Sve manja upotreba manuelnog menjača u sportskim vozilima
Texonja
Postovi: 4510
Garaža: X3
Lokacija: Poker table
Re: Sve manja upotreba manuelnog menjača u sportskim vozilim
Post od Texonja »
:o
sent from my HTC Sensation
Nema problema ;)
Postovi: 25126
Ford’s Vibrating Shifter Teaches Simpletons How to Drive a Manual
Manual transmissions are better. Period. End of story. Yes, yes, we know. Sequential and dual-clutch transmissions change gears faster than any mortal possibly can, which is why even Porsche — Porsche — requires paddles instead of a proper lever in its flagship model. But unless your name is Sebastian Vettel or Sebastian Loeb, driving isn’t putting down the fastest time. It’s about having the most fun. And on that score, flicking a lever always beats squeezing a paddle.
Of course, properly shifting a car is a skill, one increasingly being lost as automatics and — gasp! — CVTs become the norm. Which is why we’re stoked to hear an engineer at Ford has made it easier than ever for n00bs to learn how to properly row their own gears.
Zach Nelson, a junior engineer at Ford, ripped the haptic feedback motor out of an Xbox 360 controller and put it inside a custom shifter he printed on a MakerBot Thing-O-Matic. He installed an Arduino controller and connected an Android tablet with a mini-USB port and a Bluetooth receiver, then tapped the Mustang’s on-board diagnostic system using Ford’s open source OpenXC software platform.
That gave Nelson reams of real-time data to play with, including engine speed (RPM, for you non-car guys) and accelerator position. Using that information, the shift knob can be programmed to vibrate as the engine approaches redline (good for performance runs) or its most efficient shift point (for better fuel economy). It can even be programmed to tell an absolute beginner when to shift, in case the howl of a 5.0 approaching 7,000 RPM isn’t a big enough clue.
“The vibrating knob can be installed onto the stock shift lever, and I’ve tested it on several vehicles including Mustang and Focus ST,” Nelson said. “I decided to have a little fun with it and installed an LED display on top that shows the gear position.”
Ford’s release of OpenXC is one of the first in the industry and could be a boon for aftermarket companies to develop new, innovative apps that tap into the vehicle’s system for information, while not allowing modifications to the core software, keeping things safe and secure.
And if you want to build it yourself, all you need is some cash, some code, and a trip to Staples.
http://www.wired.com/autopia/2013/07/ford-shifter/
http://www.youtube.com/watch?feature=pl ... fwCEwYYhI4
nuk
Postovi: 7607
Garaža: Renault Espace 2.0dCi
Lokacija: Ns
Post od nuk »
Budalastina u najavi
Sent from my BlackBerry using Tapatalk
Postovi: 25126
Badgered about the lack of a manual by journalists during a tech session on the new Huracán at the automaker’s headquarters in Sant’Agata Bolognese last week, chief engineer Maurizio Reggiani brought up the fact that just five percent of Gallardo orders were for a manual. Mid-sentence, he was interrupted by company CEO Stephan Winkelmann who commented that the 5 percent statistic was ancient.
“Close to zero percent Gallardos were ordered in manual,” he said.
In fact, orders for a manual transmission were so few and far between admits Winkelman that every time one came in they had to go back and re-check the order form, confirming with the dealership that a mistake hadn’t been made.
Adding context Reggiani then went on to outline the complexities of offering a manual, particularly when it comes to the new high-tech control system in the new Huracán.
http://www.autoguide.com/auto-news/2014 ... ssion.html
Postovi: 25126
Re: Sve manja upotreba manuelnog menjača u sportskim vozilima
