Mobilne telekomunikacije
Ralee
Postovi: 3505
Re: Mobilne telekomunikacije
Post od Ralee »
:thumbup:
havijer
Postovi: 3115
Garaža: I30 mk1 1,4
Lokacija: Kragujevac/GM
Post od havijer »
Samsung Galaxy S7 vs S7 Edge: Camera
Samsung Galaxy S7: 12-megapixel, phase detection, Dual Pixels, OIS, f/1.7 lens, 1/2.6″ sensor, 1.4 µm pixel, 4K video, 5-megapixel front camera
Samsung Galaxy S7 Edge: 12-megapixel, phase detection, Dual Pixels, OIS, f/1.7 lens, 1/2.6″ sensor, 1.4 µm pixel, 4K video, 5-megapixel front camera
Again, the cameras offered in these two phones are absolutely identical. Do you hear that, Apple? No annoyingly dropped OIS for the smaller model here.
Samsung has pared back the pixel count from 16-megapixels to 12-megapixels for the Galaxy S7 and Galaxy S7 Edge cameras, but the sensor itself is the same size as before – 1/2.6″. This allows the pixels to be larger – a pretty hefty 1.4 µm.
Bigger pixels means more light and better low-light performance – something that’s assisted by a bright f/1.7 lens.
Both cameras also benefit from Dual Pixel technology, which means that autofocus is among the fastest of any smartphone.
Again, both cameras identical, which means that both take some of the best pictures of any phone.
http://www.trustedreviews.com/opinion/s ... ge-2946826
Postovi: 28267
Rale je pitao A8 ili Edge, ne vidim kakve veze ima poredjenje S7 i S7e sa time?
havijer
Postovi: 3115
Garaža: I30 mk1 1,4
Post od havijer »
Greška. Videh ovaj post pa sam se prebacio :)
maxer napisao:Pa S7, bilo običan ili Edgle, nema tu nikakve dileme :zbunjen:
Postovi: 13803
S7 edge pravi odlične fotke.
Raki_Audi
Postovi: 1292
Post od Raki_Audi »
I phone X ili Samsung S9 plus? Po prvi put me odusevljavaju oba telefona svaki na svoj nacin. l da stvarno ne znam koji da odaberem? Moze pomoc ? :zbunjen:
carov2
Postovi: 5319
Garaža: Audi A4
Lokacija: Pirot, Kladovo
Post od carov2 »
U istoj sam dilemi, ali ću verovatno iPhone...
Koji telefon sada koristiš?
Dani
Postovi: 654
Pridružio se: 26 Okt 2014, 02:41
Garaža: BMW F10 530d
Post od Dani »
Ja ozbiljno razmisljam o prelasku na IP, iako bas ni jedan problem nisam imao sa Samsungom.
maxer
Postovi: 6672
Lokacija: Zaječar
Post od maxer »
@Raki_Audi
Za toko skupe sprave, moraš sam da odlučuješ i nema razloga da pitaš druge jer je to sve stvar ličnog ukusa, pošto su sve te sprave vrh-vrhova i razlike se svode na jedna malo bolja ovde ali malo gora onde ... i tako u krug. Kad potreš te +/- oscilacije, ostaje znak = tj. nema tu nikakve razlike.
Uzmi onaj što te više privlači dok radiš sa njme a ako te oba privlače, pa stavi ih ispred sebe i kreni: Eci - peci - pec, ti si - mali - zec, ti is - mala - prepelica, eci - peci - PEC :o ... e, tebe neću da kupim, oću ovaj drugi :kezo: (možda nemaš pojma o čemu pričam, ali lako ćeš se raspitati kod svojih roditelja, oni sigurno znaju :)).
Postovi: 28267
S9+ ima dosta prednosti, kao sto je dosta veci ekran, sa vecom rezolucijom, bolje kamere, 30% jaca baterija, USB 3.1 type-c, ima 6GB rama, u odnosu na Iphone-ovih 3GB...ako ti je to bitno.
Ako nije, odes do prodavnice, pogledas i probas oba, te odlucis.
Mene uzasno nervira izbacena kamera na Iphone X.
Uzeo sam od drugara da cackam i to mi je bas smetalo.
Da se neki od ta 2 fona nesto specijalno izdvaja dizajnom i da me je odusevio, mozda bih i dao neki konkretan odgovor, a ovako, bukvalno uzmi koji ti vise bude prijao u ruci i ako ti je dovoljno jaka baterija na X.
maxer
Postovi: 6672
Lokacija: Zaječar
Post od maxer »
Eto, vidiš kako je nekima lako da se odluče: 50% bolji ... il beše 30? :think: ... ma nema veze, oću Samsung :sreckovic: :kezo:
Postovi: 28267
Ja mislim da sam daleko objektivniji od tebe, koji konstantno preporucujes jedan od najprecenjenijih brendova telefona danas.
