Biciklizam
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
paja napisao:Da limit je 6,8 min. Pitanje je koji je bio motiv za postavljanje granice, da li bezbednost ili želja da se svima omoguće isti uslovi.
Danas je jako lako (uz puno para) sklopiti bicikl koji je lakši od tih 6.8 kg. Ram sa viljuškom, šticnom i koje čime još bez problema biva do 1,5 kg, točkovi sa gumama daleko ispod 1,5 kg, mehanika takođe ispod 1,5 kg. Tako da postoji jako veliki prostor da se voze npr teški točkovi jer su Shimano koji je sponzor, a ne npr Mavic koji je laši 300g i sl.
Elektronska grupa je osetno teža od mehaničke pa je većina vozi.
6.8 is one of those numeric constants that every cyclist is familiar with. It refers to the 6.8 kilogram minimum weight limit set by the UCI which restricts all bikes used in competition to this weight. This regulation was established in 2000 as a means to ensure manufacturers don’t push the structural integrity of bikes and so that teams are competing on a relatively similar machines.
...This specialist, with the advice of other experts, has defined that 6,8Kg is the minimum weight acceptable for a bicycle, for an essential reason that is the manoeuvrability of the bicycle. Of course, technical risks related to composites materials have also been considered, but the primary reason of this rule is the manoeuvrability...
...We are aware that technology and materials evolve, and it would be comprehensible to think today that from a technical point of view, this weight limit could be lowered. But we have no assurance that bicycles of 6Kg (for example) are safe. We have in our Equipment Commission an engineer specialist of cycling, who worked for many manufacturers and who have designed several bicycles that are still in the peloton. This engineer expert in composite materials is not completely convinced of the reliability and strength of the bicycles weighing about 6Kg. We know that some bicycles of less than 6,8 Kg are commercialized and that some manufacturers think they are safe. We also have feedbacks from many other manufacturers who don’t think the same thing, and who advise us to leave this 6,8Kg weight limit, because this limit is very accurate and that it prevents an unreasonable race to the minimum weight...
http://cyclingtips.com.au/2013/08/the-6-8kg-limit/
Na Djiru 2004, trkaci koji su vozili Kenjce, lepili su tegove na gornju cev da bi otezali bicikle a sto je ujedno bila i svojevrsna reklamna kampanja.
Re: Biciklizam
Slikaj je super!
Regulativa o 6,8 kg je definitivno zastarela. Od 2000. do danas se promenilo puno toga u biciklizmu. Moj bicikl koji je sve samo ne krhki drumaš i koji nema ni jednu ultra lihgt komponentu, osim možda sedišta, bi promenom točkova otišao ispod 6.8 kg.
Da ponovim i ovde ono što smo diskutovali. Ne vidim poentu diskova na drumašima.
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
:thumbup:
Postovi: 11444
Re: Biciklizam
...i najneizvesniji i najnapetiji završetak ikad...da li je odelo i bicikl pobedilo?
http://www.youtube.com/watch?v=rWyfb3H7LEg
Postovi: 12166
Re: Biciklizam
Uzeo sam neke Corratec paknove, kao malo kvalitetnije.
BAJKER
Postovi: 6086
Re: Biciklizam
Post od BAJKER »
U Novom Sadu javni štand za popravku bicikala -- 19.11.2013
Kako kažu i sami konstruktori javnog štanda za popravku bicikala, dostupan je 24 sata dnevno na Ribljoj pijaci u Novom Sadu, a napravili su ga mladi i mlade Novog Sada za široke narodne mase na biciklima.
Ljubitelji bicikala okupljeni oko građanske grupe Novosadska biciklistička inicijativa realizacijom ovog interesantnog projekta obezbedili su svim posetiocima Riblje pijace u Novom Sadu mesto za popravku bicikla koje mogu besplatno da koriste.
Motiv cele akcije je bilo ohrabrivanje i animiranje mladih u Novom Sadu, da na zanimljiv i maksimalno samostalan način utiču na oblikovanje grada u kom žive. Želeli smo da naš grad prati trendove svetske biciklističke infrastrukture i mislimo da smo u tome uspeli. Radionica je finansirana u saradnji sa Trag fondacijom (bivši Balkanski fond za lokalne inicijative), a JKP Tržnica je izašla u susret Novosadskoj biciklističkoj inicijativi i obezbedila lokaciju i postavljanje ovog štanda na Ribljoj pijaci. Štand za javnu popravku bicikala sastoji se od nosećeg stuba na koji se postavi bicikl, od nekoliko osnovnih alata koji vise na sajlama i stojeće ručne pumpe. Ohrabruje nas i što je Grad Novi Sad u okviru konkursa Gradske uprave za sport i omladinu prihvatio naš predlog projekta, pa ćemo videti još ovakvih štandova po gradu.
http://www.cikloberza.com/news.php?id=1142
swemir
Postovi: 3878
Re: Biciklizam
Post od swemir »
Jest sad kad su proterali one amere sto su besplatno popravljali biciklove... prozvali ih spijunima i sut karta iz srbije. A bila dobra fora . Sednes na kafu oni ti nasteluju bajs....podmazu i stave dve bubice za prisluskivanje..
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
Kupljen jako bitan deo opreme svakog bicikliste - vaga. Aluminijum 6061. Greska +- 1gr :mrgreen:
Re: Biciklizam
Neko se ozbiljno sprema da sklapa nov bicikl. :kezo:
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
Ne mogu stalno da dolazim kod tebe na merenje i konsultacije, vec nas cudno gledaju :dobarvic:
Re: Biciklizam
Ko? :kezo:
Proverio sam kad će se pojaviti viljuška. Pomerili su na 6. dcembar. Ostavio sam mail da me obaveste kad stigne.
Postovi: 32208
Re: Biciklizam
A tek što kruže priče...
Re: Biciklizam
Kakve priče? Onaj deo da nismo normali preskoči, to znamo i sami. :)
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
trojanac napisao:A tek što kruže priče...
Sa si reko? :palica:
zuzazu
Postovi: 4641
Re: Biciklizam
Post od zuzazu »
PAJOOOOOO! VAGAAAA :o
Al6061. Da je olaksamo malo? Bajker da je izbusi?
