Mercedes E facelift
- Day Walker
- Postovi: 23576
- Garaža: BMW X3
- nuk
- Postovi: 7607
- Lokacija: Ns
Re: Mercedes E facelift
@DW
moze biti mada mi je i dalje cudno da nema prskalica
Tako je, necemo dozvoliti da cvrsti materijalni dokazi stanu na put nasim ubedjenjima
Mora imati prskalice!!!
- Day Walker
- Postovi: 23576
- Garaža: BMW X3
npr UK:
By the law in UK Xenon lights can be fitted if headlights are with self leveling and washer system installed
ma ima sigurnoScuderia napisao:Mozda jednostavno nema prskalice.
Koliko sam ja shvatio, standard je:
Dnevna - LED
Kratka - LED
Duga - Halogena
Doplata:
Full LED
Pa onda nema ni razloga za prskalice.
Dnevna - LED
Kratka - LED
Duga - Halogena
Doplata:
Full LED
Re: AW: Mercedes E facelift
Malopre pored mene na parkingu E63 AMG FL. Izgleda odlicno ali meni je duplo jeftiniji CLS atraktivniji
Gesendet von meinem GT-N7000 mit Tapatalk 2
- methane.master
- Postovi: 21561
Koliko se secam, kod facelift E klase nema Xenona, standardno idu halogena a uz doplatu ide LED. I istina je da LED farovi nemaju prskalice, nema ni novi S:
Halogen
LED
Halogen
LED
Poslednja izmena od HKS u 11 Apr 2013, 23:29, izmenjeno 1 put ukupno.
Nema veze...zadovoljio bih se sa 350 CDImethane.master napisao:Ali taj CLS nije 63 AMG
- Postovi: 25130
Evo, evo:Laki021 napisao:Tako je, necemo dozvoliti da cvrsti materijalni dokazi stanu na put nasim ubedjenjima
E-Class facelift has no headlight washers?
by Markus Jordan | December 17, 2012
Ever notice that the facelifted E-Class has no built-in headlight washers, which were previously used with Xenons? We asked Mercedes-Benz - and received corresponding information.
According to the makers, the omission of a headlight cleaning system is not due to the "2000 lumens limit". Above this value currently for xenon lights automatic headlamp leveling and headlight washers are required. For LED headlamps this does not apply.
The headlight washers serve to reduce glare for oncoming traffic caused by dirt. "Recent studies show that the effect of the headlamp cleaning system has both positive and negative effects on the glare. So that the use of a headlamp cleaning system for the purposes of road safety is questionable," according to a spokesperson for Mercedes-Benz.
"The elimination of the headlamp cleaning system also represents a weight saving, with a full tank of up to 6 kg. Thus a CO2 saving of about 0.5 g/km is achieved. Therefore, we have decided in terms of sustainable environmental and economic vehicle operation to delete the headlight washer system."
Regardless, MB also saves on the cost of production, and fewer parts have to be stocked - which also may be one of the main reasons for the omission of the headlight washers. This option will no longer be available with the facelift of the E-Class (W212 sedan / S212 wagon / C207 coupe / A207 cabriolet).
http://blog.mercedes-benz-passion.com
E sto bi voleo da vidim vlasnika E FLa kako objasnjava nasem panduru zbog cega nema prskalice
LED? Jel se to maze na leba?
- nuk
- Postovi: 7607
- Lokacija: Ns
sto, dovoljno je da odstampa ovaj tekst I lupi neki pecat
Sent from my BlackBerry using Tapatalk
- methane.master
- Postovi: 21561
Pravi si gastos. Da ima "nišan" i da je dizla.Floyd napisao:Nema veze...zadovoljio bih se sa 350 CDImethane.master napisao:Ali taj CLS nije 63 AMG![]()
Ja bi AMG-a pa nek ide život. Ionako bih celu godinu štedeo za registraciju i jedan rezerovar, al bih onda napravio džumbus i narednih 12 meseci čekao da mi vrate dozvolu. Taman da opet uštedim za registraciju i gorivo i onda opet u krug.
Jel može E63 da se uzme sa zadnjim spojlerom u boji auta a ne onim odvratnim karbonskim?
