Chip-tuning
Ivan
Postovi: 9930
Garaža: bmw 3 f31, bmw 5 f10,
Re: Chip-tuning
Post od Ivan »
Odakle ti glupost da je menjac preopterecen sa quattrom? Kada ide skroz drugi menjac za prednji pogon i za quattro, znaci nije isti manuelac u pitanju.
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
Znam ivane da je skroz drugi menjac za quattro
Ali taj quattro menjac je skup ko da je od zlata
A cuo sam da je osetljiv ... I da se s....e
E sad ... Zato ste vi tu da mi pomognete ... Sta raditi
Postovi: 48344
Re: Chip-tuning
Našao sam samo razlike za slabije motore.
https://translate.googleusercontent.com ... st22592565
Oznaka tvog motora je CAHA.
I've even made the effort and in the 3 ETKA 2.0 TDI with 81 kW, 103 kW and 125KW (CBDC, CBAB, CBBB) to compare. The following outcomes were achieved:
Identical are:
Connecting rods, pistons, piston rings, all bearings, oil spray nozzles
Cylinder head including valves, etc. (!), Timing belt set complete
Oil filter module, fuel filter, auxiliary water pump, radiator + dual fan, air filter, LMM
-Cr-pump, injection, injectors (!) Abgasrückfuhrung, vacuum pump
Turbo + manifold from 110PS = 140HP; (Btw all Turbos are available only with a manifold, if I have understood correctly .... so not cheap in case of damage)
-From MJ2010 identical intercoolers for all previously 110PS = 140HP with a different part no.
Differences:
-The 110 PS NEN other short block, crankshaft and oil pump, because it has not installed the balance shaft module (140 and 170 hp here completely identical)
-The clutch including flywheel is of course dependent torque designed
-170PS has ne other water pump + turbo + exhaust system
So looks as if the 81 kW motor from the brand "unbreakable". Would not surprise me if the Mercedes 190 diesel creates mileages. (Parts such as CR pump, injectors and turbo outside times left out) So really very solid engine what pistons and co. terms. Conversely, I am now but a few thoughts about the shelf life of my baby
When 1.6 TDI all parts are identical in 90 HP and 105 HP version, even the turbos.
Ko ima ETKU može da pogleda detaljnije.
Postovi: 10967
Re: Chip-tuning
Raki on samo moze bolje da ide uz quattro posle cipa . Lakse ce pokretati sva cetiri tocka nego ranije.
Postovi: 48344
Re: Chip-tuning
Nije fora u lakoći. Ako je obrtni moment prejak samleće ceo prenos.
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
E ovako momci u medjuvremenu sam pita 3 majstora koja znaju
Sve oko vw i audija i sva tri su mi ko iz topa rekli
,,Samo cipuj, nece ti nista autu biti,, :)
Re: Chip-tuning
:plusone: :navijamo:
Realno, dosta zavisi i od toga koliko i kako ćeš koristiti to povećanje snage i tako to.
Postovi: 28242
Re: Chip-tuning
U sustini, nemoj potapati gas ispod 2000 obrtaja, i neces toliko siliti menjac.
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
Ma najvise za preticanja i za ubrzanja preko 140kmh
Necu se zamisljati da sam u 402m na trkama sigurno
Za preticanja snage nikad dosta i dobro je imati puno nm
Jer ti to ne daj boze moze spasiti zivot ..
Postovi: 10967
Re: Chip-tuning
Geza napisao:Nije fora u lakoći. Ako je obrtni moment prejak samleće ceo prenos.
Pa da, zato i treba da radi negde gde postoji dyno, da se rasporedi obrtni kako treba, jer prejak obrtni u jednom trenutku moze da ga slomi, dok uz lepo rasporedjenu gradaciju ne bi bilo toga.
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
A u Srbiji koliko ja znam nemamo Dyno za 4x4 :(
Ajojj sta sada ? Gde je sada najblize i najbolje i sve to uraditi u jednoj kuci ??
Postovi: 10967
Re: Chip-tuning
ja mislim da revochip u pozegi ima i za 4x4 dyno. pozovi ih raki pa pitaj.
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
Radio sam kod njih prethodni auto
Nemaju 4x4 dyno
Jedino ako u medjuvremenu nisu dobili ??? Mada ne verujem...
Postovi: 10967
Re: Chip-tuning
a jel si radio na ovoj novoj lokaciji. posto su na fb stranici najavljivali da uvode za 4x4 kada otvore ovaj novi objekat (2013. godine). :zbunjen:
Raki_Audi
Postovi: 1291
Re: Chip-tuning
Post od Raki_Audi »
Da na novoj lokaciju sam radio i nemaju
Decembra 2013 sam radio sesticu 2.7 tamo ...
