Računari
Postovi: 23574
Re: Računari
Treba mi pomoc oko aktivacije win10 enterprise, isteklo mi je onih 90 dana koriscenja..
Probao sam sa KMSpico al nesto nece.. Aktivira ga navodno i onda nakon sledeceg ukljucivanja win ponovo nije aktiviran. Opet sam ispocetka pokusao i nece...
Neka ideja?
Postovi: 28267
Re: Računari
Ja sam 2 enterprise-a aktivirao sa KMSpico v10.0.102040 Beta Install Edition.
0. Uninstall any previous version, run first: UnInstall_Service.cmd with admin rights.
1. Run KMSpico_setup.exe
2. Install it.
3. Done.
Based off of open source code KMSEmulator of mikmik38, qad, cynecx,
jm287, HotBird64, zm0d, CODYQX4.
Recommendations Optional:
- Make exceptions in anti-virus or Defender to Directory and files in
%ProgramFiles%\KMSpico\KMSELDI.exe, Service_KMS.exe, Autopico.exe
also for W10P/8.1/2012R the files %WinDir%\SECOH-QAD.exe.
- In case of troubles check the log files inside "logs" folder.
- Use Volume Licensed products.
File : KMSpico_setup.exe
CRC32 : 74c31768
MD5 : 72c8d3f5fc03bb442ac2969f4ac2f179
SHA1 : bcb8b8ddfde2bdb1acb45c56e069e579d67bf5a0
Change Log:
- Fixed bugs Windows 10 Build 10240 Detection.
- Add oficial site to the log files.
+ L E G A L +
First of all you should know that I do NOT release these cracks
so that you "the end-user" can benefit from it in the term of
using software or any other of these releases without buying
the required licenses. heldigard however believe that everyone
should have the option to test and backup their program and be
able to run it without any problems.
Further I do NOT in any way condone the spreading of this
crack, in other words I do NOT spread the releases to any
websites, P2P networks or any other public available location
and I urge that this releases should not be spread like that
at all.
I -heldigard- has nothing to do with the distribution of these
cracks, it is all done by third parties. As such, and
according to the laws where the individuals of heldigard reside,
it is not my responsibility what others decides to do with
these releases. However, let it be said quite clearly;
"I DO NOT in any way condone the selling or redistribution
of these cracks, this was NEVER my intention."
heldigard does NOT take any responsibility of computer-loss
or any data-errors that may occur from using these cracks.
Keep in mind that you are using a third party solution to
something we did not develop in the first place.
Do note that the usage of these cracks are legal in most
countries outside the United States, IF and ONLY IF you own a
full copy of the program - then you may use these cracks
for backup purposes, and only that. It remains to be seen how
affected you are of the End User License Agreements (EULAs).
They can't supersede domestic laws, remember that.
According to the "DMCA ACT" in the Unites States, you have no
rights to circumvent a copy protection. Beware, they will
punish you harder than if you stole the shrinkwrapped software
in a mall. Though heldigard's base of operation does not reside
in the Unites States, and thus I am NOT bound to the
US legislations like:
* No Electronic Theft Act
* Digital Millenium Copyright Act
* The Patriot Act
* "other US legislations"
You should ALWAYS buy the software that you do use, or find
suitable Open Source replacements (as there are loads), I do!
By using these cracks you automatically agree
to the written agreement above, and thus the responsibility
regarding whatever you are affected by any EULAs is
with YOU and YOU only.
+ G R E E T S +
MIKMIK38, RATIBORUS, QAD, ZM0D, CYNECX, ALPHAWAVES
NOSFERATI87, JM287, HOTBIRD64, DEAGLES, CODYQX4, XINSO, NOVEMBER_RA1N
CERBERUS8855, HUI, NOVA-S, KELORGO.
forums.mydigitallife.info
nsaneforums.com
intercambiosvirtuales.org
ru-board.com
pcbeta.com
FAQ
0. Windows Update
Q: Can I install the updates after using this application?
A: Until now yes.
1. SmartScreen
Q: The smart-screen is Gray!, god save all of us, kmspico broke my OS!.
A: If you are enough fool to use SmartScreen, then EnableSmartScreen the reg file in scripts folder.
2. Permanent Activation
Q: It is this permanent?
A: Until now for Windows 6,7,8,8.1 it will automatic reactivate it often, so yes.
