Reducing or increasing font size across whole document
There are built-in commands for this. The Grow Font and Shrink Font commands
are assigned the default shortcuts Ctrl+ and Ctrl+ and these will increase
or decrease the size of each character to the next/previous size on the font
size dropdown. The Grow Font One Point and Shrink Font One Point commands
are assigned the default shortcuts Ctrl+] and Ctrl+[ and these will increase
or decrease the size by one point at a time.
If different parts of the selected text have different sizes, they'll be
affected separately. For example, if you have selected some text in 8 pt and
some in 14 pt, and you apply Grow Font to the whole selection, the pieces
become 9 pt and 16 pt respectively.
For your request, just select the whole document (Ctrl+A) and then press the
appropriate shortcut.
Računari
- methane.master
- Postovi: 21561
Re: Računari
Koji sam ja pajser, mislio sam skroz nešto drugo. Tako je Grujo.
Re: Računari
Ljudi kako snimiti na hard nešto što ide preko live stream-a?
Re: Računari
Zvuk?
Re: Računari
I slika i ton.
- Delija
- Postovi: 18946
Re: Računari
Koristis VLC Media Player.
Re: Računari
Ali kako kad nemam adresu? Imam na sajtu stream iz koga ne znam kako da izvučem adresu koju bih ubacio u VLC.
- Delija
- Postovi: 18946
Re: Računari
Mozda moze da se provali iz "source-a" strane.
Brute force metoda bi bila snimanje svega onoga sto vidis na ekranu PC-a.
Re: Računari
Aj ti probaj. Treba mi da snmim vesti sa http://balkans.aljazeera.net/
- Delija
- Postovi: 18946
Re: Računari
Probacu da vidim sta moze.
- Postovi: 25052
Re: Računari
Camtasia recorder, sad sam proverio-radi.
- Delija
- Postovi: 18946
Re: Računari
Brute force metoda radi sigurno - za to postoji gomila programa.
Probao sam da iscupam stream i nalaze snooper-i neke RTMP-ove, ali nisam uspeo da ih iskoristim. Probacu jos malo dok se ne smorim
Re: Računari
Instaliram ovo čudo što je Dragovorl preporučio. Nemoj da se mučiš.
- Delija
- Postovi: 18946
Re: Računari
To ti je obican screen (video) capture iliti snima video na osnovu onoga sto ti je na ekranu racunara.
Bas me sad nervira sto nece da se igra sa mnom...
- Postovi: 25052
Re: Računari
Podesis area na custom ako hoces u manjem prozoru od full screena da snimas i podesi kompresiju i format, jer hoce da ispadnu jako veliki fajlovi.
