BMW M3 2014
Scuderia
Postovi: 13495
Re: BMW M3 2014
Post od Scuderia »
:djavo:
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Re: BMW M3 2014
Post od Risto »
ovaj sivi je ziva perverzija, svaki M3 od kad pratim auto industriju mi se svidjao pa ne sumnjam ni u ovog...
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Re: BMW M3 2014
Post od Laki021 »
Scuderia napisao:Slika
:o
Neko se igrao sa PSom, ali je odlicno ispalo.
Ovo je M4. Mislim da je to zvanicno prikazano kao koncept u Detroitu.
Edit: evo vam ovde slika sa predstavljanja koliko hocete:
http://tipdad.com/bmw-m4-concept-2013-i ... s-detroit/
Evo i na srpskom
http://www.b92.net/automobili/vesti.php ... _id=677629
Poslednja izmena od Laki021 u 23 Jan 2013, 21:46, izmenjeno 1 put ukupno.
Scuderia
Postovi: 13495
Re: BMW M3 2014
Post od Scuderia »
To je obicna 4orka, nije M. Evo original.
Laki021
Postovi: 13095
Lokacija: Zurich
Re: BMW M3 2014
Post od Laki021 »
Pa da, to je zapeavo koncept, te kontam da ce M4 izgledati ovako a obicnu cetvorku ce malo unormaliti :)
Postovi: 48917
Re: BMW M3 2014
Scuderia
Postovi: 13495
Re: BMW M3 2014
Post od Scuderia »
Heineken
Postovi: 6454
Lokacija: Šid, Srbija
Re: BMW M3 2014
Post od Heineken »
:djavo: ala je namrgodjen...
Re: BMW M3 2014
http://www.youtube.com/watch?v=BE0_fhs8QQE
Ahead of its debut (in concept form) sometime later this year, the production F80 M3 prototype forges ahead with testing this week at the Nurburgring. We've got it on video giving us probably the best listen so far at the F80 M3's multi-turbo inline 6.
According to the VIN info, the M3 will be powered by a 310kW (415 hp) 3.0L inline 6 engine (s55). Consistent with the information we've been posting, this would have the next M3 and M4 featuring similar horsepower figures to the current M3 (414 hp) from the 3.0L inline 6 multi-turbo s55 engine. But, we've also been previously told by a trusty source familiar with F80/F82 development that the cars will boast approximately 100 lb-ft more torque (in range of 395 lb-ft).
The rest of the info we know:
- Lighter than current M3 (targeting E46 M3 weight)
- More powerful than current M3
(approximately same HP, but around 100 lb-ft more torque (in range of 395 lb-ft))
- Faster than current M3
- More efficient than current M3
- Powered by an inline 6 cylinder multi turbo engine (source, source)
- Offered with DCT and manual transmission
- Offered with optional M Carbon Ceramic Brakes (photos)
- Electric Power Steering (completely reworked for precision for M3/M4)
- Tires (from prototype) - Michelin Pilot Super Sport: 255/35/19 (front), 275/35/19 (rear)
- Front styling to feature elements from the M6 and 1M coupe, with Air Curtain technology (our render)
- Hood to feature power/vent bump
- F82 M4 coupe to feature double-bubble sculpted carbon fiber roof (like M6 Coupe)
- M3 Introduced late 2013 - early 2014 (concept debuts earlier)
- M3 European Delivery begins June 2014, at earliest
- M4 Introduced no earlier than late 2014
Postovi: 48917
Re: BMW M3 2014
Scuderia
Postovi: 13495
Re: BMW M3 2014
Post od Scuderia »
Kontam da si za prvu fotku hteo da postavis ovu :P
Postovi: 48917
Re: BMW M3 2014
:kesa:
Scuderia
Postovi: 13495
Re: BMW M3 & M4 2014
Post od Scuderia »
M3
Re: BMW M3 2014
ENGINE
Inline 6 cylinder engine with two mono-scroll turbochargers
Direct Injection
VALVETRONIC
Double-VANOS
closed-decked crankcase