3. Pro WMC/Core
Q: It only activate for 30 days or 45 days?
A: It is not possible in real kms activate a ProWMC/Core, but thanks to the emulator is possible activate it for 30 days in W8 and 45 days for W8.1
4. Virus:
Q:My anti-virus alert like crazy!
A:If you downloaded the file from another location, we don't know what other people do with the file. The file here only has false positives.
5. On-line/Off-line:
Q: I need internet connection?
A: No.
6. Evaluation Edition
Q: I can't activate Windows 8.1 only Office, HELP!!!
I'm having problems with activating windows.
The log:
20:13:26:322 Installing Key: -9D6T9
20:13:26:403 Error: C004E016 InstallProductKey
20:13:26:562 Error: C004F013 RefreshLicenseStatus
20:13:26:917 Found Windows Products: 1
20:13:26:919 Name: Windows(R), Professional edition
Description: Windows(R) Operating System, RETAIL channel
GracePeriodRemaining: 0
LicenseStatus: 0
PartialProductKey: 9Y92F
GenuineStatus: 1
A: If you are using an evaluation version, then install a fresh RTM edition.
7. Firewall AV
Q: Does not Work!!!
A: Some anti-virus block the applications, give the respective exceptions.
8. Hack-activators
Q: Nothing Work!!!
A: Do a fresh install.
9. Watermark
Q: It activate, but the watermark is still there!
A: Reboot.
10. OEM/MAK
Q: I am afraid, my windows/office is genuine/legit activated. Do this application will broke my license?
A: The application is designed to check a permanent activation either windows or office and avoid it. Older versions was buggy, but the main idea of this app is be smart and take the right choice without any intervention.
11. Log files
Q: Where are the log files of this program?
A: Program Files -> KMSpico -> logs
Demo Videos:
http://www.youtube.com/watch?feature=pl ... Fdhz4OZDxc
http://www.youtube.com/watch?feature=pl ... GtMCLiBPVI
Postovi: 23574
Re: Računari
Pokusacu kasnije/sutra pa javljam ishod :thumbup:
fala :pivo:
nenad.fil
Postovi: 1378
Re: Računari
Post od nenad.fil »
Koji ce ti djavo crack? Ja sam instalirao win 8 crackovan, otisao na microsoft sajt "get windows 10" i instalirao normalno bez kreka. Aktiviran.
Postovi: 28267
Re: Računari
Nema nikakve razlike, a nece svakome da updateuje na 10ku.
Dodatno sto je uvek bolja opcija clean install.
Sent from my Sony
Postovi: 9260
Re: Računari
Nije to nego hoće Enterprise verziju, valjda samo u njoj može potpuno da se isključi slanje podataka nazad u "mothership". A ona nije besplatna.
superboss
Postovi: 3770
Lokacija: Speck in the Sea
Re: Računari
Post od superboss »
Dobio sam neki promo kod za 20% popusta na kupovinu slušalica u Gigatronu pa ako neko planira da pazari....važi i za online kupovinu
Postovi: 49222
Re: Računari
Potrebna mala pomoć. Treba do večeras da savladam nešto što bi trebalo da se zove Git transfer (možda ima nešto slično, nisam baš najbolje razumeo). Uglavnom, treba da postavim fotke što veće rezolucije, da bi to neko mogao da preuzme.
Postovi: 11243
Re: Računari
Kako mislis da postavis da neko preuzme, samo da skine od tebe?
Ako je tako bilo koji sharing sajt tipa mega.nz moze da posluzi.
Postovi: 49222
Re: Računari
Valjda tako nešto, prvi put sam danas čuo za to. Poslaću linkove do slika, izgubiću manje vremena nego da kačim sve.
Postovi: 8251
Re: Računari
možda misli na ovo
https://www.wetransfer.com/
Postovi: 49222
Re: Računari
To G! :)
Milos
Postovi: 9290
Garaža: tedeijevi geteijevi
Re: Računari
Post od Milos »
Laserski ili Inkjet stampaci ? Ne stampa se puno mozda 100-150 strana mesecno .
masaivan
Postovi: 1216
Re: Računari
Post od masaivan »
Laser uvek bolja varijanta.
Postovi: 9260
Re: Računari
Laser, da ne razmišljaš o zapušenim diznama i kertridžima.