Moje misljenje je potkrepljeno nekim cinjenicama i validnim razlozima, za razliku od tvog.
A i nisam napadan sa svojim misljenjem poput tebe, da sada kacim 101 test i slike i da posebno editujem post sa boldovanjem i podvlacenjem, vec samo kazem moje misljenje i neke detalje.
Ovde nista nisam preporucio, nego su cinjenice da je sve sto sam naveo, bolje na S9+, a neke stvari nisam ni naveo, a na njemu je da odluci da li mu je to bitno.
Ja da se lozim na Samsung, do sada bih imao i S8, koji mi je drugar iz DE maltene poklanjao, a i S9.
Ni jedan od ta 2 mi nije vredan menjanja S7e, niti me je odusevio, a kada nesto bude vredno, pazaricu.
Telefoni do sada u poslednjih par godina su mi bili: HTC One, Nokia 930, Sony Z3, Samsung S7e.
A i iskreno, mene telefoni ni ne zanimaju preterano, da bih se na nesto tu posebno lozio.
Zapravo, verovatno bih licno da sada biram, izabrao X, da nema onog odvratnog ispupcenja kamere, koji mi je bas skakao po zivcima, a ni S7e ne bih kupio, da Iphone 7+ nije bio cigletina koju nisam mogao da drzim u ruci.
maxer
Postovi: 6672
Lokacija: Zaječar
Post od maxer »
Ajd sve na stranu, pošto se slažemo - da se ne slažemo (što bi rekli političari danas), ali mi je za oko zapalo ovo procenjivanje da je 30% bolji ... da je 50% bolji (iz G6 rasprave) ... to uz kombinaciju autoritativnog nastupa (ja sve znam), meni je iskreno - vrlo zabavno :mrgreen:
Mnogo bre ozbiljno shvataš neke stvari ... skoro pa ko Ogi - put za Nemačku :mrgreen:
Postovi: 28267
Ne znam gde si osetio moju autoritarnost, ali nigde nikome nisam nista naredjivao, niti cak govorio sta da urade.
Ili mozda ne znas znacanje te reci, a hteo si da kazes da nadmeno pricam, sto opet nije slucaj, jer prosto iznosim cinjenice, uz malo mog misljenja.
Nigde nisam ni napisao koliko je S8 bolji od G6 procentualno, nego ti selektivno pamtis, pa kada ti se ne svidjaju cinjenice koje sam ja istakao, onda to sklopis u neku svoju pricu.
Procesor u S8 je 50% jaci od onog u G6, kako sam i rekao, a to nisam ja procenio, nego rezultati testova, koji su 50% bolji.
Isto kao sto sada nisam procenio da S9 ima 30% vecu bateriju, nego je zaista 30% veca.
U G6 "raspravi", gde nismo nista raspravljali, ti si sam trazio dokaze, a ja ti naveo cinjenice koje si mogao i sam da proveris sa 3 klika, a nista nisam napisao u fazonu "ja znam", osim da mi se ne svidja softver, za koji si i ti sam napisao da se vecini ne svidja.
A onda me posle prozivas, jer sam odgovorio na tvoj post, na najnormalniji moguci nacin.
To sto odgovaram opsirnije i preciznije nego sto si ti navikao, ne znaci da icemu odavde dajem neki znacaj i da ozbiljno shvatam.
Ti daleko ozbiljnije od mene sve ovde shvatas i daleko vise te pogadja, cim ti se probudila potreba da me podjebavas, cim sam opet naveo sta je na nekom telefonu bolje od drugog.
S9 nisam do sada ni pogledao, dok Raki nije pitao, pa sam saznao specifikacije i pogledao poredjenje kamere i slicno, cisto razonode radi, a onda podelio, jer je to covek trazio.
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Ja držim telefon u case-u tako da mi ispupcenje ni na jednom mobu nije smetalo :D to je već stvar lične preferencije, nekima će biti mana nekima ne
Čačkao danas malo Mate 10 Pro, dobar je, malo veće dimenzije nego što bih želeo ali bih mogao da se naviknem. Ekran dobar. Kamera glavna je vrh, baš dobre slike prave. Selfie je sranje, ima neko veštačko ulepšavanje ali ne radi bas lepo, pa razmazuje ivice lica,to bi trebalo isključiti. Za 550e koliko su po oglasima nema bolje kupovine ja mislim
