Formula 1 - sezona 2014
Formula 1, WRC, Moto GP i ostalo
Postovi: 24880
Re: Formula 1 - sezona 2014
Povlace ih iz trke namerno da bi sacuvali motore i menjace za sledece trke, iako bi recimo mogao da zavrsi trku, ali na nekoj losijoj poziciji, ne nuzno zato sto ce se nesto ostetiti.
The power unit is deemed to consist of six separate elements, of which five of each are available to each driver per season before they are penalised. The elements are the engine, the motor generator unit-kinetic (MGU-K), the motor generator unit-heat (MGU-H), the energy store (ES), turbocharger (TC) and control electronics (CE). Should a driver use more than five of any one component he faces a penalty ranging from a five-place grid drop, a 10-place grid drop, or (if the entire power unit has to be changed) starting the race from the pit lane.
Gearbox ratios are fixed for the season (for 2014 only they may be changed once), but teams may change gears or dog rings at any time during an event providing that the FIA technical delegate is satisfied that there is physical damage to the parts in question.
Postovi: 24880
Postovi: 48637
Kako zvuče bolidi na startu.
http://www.youtube.com/watch?v=ZCkbuhNJXns
samo polako
Postovi: 3361
Post od samo polako »
Kakav smor ovo gledanje sa tribina formule 1. :kezo:
A još sad i zvuk :trljamoci:
Jel se to turbina čuje?
Šta je bre ovo?! Zvuk ko skuteri. :thumbdown:
@Samo polako
Jeste zviždi turbina.
Jack™
Postovi: 97
Pridružio se: 03 Mar 2014, 09:15
Garaža: Kia Rio Sport Sedan 1.2 85KS
Post od Jack™ »
Jako sam srecan sto sam dva puta bio na Hungaroringu i uzivo cuo stare motore, malo i ogluveo ali bilo je neprocenjivo.
Taj adrenalin koji sam osetio kad su 22 automobila startovala u zivotu nisam osetio... Ta buka... Ludnica...
AcaKayak
Postovi: 4865
Post od AcaKayak »
+1
Jack™
Postovi: 97
Post od Jack™ »
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
Ma resice to u svom fazonu, ugradice zvucnike koji ce se paliti u svakom sedmom krugu, a posebni poeni bice dodeljeni od publike za akusticni ugodjaj svakog bolida...
Stvarno prave od F1 sve suprotno od onoga sto treba da bude, nadam se da ce se Berni sto pre penzionisati...
Poceli su da gube dobrano na popularnosti i trebalo je nesto izmeniti, ali ovo je potpuno pogresan pravac/smer i blago receno tragikomedija... :glavomuzid:
AcaKayak
Postovi: 4865
Post od AcaKayak »
+1
Aca BG
Postovi: 1965
Post od Aca BG »
+1 katastrofa na sta je spala F1
Re: AW: Formula 1 - sezona 2014
Samo se prilagodjavaju trendovima u auto industriji :)
Delija napisao:Poceli su da gube dobrano na popularnosti i trebalo je nesto izmeniti, ali ovo je potpuno pogresan pravac/smer i blago receno tragikomedija... :glavomuzid:
Pa kad vide da je 50k ljudi na trci umesto 250k, obrnuce sve i vratiti na pravo trkanje.
Cela prica, od usporavanja bolida zbog sigurnosti do je*ene ekologije je smesna.
Kao da treba da uspore borbene avione, da ne lete iznad 1 maha, jer je bezbednije :kuku: Ti momci ne sedaju u bolid da bi brali ljubicice nego da bi se trkali i svesni su rizika.
Ne bih se ja tako sprdao sa ekologijom. Pogledajte stanje u Parizu i mere koje vlasti preduzimaju ;)
Ono, tacno je da sama formula 1 ne pravi neku veliku stetu na globalnom novou ali ne treba se saliti sa ekologijom.
