BMW serija 3 (F30)
Postovi: 14163
Re: BMW 3-Series Touring
Pa bitno je samo da izabereš marku posle samo biraš koju ćeš veličinu.
dag81 napisao:Kako god, meni bi A6 bas bio potaman. :mrgreen:
Nista ti ne znas :kezo:
Inace novi A6 mi je najlepsi u klasi i da trazim takav tip auta teska bi bila odluka izmedju njega i 5ice.
Postovi: 32597
Inače, tema je o BMW serije 3.
Vidim da ste zaboravili, pa da vas podsetim. :palica:
Dobro je, nismo stigli do OFF TOPIC LEVEL: Drugari....
Postovi: 48691
Postovi: 48691
Heineken
Postovi: 6451
Lokacija: Šid, Srbija
Post od Heineken »
Odlicno mu stoji crvena boja.. :klanjamse:
Postovi: 48691
Re: BMW 3-Series Touring & Cabrio
Heineken
Postovi: 6451
Post od Heineken »
Zar ovo nije E93?
da, da, ovo je model iz 2011... Bar mi se cini tako...
Postovi: 48691
:kuku:
Postovi: 24887
Re: BMW 328i (F30)
http://www.youtube.com/watch?v=cgMo7bhd ... r_embedded
Now for the list of what it can do:
Live Performance Data - Instant "as it happens" data display of multiple parameters with virtually no lag or delay. Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more!
Diagnostic Data Interpretation & Reset - Read and clear OBD2 diagnostic trouble codes (DTC) to reducing trips to the dealership.
Built In Performance Timer - Automatic start and stop 0-60mph (0-100kph) timer for evaluating your car's performance or your driving skill
Plug and Play install - Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector.
Peak Recall & Run Record - Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background.
Universal Aux Inputs - Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values.
On the Fly Configuration Menu - Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more!
http://www.bimmerfest.com/news/633664/f ... 3cars.com/
Postovi: 24887
Re: BMW 328i (F30)
Merac momenta i snage, postoji i za F10 i slicne novije modele.
http://www.youtube.com/watch?v=LAyu8VWg ... r_embedded
Re: BMW 328i (F30)
Ima ovo i kod mene...
Postovi: 48691
Re: BMW 3-Series Touring & Cabrio & GT
