VW Golf VII
Postovi: 49239
Re: VW Golf VII
The new Golf measures 4,255mm (167.5-inches) in length, 1799mm (70.8-inches) in width and 1452mm (57.2-inches) in height, making it 56mm (2.2-in.) longer and 13mm (0.5-in.) wider but also 28mm (1.1-in.) lower than the current model. It also rides on a 59mm (2.3-in) longer wheelbase and wider front (8mm / 0.3-in.) and rear (6mm / 0.2-in) tracks.
All this results to a more spacious interior with the cabin length increased by 14mm (0.6-in.) to 1,750mm (68.9-in.), rear legroom by 15mm (0.6-in.), and front and rear shoulder room by 31mm and 30mm (1.2-in.) respectively, while the boot area has been boosted by 30 liters for a total of 380 liters.
Even though it has a larger footprint than the Golf Mk6, the German firm's compact model is up to 100kg (220 pounds) lighter than its predecessor.
According to VW, among other savings, 3kg (6.6 lbs) were shaved from the new electrical wiring, 12kg (26.5 lbs) from the equipment features, 26kg (57.3 lbs) from the aluminum components in the chassis and 38kg (83.8 lbs) from the new body, bringing the base model's curb weight down to 1,050kg (2,315 pounds).
As a direct result of the weight savings, VW says that fuel consumption has been reduced by an average of 13.9 percent across the range with some versions boasting up to 23 percent savings.
VW has yet to fully open its cards about the available engine range but it did confirm a new generation of three- and four-cylinder turbo diesels, along with an entry-level 1.2-liter TSI petrol and the new EA211 turbocharged 1.4-litre four-cylinder direct injection petrol unit with cylinder deactivation that produces 138hp (140PS).
When combined with a seven speed dual clutch gearbox, the 1.4 TSI EA211 is said to return 4.8lt/100km (58.9mpg UK or 49mpg) on the combined European consumption cycle with CO2 emissions of 112g/km.
According to Autocar magazine, VW will also preview the GTI version of the Golf Mk7 equipped with a new 222hp (225PS) 2.0-liter turbocharged petrol (EA888) at the Paris Motor Show, though this is something that we have yet to confirm.
Postovi: 49239
Re: VW Golf VII
Mislim da ova još nije bila.
7footer
Postovi: 628
Pridružio se: 19 Jan 2012, 17:53
Garaža: Lexus GS 450h, Chevrolet Trax, Yamaha Stryker
Lokacija: Svet
Re: VW Golf VII
Post od 7footer »
Мени се допада
Pozdrav
Scuderia
Postovi: 13495
Re: VW Golf VII
Post od Scuderia »
Geza napisao:Slika
:mrgreen:
ZAXSPEED
Postovi: 216
Pridružio se: 26 Jan 2012, 16:43
Garaža: Passat B7 , Clio IV 1.5 dci
Re: VW Golf VII
Post od ZAXSPEED »
Prednji kraj odličan, zadnji :srbin: :kuku: :kuku:
Re: VW Golf VII
Trudim se da uocim razliku prednjeg dela u odnosu na 6icu ali ne uspevam...osim sto primecujem da su farovi sa ostrijim uglovima.
Ne znam, meni se vise razlikuje W204 stari i FL od ovog i 6ice.
Nadam se da od pozadi nece biti ovakav.
Postovi: 14343
Re: VW Golf VII
Meni se baš razlikuje. Kad gledam šesticu i dalje vidim svoj auto koji ima promenjene farove i drugi branik, dok se kod sedmice baš vidi da je drugi automobil. A što se tiče zadnjeg dela mislim da je bolje sačekati da izađe bolja slika
Postovi: 49239
Re: VW Golf VII
Postovi: 49239
Re: VW Golf VII
Dusan
Postovi: 4285
Lokacija: Wien
Re: VW Golf VII
Post od Dusan »
Ovo je blago izmenjeni 6? :trljamoci:
Re: VW Golf VII
Rekoh ja...
Floyd napisao:Trudim se da uocim razliku prednjeg dela u odnosu na 6icu ali ne uspevam...osim sto primecujem da su farovi sa ostrijim uglovima.
Inace, u internet izdanju gore pomenutog casopisa citam da ce novi R imati 280ks.
Bio sam siguran da nece stici i preskociti 300ks ;)
Dusan
Postovi: 4285
Lokacija: Wien
Re: VW Golf VII
Post od Dusan »
Zvucis kao da si upravo dobio informaciju iz vrha VWa snazi. :kezo:
Ne verujem da ce 7 ovako izgledati, samim tim ne verujem ni u tacnost te informacije. :)
Ako je VW uspeo da sakrije izgled do same premijere, ne vidim zasto ne bi uspeli i informaciju o snazi R-a. ;)
Poslednja izmena od Dusan u 29 Avg 2012, 21:51, izmenjeno 1 put ukupno.
Postovi: 11473
Re: VW Golf VII
Izgleda da će se nastaviti moja stara tradicija da mi se neparni Golfovi sviđaju, a parni su mi dosadni i ružni.
Re: VW Golf VII
Dusan napisao:Zvucis kao da si upravo dobio informaciju iz vrha VWa snazi. :kezo:
http://www.auto-motor-und-sport.de/news ... 25256.html
Angetrieben werden beide Modelle vom Vierzylinder-2,0-Liter-Turbobenziner, der in der R-Version des VW Golf 7 280 PS auf die Kurbelwelle stemmen wird.
starac vujadin napisao:Izgleda da će se nastaviti moja stara tradicija da mi se neparni Golfovi sviđaju, a parni su mi dosadni i ružni.
Pa ako je tradicija u pitanju onda je red da se nastavi...hebes sve ostalo, tradicija se treba postovati :mrgreen:
Dusan
Postovi: 4285
Lokacija: Wien
Re: VW Golf VII
Post od Dusan »
Od kad se Vagen zvanicno oglasava preko novina i to minimum godinu dana unapred?
