Opel Astra OPC
kvcali
Postovi: 3007
Garaža: Omega B2 2.0
Lokacija: Kraljevo
Re: Opel Astra OPC
Post od kvcali »
Jedino reno i opel tu i imaju nesto vredno, ova druga dva konkurenta su suvise "obicni"
evo jos jedan lep spot
http://www.youtube.com/watch?v=nN3XWByFNwU
Puzo81
Postovi: 3396
Re: Opel Astra OPC
Post od Puzo81 »
Chek bre,ako samo do 250 :think:
Onda Chiletova bertonka Z20LET moze na crtu s njom :D
dunx81
Postovi: 5731
Garaža: Civic 1.8
Lokacija: Zrenjanin
Re: Opel Astra OPC
Post od dunx81 »
Da li ima neke razlike u motorima koji pokrecu g opc i bertone turbo?
kvcali
Postovi: 3007
Lokacija: Kraljevo
Re: Opel Astra OPC
Post od kvcali »
10ks je jaci opc
dunx81
Postovi: 5731
Garaža: Civic 1.8
Lokacija: Zrenjanin
Re: Opel Astra OPC
Post od dunx81 »
A ovako konstrukcijski?
kvcali
Postovi: 3007
Lokacija: Kraljevo
Re: Opel Astra OPC
Post od kvcali »
Isti su , tacnije 8ks je jaci
evo ti i specifikacije G opc II, postojao je i G opc I, motor X20XER od 160ks atmosferac
Engine :R 4
Engine Code :Z20LET
Fuel ; Petrol
Fuel System :MPI - Bosch Motronic ME 1.5.5
Engine Alignment :Transverse
Drive :FWD
Displacement :1998 cm3
Bore x Stroke : 86.0 x 86.0 mm
Type :16 Valves
Aspiration :Turbo + Intercooler
Compression Ratio : 8.8
Output : 200 cv (147 kW) @ 5600 rpm
Torque : 250 Nm (184 lb.ft) @ 1950 rpm
Gearbox : 5 speed Manual
Wheelbase : 261.0 cm
Length : 411.0 cm
Width : 171.0 cm
Height : 142.0 cm
Cx : -
Front Brakes : Vented Discs (308 mm)
Rear Brakes : Discs (264 mm)
Front Tyres : 215/40 R17
Rear Tyres : 215/40 R17
Kerb Weight : 1250 kg
Weight/Output Ratio : 6.25 kg/cv
Front Suspension : Independent. McPherson. coil springs. anti-roll bar
Rear Suspension : -
Top Speed : 240 km/h (149 Mph)
0 to 100 km/h : 7.5 s
0 to 400m (1/4 mile) : - s
0 to 1000m : - s
Fuel Consumption* : 6.8L / -L / 12.5L / 8.9L (26 mpg)
Range : 584 km
Fuel Tank : 52 L
Trunk : 370-1180 L
CO2 emissions : 214 g/Km
dunx81
Postovi: 5731
Garaža: Civic 1.8
Lokacija: Zrenjanin
Re: Opel Astra OPC
Post od dunx81 »
Pitam...vidim da postoji razlika u ceni opc-a u odnosu na bertone a automobili su po svemu sudeci dosta slicni.
Osim karoserije i (pretpostavljam) medjuosovinskog rastojanja ne znam da li ima neke specijalne razlike u vesanju,opremi ili necem trecem.
Ili je cena takva zbog egzotike.
superboss
Postovi: 3770
Lokacija: Speck in the Sea
Re: Opel Astra OPC
Post od superboss »
Pa ako tako gledas da.(isto kao GTi i obican Golf)
Bertonka je kupe verzija astre.
OPC je sportska verzija, mozda im motorizacija nije dijametralno razlicita(top model astre bertone sigurno ima motor jako slican OPC-ovom),medjutim sve ostalo jeste: spojleri, enterijer, felne vesanje itd...
Postovi: 11468
Re: Opel Astra OPC
X20XER..to je bio motor. Retka zverka.
dunx81
Postovi: 5731
Garaža: Civic 1.8
Lokacija: Zrenjanin
Re: Opel Astra OPC
Post od dunx81 »
Ne znam koliko je dobar primer poredjenje obican golf/gti,tu je stvar malo istumbana. :)
Nema obicnog i gti-ja s istim motorom a znaju da izgledaju isto (mk4)
A Astre ne izgledaju isto a imaju isti motor :)
Re: Opel Astra OPC
Gde je sve išao taj motor?
Jel išao u SAAB?
Postovi: 15324
Re: Opel Astra OPC
superboss napisao:Bertonka je kupe verzija astre.
A sta je onda GTC? :nemampojma:
Postovi: 28266
Re: Opel Astra OPC
Ne postoji G Astra GTC,tek H...
Nije vise Bertone grupa dizajnirala...
Bertone grupa je dizajnirala mnogo modela razlicitih marki i samo njhov dizajn moze da nosi njihovo ime,logicno.
Postovi: 15324
Re: Opel Astra OPC
A ja mislio da se prica o Astri J. Jbg, posledice teskog dana... :uf:
kvcali
Postovi: 3007
Lokacija: Kraljevo
Re: Opel Astra OPC
Post od kvcali »
razlikuje se motor za tih 8ks od kupea (bertone) razlikuje se prednji i zadnji branik, sedista, felne, repni spojler koji bertone nema, retrovizori, maska, farovi, neke sitnice u unutrasnjosti i naravno znacka, zato je malo skuplja u odnosu na bertone, ali to nije toliko bas zbog ovih stvari pre ce da bude da ih ima jako malo jer je to bila limitirana serija, mada i bertonki turbo imas po oglasima u nemackoj za 8-9 hiljada u nekom top stanju i ispod 100 000 km, ove kod nas na placevima su presle boga oca.
Mislim da je opc proizvedena u 3,000 primeraka ako se ne varam
