEAN CODING FOR KEYFOB $190
ALSO JUST PURCHASED A BRAND NEW KEYFOB FROM BMW 5 WEEKS AGO (TOTAL OF 3 NOW) $267of
iggyboy
Postovi: 1134
Pridružio se: 16 Jul 2012, 14:31
Garaža: 407 coupe 2.2 petrol
Lokacija: pozarevac
Post od iggyboy »
https://www.polovniautomobili.com/auto- ... stratus-jx
ja iskreno ne bih dao vise od 1000 evra za ovo
a ne znam ni kako ce da prodje tehnicki sad po novom
▒▓██ P █ A █ R █ T █ I █ Z █ A █ N ██▓▒
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
Sjajan primerak za onu "smajling" temu :) Prosto neverovatno kako je odredio cenu...
Postovi: 9477
ne znam kako nekom moze da se svidja ova hrapava folija, bio jedan merc ML u mom kraju pa to je uzas kako izgleda, ne znam ni kako se ono pere, nikad nije izgledala ful cisto i sad vidjam par automobila sa nekm detaljima u tom fazonu, odvratno
https://www.olx.ba/r/30568683/58390
SlikaSlikaSlika
Postovi: 28242
Taj auto moze da bude na naslovnici knjige "Kako sebi da upropastim zivot" :D
Ivan
Postovi: 9930
Garaža: bmw 3 f31, bmw 5 f10,
Post od Ivan »
Dobro ste spomenuli ovo za 25d jer sam ga baš merkao nešto , slab je izbor u toj klasi 4x4 i 2.0 motor.
520d xdrive u rangu cene sa 525d xdrive
Gruja1595
Postovi: 919
Garaža: BMW F30 320eD
Lokacija: Kragujevac
Post od Gruja1595 »
http://www.polovniautomobili.com/auto-o ... 77/audi-q5
Moj auto, ako zanima nekoga :)
member
Postovi: 3732
Post od member »
Ivan napisao:Dobro ste spomenuli ovo za 25d jer sam ga baš merkao nešto , slab je izbor u toj klasi 4x4 i 2.0 motor.
Ne znam , možda je slučajnost da za tih par primera koje znam za 525d da su loše prošli, a recimo svi sa 520d su zadovoljni.
Da se ogradim da 90% tih auta su polovnjaci iz uvoza, tako da je sve to individualno.
Odeš do Zekića pa dobiješ direktno informacije iz prve ruke o čemu se tu radi.
Za F10, i generalno BMW, 3.0d se odlično pokazao. Ali to je kod nas raritet u rangu M5 Slika
Ova dva moja slučaja su sa servisnim knjigama, i mislim da je F10 od prvog vlasnika. Tik preko 100 000 km na satu bio kad ga kupio. Kačio sam ovde negde oglas. Dosta oprema, šiber, HUD, Webasto, xDrive itd, ali ubi ga auto. Nije mogao da prodje tehnički pregled u AT pre par nedelja :)
carov2
Postovi: 4958
Garaža: Audi A4
Lokacija: Pirot, Kladovo
Post od carov2 »
Čovek sa jednog drugog foruma je baš zadovoljan sa 525d f10 2.0, 2014. Prelazi puno kilometara godišnje, mislim da je prešao preko 100k km sa njim. (Tipa sa oko 100k km je kupljen, sada ima preko 200k km.) Jedno vreme je bio i čipovan.
Postovi: 7520
Da brush ga bas hvali.
Postovi: 28242
Zasto mu je skinuo cip?
Postovi: 7520
Jebavao ga valjda dpf
Ivan
Postovi: 9930
Post od Ivan »
A dpf ostao u zivotu?
