Formula 1 - sezona 2014
Formula 1, WRC, Moto GP i ostalo
Postovi: 22133
Re: Formula 1 - sezona 2014
Isto je i u Le Mans, pa smo preživeli... Plus ovi motori tek imaju da pokažu šta znaju.
Tapatalk 4
Postovi: 15328
Zanimljiva tabela koja mi je iskocila na fbu.
Postovi: 49239
Drugi trening u Bahreinu, još sat vremena.
http://www.vipboxeu.co/motorsports/2171 ... nline.html
Postovi: 49239
Revealed: How Mercedes' packaging of their turbo engine has given them the edge
http://www1.skysports.com/f1/news/12472/9243875
W05's technical secrets disclosed with Sky Sports F1 analyst Mark Hughes revealing that Mercedes' dominant car is running with its turbo turbine and air compressor split
The Mercedes W05: The devil is in the detail?
The secret of Mercedes' current domination of F1's new turbo era has been made public after Sky Sports F1's Mark Hughes revealed intricate details of how the Silver Arrows are packaging the hitherto-dominant W05.
Sky F1 analyst Hughes has learnt that, in a highly complicated engineering feat, the team have successfully packaged their turbine and air compressor at either end of the W05's engine.
The innovative design - which, like the best ideas, sounds simple, is vastly complex and brilliantly effective - is believed to have been conceived over two years ago.
The revelation is also the best explanation yet for why the W05 has so far proved unbeatable in 2014, with Nico Rosberg's cruise to victory in Australia followed by Lewis Hamilton scoring F1's version of a hat-trick - pole position, the fastest lap of the race and victory - in Malaysia on Sunday.
Hughes has learnt that the Brackley team's ties with Mercedes High Performance Engines gave them a critical headstart at the start of F1's new turbo age.
Looking to achieve the most aerodynamically efficient car possible, the Mercedes team had significant influence over power unit design created at the German manufacturer's engine base in Brixworth.
Writing in Motorsport magazine, Hughes discloses that Mercedes' breakthrough 'innovation is having the turbo's compressor at one end of the engine and the turbine at the other, linked by a long shaft through the vee of the engine'.
The 'trick turbo layout' triggers a series of critical performance benefits. A reduction in turbo lag means less power needs to be be harvested from the car's ERS unit to keep the turbine spooled off throttle. That in turn improves the efficiency of the car, with more power reserved for performance gain and less fuel consequentially used up.
Mercedes' customer teams all have the same advantage. However, because McLaren, Williams and Force India only took delivery of their power units relatively recently, they have had less time to work the layout into their respective car designs.
But for the works outfit, the benefits of the W05's innovative layout has proved multifaceted.
With the compressor further away from the turbine - which is spun by hot exhaust gases - the W05 has a smaller intercooler, meaning Mercedes are running with smaller sidepods which boost aerodynamic performance.
Furthermore, with the compressor in front of the engine, Mercedes have also moved their car's gearbox forward, improving its centre of gravity and therefore, in theory, its handling.
But while Mercedes' rivals are aware of the championship leaders' secret, they are essentially powerless to react. The engines for 2014 are now in lock-down, with February 28 marking the agreed homologation date by which all the teams had to register their design for the new season with the governing body, the FIA.
The Mercedes power unit has been widely credited as being the critical performance differential in their victorious start to the new season. Red Bull boss Christian Horner claimed in Malaysia that his team was one second slower along the straights, with trackside observers estimating that the Mercedes unit boasts anything between 50 and 70 extra horsepower over the rest of the field.
Mercedes' domination continued on the track on Friday in practice for this weekend's Bahrain GP with Lewis Hamilton topping a Silver Arrows one-two in both of the day's sessions, one second clear of the distant chasing pack. So far this season, a Mercedes W05 has been quickest in fourteen of the sixteen track sessions.
Postovi: 49239
Williams :bravo: :bravo: :bravo:
FOrce India :bravo:
Ferrari :kuku:
Postovi: 32926
Jedna od boljih trka poslednjih nekoliko godina. Obožavam kad se timske kolege trkaju. Mercedesov motor za klasu bolji od ostalih. Videćemo šta sledi u nastavku sezone.
Tapatalk with Desire 500
Postovi: 49239
Postovi: 15328
Stvarno sjajna trka. Bravo za Hamiltona i Rozberga, navijao sam da pobesi Rozberg ali bilo je zanimljivo gledati borbe za prvo mesto. :bravo:
Sent from my ALCATEL ONE TOUCH IDOL using Tapatalk
Raki_Audi
Postovi: 1292
Post od Raki_Audi »
Hamilton razvalio
Najbolji je nema sta ...
Start, tempo, medium gume ... Sve ...
elMaestro
Postovi: 3897
Garaža: C2
Re: Одг: Formula 1 - sezona 2014
Post od elMaestro »
Svaka cast Mercedesu! Rozberg odlican, Hamilton isto. :bravo:
Perezu takodje svaka cast.
Svidelo mi se sto se Rikardo napao Fetela, prosle sezone ih je Veber slusao, on ih ne hebe ni 2%.
Jos jednom, prelepa trka za gledanje.
Имам једно потпитање...
jocas
Postovi: 2306
Lokacija: Niš
Post od jocas »
Postovi: 49239
Tri kazne za Maldonada.
10 sekundi kazne u boksu, 5 pozicija niže startno mesto na sledećim kvalifikacijama i 3 kaznena poena.
Postovi: 15328
Malo mi je nelogicno ovo oko nezgode, pa bih voleo da mi objasni neko ko je upucen u pravila i ovakve incidente. Maldonado je drzao unutrasnji deo krivine, Guti je isao sa spoljne strane i uleteo je u Maldonadovu putanju, zar nije trebao da drzi spoljni deo krivine i tako izbegne incident? Po meni je vise kriv Gutierez, ali nisam previse upucen u pravila pa zato pitam ovo.
Postovi: 22133
U pravu su sudije, ali kao po običaju u poslednje vreme uništavaju trke prestrogim kaznama.
Ono što je zanimljivo je videti na delu nove spuštene noseve. Teško je dati neki komentar na koji način doprinose bezbednosti kada ovako lansiraju drugi bolid u vis.
Sve u svemu odlična trka. Savršena trka za Mercedes i odličan duel. Takođe otkriva svim nevernim tomama koji su se javljali u ovoj temi veličajući vozače ispred bolida usled potpunog nepoznavanja auto sporta. U ovom sportu bolid je sve, a dobar vozač ne može da iskompenzuje spor bolid.
Tapatalk Pro
