Vladapetr napisao:Ma jok, Beli će napraviti rezultat u BG i nešto u okolini. Srbija i Vojvodina nemaju pojma o kome se radi, možda ova ujdurma sa rikom pomogne
Sedeli smo sa Belim pre neki dan kad je bio u NS, skroz spontano se potrefilo, ne bi verovao koliko je mase bilo, a prilaze mu stariji ozbiljni ljudi da se slikaju, kao Djokovica da su videli uzivo
Inace opusten, normala lik skroz, onaj trip kao da znas nekoga jako dugo...teska sprdnja
STEP 1: Get inside your vehicle a firmly place yourself in your seat. Once in, press both the accelerate and brake pedal together
STEP 2: With both pedals pressed, put your key in the ignition and turn it to position 2, which is the position that switches all auxiliary heating on but not the engine
STEP 3: Once done, the spanner light will start flashing
If it flashes 10 times it means the number is '0' and any other flashes corresponds to a number with a pause between each number
For example code P0110
The light will flash ten times then pause (2sec Or 1 not sure) flash once, (2 sec pause) flash once, (2 sec pause) then flash ten times
If you have more than one code it will stop for a break between each code
However if you don’t have any code stored it will start Flashing and keeps on flashing until you release the pedals
If you follow the above steps you are certain to find codes without ever having to plug an OBD equipment
Lista grešaka je na tom linku.
Pazi ti njega, ko švaba. Čim zasvetli nešto, odmah servis bato. I to oficijel servis fir opel
Isao sam pre skoro mesec dana u servis za plin. Nisam mogao uopste da vozim, morao sam na benzin samo. Oni minusi su ga unakazili posteno. Pare samo lete iz dzepa. Pre 2 nedelje sam tresnuo pare za regu, sad ovo pa me cekaju gume nove na prolece. Veselje u najavi, jer kako kaze slogan zivimo za automobile
Od 13 do 19 marta pojacana kontrola koriscenja sigurnosnih pojaseva i mobilnin telefona. 17 do 23 aprila pojacana kontrola brzine. I 21 april blic maraton (24h kontrola brzine svim raspolozivim sredstvima).
