Mozda ti je ovo interesantnije. Za start stop auta
"The bottom line is the AGMs can be recharged faster than other lead-acid type batteries."
Ili mozda ovo:
"If you're cruising and on the hook most of the time AGM's are the worst batteries as they will only last a season or two if they are not fully charged often. Most of the time on the hook it's difficult to fully charge batteries so you end up using the band between 50% and 85%. If you live in a marina or can fully charge them often they're fine. I went back to flooded batteries."
