Ferrari - Opsta tema
Re: Ferrari - Opsta tema
https://www.youtube.com/watch?v=5zy01OpUwEs
ROCK
Postovi: 2735
Garaža: BMW F30 328i
Lokacija: CH
Post od ROCK »
Poente bez. Divljanje na uatoputu gde moze da se napravi samo tako lancana katastrofa
Bolje da ga spicio po krivinama uz brdo gde malo treba i znanja a ne gas do poda na AP i moli Boga da se ne skucas u neku cisternu :D
Budala!
Sent from my SM-G955F using Tapatalk
Ralee
Postovi: 3505
Post od Ralee »
https://www.youtube.com/watch?v=OttmzcD85DU
Postovi: 28267
Prelep auto, jedna od najlepsih zadnjica u autoindustriji :doubleup:
https://www.youtube.com/watch?v=NSB7duF5rbc
https://youtu.be/NE7GTW9NAZA
Danas sam video neki Ferrari koji uopste ne liči na Ferrari. Mator je, kraj 80tih bih rekao, početak 90te. Šta može da bude to?
Našo... Liči ipak...308gtb
mića
Postovi: 2217
Garaža: Corolla
Lokacija: beograd
Post od mića »
Vidi ovde koji je, ovako napamet ko ce ga znati Slika
http://m.ranker.com/list/full-list-of-f ... /reference
Gesendet von meinem VTR-L29 mit Tapatalk
Našo ga u oglasima
milospinkfloyd
Postovi: 2015
Lokacija: subotica
Post od milospinkfloyd »
jel ladno niko ne pise za naslednika kalifornije? Zove se Portofino (kao IWC sat)
The Ferrari Portofino is the new V8 GT set to dominate its segment thanks to a perfect combination of sportiness, elegance and on board comfort.
Ferrari has chosen a particularly evocative moniker for this exceptionally versatile drop-top car, referencing one of Italy's most beautiful towns. Portofino is renowned for its charming tourist port and, over the years, has become internationally synonymous with elegance, sportiness and understated luxury. The launch colour of the new Ferrari has also been dedicated to this marvellous town: Rosso Portofino.
Capable of unleashing a massive 600 cv and sprinting from 0 to 100 km/h in just 3.5 seconds, the Ferrari Portofino is the most powerful convertible to combine the advantages of a retractable hard top, a roomy boot and generous cockpit space plus two rear seats suitable for short trips.
The Ferrari Portofino's all-new chassis features a significant weight saving over the California T it replaces. Thanks to the extensive use of modern production technologies, all the chassis and body-in-white components have been redesigned with a consequent reduction in weight despite an increase in torsional rigidity.
Engine
The renowned Ferrari V8 turbo, part of the engine family that was nominated International Engine of the Year in both 2016 and 2017, now punches out 40 cv more than the California T's power unit thanks to the adoption of new components and specific calibration of the engine management software. The characteristic Ferrari V8 soundtrack has also been further enhanced and can be fully appreciated, particularly in top-down driving.
All aspects of the 8-cylinder's efficiency have been honed with the adoption of new pistons and con-rods, and a new intake system design. The geometries throughout the exhaust system have also been revolutionised. The new one-piece-cast exhaust header reduces losses, an important factor in ensuring Ferrari's characteristic throttle response with zero turbo lag. These improvements, combined with the Variable Boost Management which adjusts torque delivery to suit the gear selected, enable the Ferrari Portofino to offer even higher levels of acceleration in all gears and lower fuel consumption compared to the outgoing model.
Vehicle dynamics
The Ferrari Portofino's vehicle dynamic characteristics have been completely revised and benefit from the introduction of new technological solutions. For the first time on this type of Ferrari model, the third generation electronic rear differential (E-Diff3) has been adopted and integrated with the F1-Trac, improving both mechanical grip and the control of the car on the limit. The Ferrari Portofino is also the first GT in the range to be fitted with EPS (Electric Power Steering). This allowed the engineers to reduce the steering ratio by seven per cent for even more responsive steering without a trade-off in stability thanks to the integration with the E-Diff3. The magnetorheological damping system (SCM-E) has been uprated with dual-coil technology which helps reduce roll while simultaneously improving absorption of road surface unevenness. The result is an even more dynamic, responsive car that also delivers superior ride comfort.
Design & Aerodynamics
The Ferrari Design Centre-penned Ferrari Portofino is an aggressively-styled car with a two-box fastback configuration - unprecedented in a coupé-convertible with a retractable hard top - that adds extra sleekness to its silhouette, lending it a sportier character without impinging on its elegance and dynamism.
Close collaboration between the Aerodynamics department and Ferrari Design has ensured maximum efficiency in the development of the surface treatment. Starting with the front, the form of the large radiator grille opening, that stretches from edge to edge of the carefully contoured nose, is underscored by a new full-LED headlight assembly with a more horizontal shape. The outside edge of the headlight hides an innovative air intake which vents into the front wheelarch and exits along the flank to reduce drag.
The tail design underlines the car's sporty stance which has been further enhanced by placing the tail lights futher apart. This elegant solution cleverly conceals the rear volume housing the all-new RHT which features a more lightweight design and can be raised or lowered at low speeds.
Comfort on board
There was also a particular focus on board comfort which is guaranteed by a slew of new features, not least an infotainment system with 10.2" touchscreen display, a new air-conditioning system that improves occupant comfort both with the top up or down, a new steering wheel, 18-way electrically adjustable seats with a new backrest design that boosts legroom for rear seat passengers, and the passenger display. All occupants will particularly appreciate the new wind deflector which, when the top is dropped, cuts air flow inside the cabin by 30% and also reduces aerodynamic noise.
The Ferrari Portofino will make its world debut at the 2017 Frankfurt International Motor Show.
Technical Specifications
Engine
Type: V8 - 90°
Overall displacement: 3855 cm3
Maximum power output: 441 kW (600 cv) at 7500 rpm
Maximum torque: 760 Nm from 3000 to 5250 rpm
Weight and Dimensions
Length: 4586 mm
Width: 1938 mm
Height: 1318 mm
Weight distribution: 46-54% (front/rear)
Performance
Top speed: >320 km/h
0-100 km/h: 3.5 sec
Fuel consumption and CO2 emissions
Fuel consumption: 10.5 l/100 km
Emissions: 245g CO2/km
Postovi: 22127
milospinkfloyd
Postovi: 2015
Lokacija: subotica
:delete: konj ne gledam..
Kornjaca Rade
Postovi: 3990
Lokacija: Bg
Post od Kornjaca Rade »
https://youtu.be/6C_7LKrQkOY
Postovi: 49170
https://youtu.be/fTaP6YzESbk
gazza
Postovi: 2781
Lokacija: Vracar/Limnos
Post od gazza »
Pero Antic, novi centar KKCZ se u Beograd iz Istanbula dovezao u Ferariju :mrgreen:
