Vazduhoplovi
zuzazu
Postovi: 4655
Re: Vazduhoplovi
Post od zuzazu »
:losevidim:
Postovi: 49067
Re: Vazduhoplovi
Chemtrails?
Postovi: 49067
Re: Vazduhoplovi
Postovi: 49067
Re: Vazduhoplovi
cozmo
Postovi: 5293
Garaža: Peugeot 307 1.6 HDI
Re: Vazduhoplovi
Post od cozmo »
BAJKER
Postovi: 6086
Re: Vazduhoplovi
Post od BAJKER »
Ovaj auto sto je parkiran, prilikom poletanja farba mu je ispeskirana za dz :mrgreen:
Postovi: 9331
Re: Vazduhoplovi
:kezo: :kezo: :kezo:
i onda prica o bezbednosti letenja :)
blaugrana
Postovi: 7447
Re: Vazduhoplovi
Post od blaugrana »
Al' ga spusti sofer :bravo: :)
Mozda na leto napravim ovakav jedan snimak :djavo:
Re: Vazduhoplovi
Samo nemoj da parkiraš kod ograde. :kezo:
Sent using Tapatalk
Postovi: 23571
Re: Vazduhoplovi
NE secam se da sam tu parkirao auto :kezo:
cozmo
Postovi: 5293
Re: Vazduhoplovi
Post od cozmo »
IR F100 Crashlanded, no Fatalities
http://avherald.com/h?article=4742ca4c&opt=0
An Iran Aseman Airlines Fokker 100, registration EP-ASZ performing flight EP-853 from Mashad to Zahedan (Iran) with 103 people on board, was on approach to Zahedan when the left main gear did not extend prompting the crew to abort the approach and enter a hold at about 12:00L (07:30Z). Attempts to lower the left main gear via alternate means were without success forcing the crew to perform a partial gear up landing on Zahedan's runway 35 about one hour after aborting the first approach, the aircraft veered left off the runway causing a huge plume of dust rising above the aircraft. The aircraft came to a stop about 1500 meters down the runway left off the runway. 9 occupants received minor injuries, 2 of them were taken to hospital for observation, 7 treated at the airport. The aircraft received substantial damage.
The airport reported the aircraft entered a hold for about one hour after the left main gear did not indicate down and locked. The crew attempted to the extend and lock the gear according to checklists, but all attempts failed. The aircraft burned off fuel while emergency services prepared for the arrival of the aircraft. There were no injuries during the landing, however, during the emergency evacuation 9 injuries occurred as result of people rushing out of the emergency exits. The accident is under investigation.
Video:
http://www.tabnak.ir/fa/news/399484/%D9 ... 8%A7%D9%86
Postovi: 49067
Re: Vazduhoplovi
zuzazu
Postovi: 4655
Re: Vazduhoplovi
Post od zuzazu »
"Ako izreknete dovoljno veliku laz i nastavite da je ponavljate, ljudi ce poverovati u nju"......
Covek koji je izrekao ovo, mora da je bio uzor ljudima iz adekvatnih sluzbi koje sada upravljaju Er Srbijom.
Kada se "Lideru u regionu" skine carevo ruho, i pogleda sta stoji iza neverovatnog zatrpavanja bibordima, saopstenjima i friziranim vestima, mogu se videti razne slike koje odslikavaju pravo stanje.
Na ulasku u jednu od poslovnih zgrada, reci koje necete videti kada ulazite u zgrade Etihada.
Samo desetak metara posle ulaza - otpale ploce sa plafona, paucina koju niko nije uklonio zadnjih dvadeset godina, hodnici bez svetla, stari natpisi, i vesele mladjane stevke koje razdragano razmenjuju informacije kako ce od naredne godine leteti na A330 :kuku:
zuzazu
Postovi: 4655
Re: Vazduhoplovi
Post od zuzazu »
A evo malo i drugog lidera u regionu - Beogradskog aerodroma.
Kao sto sam pisao pre godinu dana, kada padne jaca kisa, putnici upadaju u kante koje skupljaju vodu.
Taze fotke. Plafon prokisnjava tacno na centralnom delu aerodromske zgrade, iza pasoske a ispred fri sopa, tacno na putu prema gejtovima.
Propustaju i prozori.
Nisam hteo da pravim inspekciju po zgradi, ali i ovo je dovoljno
Postovi: 13468
Re: Vazduhoplovi
Kulturica
