Grčka
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Grčka
Post od perfiko »
Da, to sa talasima je lutrija (a i sa nudistima :kezo: ).
Inače, Mišo, primetio sam na sajtu koji si naveo da je na mapi pogrešno označena plaža Saliara. :)
BAJKER
Postovi: 6086
Re: Grčka
Post od BAJKER »
perfiko napisao:Da, to sa talasima je lutrija (a i sa nudistima :kezo: ).
Drugar je pre dve godine isao u Bugarsku na more, nije uspeo jaja da smoci od talasa a kamoli da se okupa, digli crvenu zastavicu i niko nije smeo u vodu.
Misha
Postovi: 3684
Re: Grčka
Post od Misha »
:doubleup: http://www.feelgreece.com/en/saliara
Saliara is a beach on the east coast of Thassos, about 5 km south of Makryammos. It is called the Marble Beach and this name has not come by accident - because of the white sand and white marble pebbles on the sea floor, the water has a unique white-blue color and reminds of the water on the shore of a tropical island. Even in the hottest days the sand is cool because of the small marble pieces in it.
The beach is situated in a small and secluded bay and if you do not know how to find it, you will not accidentally see it. In order to get there, you must first find the entrance to Makryammos Hotel and Bungalows, located on the beach of Makryammos. Next to the entrance you will see a dirt road, take it. The road continues for about 5 km drive slowly, because there are big holes (for cars with low suspension the holes look even bigger). There are no deviations and after a while you will see Saliara from above. You will forget about the off-road as soon as you see the water.
http://www.youtube.com/watch?v=9AO_DKftxe0
Postovi: 23572
Re: Grčka
Moj favorit na Tasosu je Aliki:
Na mermernu plazu, na moju zalost, nisam otisao jer sam se pribojavao da ne rasecem gumu, a rezervnu nemam :kuku:
BAJKER
Postovi: 6086
Re: Grčka
Post od BAJKER »
:plusone: Po meni takodje jedna od najlepsih. A zar nisi mogao pesaka do mermerne, nije daleko par stotina metara osim toga i nisam video da se moze kolima tamo.
Postovi: 23572
Re: Grčka
Meni je receno, a i procitao sam da od Makriamosa do mermerne ima par km.
Npr. 3-5km
Postovi: 13469
Re: Grčka
Moze peske, a moze i kolima
somi-car
Postovi: 2243
Lokacija: BG
Re: Grčka
Post od somi-car »
Septembar je los period za Tasos. Ume da bude dosta padavina, tmurno pre dana..
Inace prosle godine je odnost Limenarija - Potos bio drugacji. Vise je ljudi bilo u Limenariji i lepse je bilo za setnju. Potos je pre par godina ima tu ulogu ali su u Limenariji jos neke ulice ukljucili u setaliste...
Ima mnogo lepsih plaza od Alikija, naravno mislim na prirodne uvale i sl. ali do njih ne mozes sa decom da stignes...
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Grčka
Post od perfiko »
BAJKER napisao::plusone: Po meni takodje jedna od najlepsih. A zar nisi mogao pesaka do mermerne, nije daleko par stotina metara osim toga i nisam video da se moze kolima tamo.
McGruja napisao:Moze peske, a moze i kolima
Pa sve može, ali...
Na karti je označen tačan položaj mermerne plaže, pa ko voli nek izvoli....mislim to peške :)
somi-car
Postovi: 2243
Lokacija: BG
Re: Grčka
Post od somi-car »
Evo zasto je zovu mermerna :)
Polke
Postovi: 160
Pridružio se: 14 Jan 2012, 23:09
Garaža: Accord CL7 & Focus C519
Re: Grčka
Post od Polke »
Oho, hvala na informacijama! Vidim da dosta volite Grcku. Ja sam bio samo jednom i to pre 15 godina na Halkidikiju i nije m se nesto svidelo.
Ako Tasus u septembu nije preporuka, sta bi bila preporuka u tom periodu?
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Grčka
Post od perfiko »
Lično sam dve godone letovao na Tasosu zadnja nedelja avgusta i prva septembra i nikakvih problema sa vremenom nisam imao, od ukupno 30 dana, 29 sunčanih, 1 šaren.
Generalno ako hoćeš da budeš siguran, idi što južnije (mada i to nije garancija), recimo Krit, i definitivno biraj ostrvo. Vazdušna strujanja oko ostrva su mnogo povoljnija, pa ako i bude kiše, to je jedan dan, retko kada veže dva tri dana u komadu (naravno ne mislim na novembar i decembar).
somi-car
Postovi: 2243
Lokacija: BG
Re: Grčka
Post od somi-car »
Vreme..promenljiva kategorija...
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Grčka
Post od perfiko »
Jel' bio neko u mestu Siviri na Kasandri?
MAD MAX
Postovi: 786
Re: Grčka
Post od MAD MAX »
Siviri je mirno mesto, sa malo naših ljudi, bez gužve kao u Pefkoh-Han-Polihrono, a i plaža je kulturnija nego u ovim mestima. Ja sam par puta prošao kroz mesto na putu za Posidi. Ako se odlučiš za Siviri, obzirom na jeftiniji smeštaj, Rt u Posidiju je ubedljivo naj naj mesto za kupanje odmor, ribolov na celi Kasandri a i jedno od prvih 10 na celom Hakidikiju, a udaljeno je oko 10km.
