Izbor za kupovinu SUV
Mr.Rotor
Postovi: 6355
Garaža: ПОЛУПРЕМИЈУМ
Lokacija: Краљево
Re: Izbor za kupovinu SUV
Post od Mr.Rotor »
Raki_Audi
Postovi: 1291
Post od Raki_Audi »
Deca ???!!! :D
Ja bi na tvom mestu A6 Allroad 3.0 Bi TDI
Veci gepek od Q5, bolje lezanje, udobnije od Q5
Ista cena kao sa SQ5 ...Takodje odlicno drzi cenu ... Vise prostora nego u Q5
Mislim da su ista ubrzanja ... Ja bi Allroad
Al to sam samo ja ;)
Raki_Audi
Postovi: 1291
Post od Raki_Audi »
I daa umalo da zaboravim najveci plus A6 allroad-a u odnosu na SQ5
Vazdusno vesanje kao standard ... Jel ima u ponudi za Q5 ? Mislim da nema uopste.
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
Nema u ponudi za Q5, jbga. To jeste stvarno ludačni auto ali odbijam da vozim paprikare. :mrgreen: Samo ako je RS6.
Ipak je SQ5 malo egzotičniji i lepši.
Ivan
Postovi: 9930
Garaža: bmw 3 f31, bmw 5 f10,
Post od Ivan »
Jeste a6 allroad osetno bolji auto, ali ne koliko je sq5 lepsi :)
Послато са GT-N7100
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
Osetno je i skuplji sa opremom i motorom koji mene zanima.
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
Hi all,
Thanks to the Audi VIP service I was able to test drive an A6 allroad with the same engine as the SQ5 for two days.
I wanted to find out the difference in ride comfort between the two of them
I don't want to go into too much detail, but I can summarize as follows
A6 better than SQ5 in terms of:
- ride comfort... it is a huuuuuuuuuuuuge difference, in the allroad you hardly feel anything, the suspension is ultracomfortable
- back seat space (knee space)
SQ5 better than A6 allroad in terms of:
- the exhaust sound is much more pronounced in the SQ5; outside it is more or less the same, but inside the car it is much loader in the SQ5
- the gearbox is programmed more sporty in the SQ5; the S mode in the allroad is still pretty comfortable, while in the SQ5 it is quite brutal
- the trunk is much more practical in the SQ5; the cover in the allroad seemed even low quality
- slightly more interior width
- panoramic sunroof is much bigger in the SQ5
Basically both cars are equally fast to drive (the SQ5 a little faster), steering is the same.
The big difference is the sensation, more noise and hard suspension in the SQ5, quiet and comfortable in the allroad.
All the rest is more or less the same (dashboard, options...)
Anyhow, if you like the sensation of driving the SQ5 is best, if you prefer fast comfortable cruising, the allroad is your choice
http://www.myaudiq5.com/index.php/topic ... bo-vs-sq5/
Raki_Audi
Postovi: 1291
Post od Raki_Audi »
Uh... A6 allroad je ko za mene pravljen
Normalno je da je vise zvuka i zivlje u SQ5 jer je izolacija malo slabija i ima onu stvar Perfonmance exhaust sistem (mislim da se ona nudi kao opcija u Allroad)
Menjac je podesen sportskije jer je S
A nije spomenuo da je veci prtljaznik, samo da je prakticniji :)
Nema veze tu smo da ti ponudimo alternative drug moj jer nije malo dati toliko para, a ne uzimati u obzir i ostale automobile
Cisto da ti budes siguran da je to to sto zelis druze.
Postovi: 11461
S ekonomske tačke kupovina najskuplje verzije modela koji je na zalasku nije pametan potez, ali dobro...kako mu volja. Nov ne bih razmatrao, tu bih uvek dao prednost Macan-u koji je svežiji model...ako se krećemo u krugu šire porodice :) . Kod polovnjaka gore pomenuta mana, postaje prednost jer će moći da se kupi skoro nov auto s dobrim popustom.
Milos
Postovi: 9204
Garaža: tedeijevi geteijevi
Post od Milos »
SQ5 nema LED farove,samo Xenon.
Meni je to bas smor.
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
Macan mi je tako ženski auto da ga ne bih ni pogledao. :)
Smor je i meni što nema LED ali jbga.
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
https://www.youtube.com/watch?v=cDh0ot64Fio
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
Da li je SQ5 u prici prvenstveno jer je jak dizel SUV ili ga zelis kao "sportski auto"? Ako je prvi razlog presudan, onda mi ovo ima smisla. U suprotnom, uzeti ga kao sportski auto, to je po meni promasaj...
Mr.Rotor
Postovi: 6355
Lokacija: Краљево
Post od Mr.Rotor »
Napisao sam juče šta želim.
Da mi treba sportski auto nikako ne bih birao ovako nešto. Treba mi auto za svaki dan koji je zabavno voziti.
Evo i sepang blue sa black optikom...
https://www.youtube.com/watch?v=ocpYFvLfocY
Scuderia
Postovi: 13495
Post od Scuderia »
Klot :mrgreen: Macan je odlican predlog, ali ti se ne svidja ni on.
