Koridor 10 & 11 - Izgradnja
Postovi: 14350
Re: Koridor 10 & 11 - Izgradnja
I autoput je ispravno, kao i automehanicar, autoprevoznik i slicno.
Skipper
Postovi: 3384
Garaža: Toyota Avensis MK3
Post od Skipper »
Darko napisao:Ovo share-uju na fejsu.
ftj napisao:I autoput je ispravno, kao i automehanicar, autoprevoznik i slicno.
http://www.srpskijezickiatelje.com/nedoumice:auto-put
Postovi: 14350
Ako pise tu onda mora da je tacno. Medjutim bacih pogled i pise i ovo sto je solidna nebuloza http://www.srpskijezickiatelje.com/nedoumice:bejsik
Postovi: 25143
Darko napisao: 21 Avg 2019, 14:14
dragvorl napisao: 21 Avg 2019, 10:44 Taj Y krak se pravi ne znam, 30 godina valjda, a obecavaju ko zna koji put vec. Prosao sam tu neki dan, dosta je uradjeno, ali je daleko od gotovog.
Meni je interesantno da 9km Y kraka kosta 8.5 miliona eura, dok 7.9km nbg-surcin kosta 70 miliona.
Ne kazem da je ok, ali ova obilaznica nije auto put 2+1 traka u oba smera, nego kao magistrala ako se dobro secam, samo je ogranicenje 100.
Postovi: 21137
ftj napisao: 21 Avg 2019, 14:18 I autoput je ispravno, kao i automehanicar, autoprevoznik i slicno.
U zakonu, pravilniku itd. svuda piše autoput, nego se našli neki pametnjakovići po netu sad.
A za njega se kaze highway sirom Evrope.
Ikac
Postovi: 1759
Post od Ikac »
All freeways are highways, but not every highway is a freeway. A freeway is a "controlled-access" highway — also known as an express highway — that's designed exclusively for high-speed vehicular traffic. Traffic flow on a freeway is unhindered because there are no traffic signals, intersections, or at-grade crossings with other roads, railways, or pedestrian paths.
The main difference between freeways and multilane highways is that in the case of freeways, these roads are separated from the rest of the traffic and can only be accessed by ramps. These ramps (slip roads) allow for speed changes between the freeway and arterial thoroughfares and collector roads. Opposing directions of traffic on a freeway are physically separated by a central reservation (median), such as a strip of grass or boulders, or by a traffic barrier. Traffic across a freeway is carried by overpasses and underpasses.
Around the world, freeways are known by various terms like Autobahn (Germany), autopista (Spain), autostrada (Italy) and snelweg (The Netherlands).
mitar1982
Postovi: 353
Lokacija: NO
Post od mitar1982 »
Fascinantan je broj kukavaca na fejsbuku, koji samo mrače i žale se na nešto.
Autoput se lepo vidi na google mapama kad se uključi satelite view. Baš me zanima kako će da reše deo na Ledinama, i eventualno spajanje sa NBG.
Neki americki izvor,?
U Evropi se autoputevi podrazumevaju pod highways. te je stoga natpisa na tabli sasvim korektan.
Postovi: 14350
Ovo na tvojoj slici je beogradska obilaznica, autoput ide levo od toga i prelazi reku na drugom mestu.
Spojice se sa jurija gagarina i vojvodjanskom (Y)
sa beobilda
mitar1982
Postovi: 353
Lokacija: NO
Post od mitar1982 »
Znam, vidi se na slici ukrštanje novog neucrtanog puta sa obilaznicom, ali ne i nastavak do NBG, zato sam postavio sliku. Proveriću šta ima na Beobuild.
Postovi: 9777
Kabal
Postovi: 3198
Garaža: Volvo XC60 D5 AWD
Post od Kabal »
Bice malo siri zbog biciklistickih staza pa je zato cena sasvim opravdana.
http://rs.n1info.com/Biznis/a509686/Put ... staza.html
Postovi: 21137
http://rs.n1info.com/Vesti/a510095/Saob ... toput.html
Saobraćajni kolaps na putu Beograd-Obrenovac zbog uključenja na novi autoput
Postovi: 15921
To je bilo očekivano. Kolaps sa ibarske mora negde otići. Plus, ima dosta znatiželjnih, a i besplatno je.
Kada startuje naplata, i prođe želja one radoznale, biće malo bolje, ali je usko grlo takvo kakvo je.
T-T
