BMW 5 (G30) 2017
Milos
Postovi: 9276
Garaža: tedeijevi geteijevi
Re: BMW 5 (G30) 2017
Post od Milos »
Odlican auto.
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
https://youtu.be/i9HvFJDmsBk
https://youtu.be/evlYfL0xryg
https://youtu.be/Wqmfi4aCd9Q
swemir
Postovi: 3886
Post od swemir »
Mene zanima Koja je razlika izmedju dva adaptivna, osim da su uz jedno ubacili 4 control maznut od reshoa. :) sta se jos razlikuje?
I za koja trzista se sklapa u Gracu?
Послато са SM-J510FN уз помоћ Тапатока
Laki kakva svojstva guma ima na 40c, a kakva na 25?
Kornjaca Rade
Postovi: 3988
Lokacija: Bg
Post od Kornjaca Rade »
swemir napisao:Mene zanima Koja je razlika izmedju dva adaptivna, osim da su uz jedno ubacili 4 control maznut od reshoa. :) sta se jos razlikuje?
Postoji Adaptive Drive koji ukljucuje Dynamic Damper Control i Dynamic Drive a postoji posebno samo Dynamic Damper Control. Samo sa ovim drugim moze da se uzme 4ws.
Adaptive Drive includes Dynamic Damper Control and Dynamic Drive. With the Dynamic Damper Control the characteristic of the shock absorbers can be adapted individually. The COMFORT, ECO PRO, SPORT and ADAPTIVE modes are available via the driver's joystick. The shock absorbers are adjusted by means of an active system via a continuous adjustment of the tension and compression stages of the dampers. Dynamic Drive reduces the rolling movements of the vehicle by means of active stabilizers on the front and rear axle to a minimum. Dynamic Drive thus increases vehicle stability as a function of the driving situation. As a result of the reduced lateral inclination, the travel comfort which increases the rearward travel, e.g. Also children in the rear on longer motorcars. Your advantages: Maximum comfort and best driving safety; Individual program selection; Constantly good vibrational properties; Reduction of rolling movements; High agility and minimization of side inclination
Poslednja izmena od Kornjaca Rade u 04 Mar 2017, 09:13, izmenjeno 1 put ukupno.
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Ivan
Postovi: 9932
Garaža: bmw 3 f31, bmw 5 f10,
Post od Ivan »
http://youtu.be/DMXjC5ytuaY
nikolasbg96
Postovi: 46
Pridružio se: 15 Apr 2016, 19:20
Garaža: F30 316d, Superb '18 1.4 TSI
Lokacija: Bgd
Post od nikolasbg96 »
Danas sam sedeo u crnom. Spolja lep i skladan iz svih uglova za razliku od f30, ali nista novo i uzbudljivo u dizajnu. Unutra bas mocan s tim da je bila neka crna plastika i vec se vide ogrebotine na suncu
Postovi: 49161
BMW Series 5 Touring M Performance package
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Volan u ovoj verziji izgleda ekstra
Postovi: 22123
Škodine felne su legle odlično.
Pffff... Ni ne lici na tvoj cvetni aranzman :)
Postovi: 22123
Ma ne moje.
Postovi: 8072
Ne znam da li liče, ali su odvratne...
Samo podsecaju, onako izdaleka :pardon:
Poslednja izmena od Delija u 06 Mar 2017, 23:21, izmenjeno 1 put ukupno.
