Misterije svemira
Postovi: 49211
Re: Misterije svemira
Postovi: 49211
Postovi: 49211
Scientists May Have Finally Found the Universe’s Missing Matter
https://futurism.com/scientists-found-u ... lEepbHq_MA
Calculations for how much matter exists in the universe never matched actual measurements.
When scientists calculate how much matter ought to exist in the universe, their estimates always vastly exceeded the amount of matter that they’ve actually accounted for.
The consensus, in fact, is that we’re missing about a third of the matter that should be out there.
But thanks to a new technique for scanning the cosmos, scientists think they may have finally spotted all that missing starstuff.
Peekaboo
For clarity, this research has nothing to do with dark matter, the invisible substance that makes up about 85 percent of the matter in the universe. Rather, the team of astronomers from Harvard and Hungary’s Eötvös University found the missing luminous matter, which makes up all of the stars, planets, and other celestial objects in the universe.
According to newly-publicized research, a draft of which was first published to the preprint server ArXiv in December, the scientists used NASA’s orbital Chandra X-Ray Observatory to scan for clouds of space gas surrounding a distant black hole. In those clouds, they found previously-unaccounted-for masses of oxygen. Extrapolating to the amount of similar gas clusters that are out there, the astronomers think that they can account for the entire difference between calculations and observations of the universe.
“We were thrilled that we were able to track down some of this missing matter” said Randall Smith, an astronomer from the Harvard & Smithsonian Center for Astrophysics (CfA) who worked on the study, in a new press release. “In the future we can apply this same method to other quasar data to confirm that this long-standing mystery has at last been cracked.”
Secret Stash
More study is needed to confirm that these new findings can actually justify the lofty extrapolation that the scientists make in their paper. But if this work holds up, it means that scientists have finally sorted out one of the most confusing mysteries of the universe.
“If we find this missing mass, we can solve one of the biggest conundrums in astrophysics,” said CfA astrophysicist Orsolya Kovacs in the same press release. “Where did the universe stash so much of its matter that makes up stuff like stars and planets and us?”
milospinkfloyd
Postovi: 2015
Lokacija: subotica
Post od milospinkfloyd »
uvek me je zanimalno da li ce ikada moci da se objasni sami pocetak. Znaci kako je nastalo prvo ista. Ako to prvo ista ima objasnjenje kako je nastalo onda kako je nastalo to od cega je prvo ista nastalo.. :ludaca:
snork
Postovi: 4967
Post od snork »
Mislim da je to van naših spoznajnih mogućnosti. Pitanje je čak da li su ljudi, Zemlja, pa i čitav nama vidljiv svemir sa svojim fizičkim zakonima, samo eksperiment u nečijoj "epruveti" ili simulacija u nečijem kompjuteru.
Konrad Zuse (konstruisao je programabilne digitalne računare u Nemačkoj još 1930-ih, samo što su bili elektro-mehanički, a ne elektronski kao nešto kasniji anglo-američki projekti) je u svojim kasnijim godinama pisao o kosmičkim temama. Njegova teorija je da prostor i vreme nisu kontinualni, već postoje u diskretnim (digitalnim) koracima i da se svaka tačka u vremenskom trenutku t+1 izračunava na nekoj vrsti "kosmičkog računara," na osnovu stanja te i ostalih tačaka u trenutku t. Pravila izračunavanja su ono što nazivamo fizičkim zakonima.
Ima i drugih ljudi koji zastupaju teoriju da je nama vidljivi svemir samo jedna instanca neke simulacije ili virtuelne mašine (od ko zna koliko svemira koji postoje), a da je "tamna materija" jedan od artefakta te činjenice. Kao na primer kad na računaru sa 16 GB memorije pokrenete 4 virtuelne mašine sa po 8 GB, pri čemu svaka koristi ne više od 4, pa sve funkcioniše dobro. Ali ipak vidi da na raspolaganju ima 8. :) Postoje i teorije da je "tamna materija" rezultat bagova u simulaciji. :)
milospinkfloyd
Postovi: 2015
Lokacija: subotica
Da, to su jedne od teroja kojih ima milion ali svakako se slazem da se dimenzija pre prostora i vremena ne moze objasniti. I postojanje bilo cega u bezdimenzijonalnom univerzumu. Ali cinjenca je takodje da za sve postoji objasnjenje samo ga mi nikada necemo saznati :(
Postovi: 49211
Zasto meteori cesto padaju u Sibir?
https://www.nezavisne.com/nauka-tehnolo ... ada/531932
Postovi: 8251
Koliko ovo genijalno izgleda, nemam reči :)
na 10-11 min, kad oba slete u isto vreme
H4wkeye
Postovi: 8763
Lokacija: PO
Post od H4wkeye »
:klanjamse: :klanjamse: Kada uzmete u obzir da su ove rakete OGROMNE i visoke 70 metara sve ovo postaje jos ludje i neverovatnije. Stvarno svaka cast. Ovo drasticno smanjuje troskove lansiranja u svemir, sto sa sobom polvacli jos dosta drugih pozitivnih stvari.
Imaju li neke brojke oko troskova?
H4wkeye
Postovi: 8763
Lokacija: PO
Post od H4wkeye »
When the space shuttle was in operation, it could launch a payload of 27,500 kilograms for $1.5 billion, or $54,500 per kilogram. For a SpaceX Falcon 9, the rocket used to access the ISS, the cost is just $2,720 per kilogram.
https://theconversation.com/how-spacex- ... ace-112586
U principu, Falcon Heavy raketa kosta 90 miliona dolara. Kada ne bi mogla da sleti natrag, te pare bi odlazile u vetar sve. Ovako, mozes da je iskoristis opet, trosak ti je samo gorivo i boosteri koji se odvajaju. Artikal govori o Falcon 9 koja je manji rodjak Falcon Heavy.
snork
Postovi: 4967
Post od snork »
Rezervni primerak svemirske stanice Mir je završio u Japanu:
http://englishrussia.com/2019/04/30/a-r ... -in-japan/
U naslovu stoji "potpuno funkcionalna replika", ali se iz komentara vidi da je reč o originalnoj-rezervnoj stanici koju su napravili Sovjeti.
Postovi: 49211
Watch Live from JPL as the Mars 2020 Rover Is Being Built
snork
Postovi: 4967
Post od snork »
Na današnji dan, pre 50 godina:
Za 4 dana će biti na Mesecu...