twin-wire arc-spray coating (instead of liners) in cylinder bores reduce engine weight
430 HP (approximately)
"far beyond" 369+ LB-FT (500 Nm)
See Dyno Chart
Higher than 7500 RPM redline
TURBOS
Two mono-scroll turbochargers
Impulse charging for optimized responsiveness
Flow-enhanced manifolds
Electric wastegate actuator
COOLING
Double-flow oil recirculation pumps
Turbocharger suction system
Main radiator plus additional radiators for the high- and low-temperature circuits, turbocharger and transmission,
Large indirect intercooler
Low-weight magnesium oil sump
Temperature-stabilizing electric water pump
WEIGHT
Under 3,306 lb (1500kg) weight
this figure is without driver and with 90% fuel
BMW clarifies that "the new model is now around 80 kilograms lighter than a comparably equipped predecessor model" [80kg = 176 lbs]
compare to E46 M3 at ~3,400 lb curb weight
compare to E92 M3 at ~3,600 lb curb weight
compare to C63 AMG at ~3,900 lb curb weight
compare to RS5 at ~4,000 lb curb weight
~ 7.68 lb/hp power to weight
compare to E92 M3 at 8.7
compare to C63 AMG at 8.7
compare to RS5 at 9.0
compare to E46 M3 at 10.25
Fuel consumption and emissions reduction of 25%
CARBON FIBER CONSTRUCTION
CFRP drive shaft
40% weight savings over previous M3
increased stiffness
reduced rotating mass for better acceleration and throttle response
CFRP roof for both M3 and M4
saves 11 pounds (5kg) on M3
saves more than 13.2 pounds (6kg) on M4
CFRP roof bow
Carbon fiber trunk for M4 (11 pounds (5kg) weight savings)
CFRP front strut brace standard (weighs just 3.3 pounds (1.5 kg))
TRANSMISSION
Standard 6 speed manual transmission
automatic throttle blips on downshift
more compact and quieter than predecessor E90/E92 M3 6 speed
26.4 pounds (12kg) lighter
carbon fiber friction linings in synchroniser rings
dry sump lubrication
Optional 7 speed M DCT (double clutch transmission) with launch control
Active M Differential (with constantly variable locking a la M5/M6)
Forged crankshaft
STEERING
Electric power steering specially tuned for M3/M4
Servotronic function electronically adjusts the level of steering assistance
Three modes: Comfort, Sport, Sport+
SUSPENSION / CHASSIS
Optional Adaptive M suspension (with Comfort, Sport, Sport+ modes)
Double-joint spring strut front axle (saves 11 pounds)
New five-link rear axle made from forged aluminum (saves 6.6 pounds)
Aluminum suspension
Aluminium stiffening plate
Rear axle subframe fixed directly to body (bolted joints between the axle subframe and the body sills, without use of elastic rubber elements).
WHEELS / BRAKES
Lightweight forged wheels standard
Staggered tire sizes
M compound brakes standard (in blue)
M carbon ceramic brakes optional (in gold)
EXHAUST
Exhaust features electrically controlled flaps just before rear silencer to minimize exhaust back-pressure as well as giving precise feedback on engine load.
AERO
50:50 weight distribution
Air Curtain
M gills with integrated Air Breather behind front wheels
MISC
M3 and M4 to be introduced together (at Detroit NAIAS 2014 in January).
M3 and M4 developed with help of BMW race car drivers Bruno Spengler and Timo Glock's participation in extensive testing and set- up runs on the Nürburgring-Nordschleife circuit, focusing on assessment of the cars’ suspension, tyres and all elements of the powertrain.
http://www.youtube.com/watch?v=z1FpSGjN15A
Postovi: 14244
Re: BMW M3 2014
xepoj, da li i dalje misliš da će c63 biti bolji na nirburgringu? :)
