Ratna tehnika
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Image: U.S. Navy E-6B Mercury at the Mojave Airport. Wikimedia Commons/Creative Commons/Alan Radecki
The Deadliest Aircraft in the U.S. Military's Arsenal You Have Never Heard Of
In a military that operates Raptor stealth fighters, A-10 tank busters, B-52 bombers and Harrier jump jets, the U.S. Navy’s placid-looking E-6 Mercury, based on the 707 airliner, seems particularly inoffensive. But don’t be deceived by appearances. Though the Mercury doesn’t carry any weapons of its own, it may be in a sense the deadliest aircraft operated by the Pentagon, as its job is to command the launch of land-based and sea-based nuclear ballistic missiles.
Of course, the U.S. military has a ground-based strategic Global Operations Center in Nebraska, and land-based transmitters for communicating with the nuclear triad. However, the E-6’s sinister purpose is to maintain the communication link between the national command authority (starting with the president and secretary of defense) and U.S. nuclear forces, even if ground-based command centers are destroyed by an enemy first strike. In other words, you can chop off the head of the U.S. nuclear forces, but the body will keep on coming at you, thanks to these doomsday planes.
The E-6’s basic mission is known as Take Charge and Move Out (TACAMO). Prior to the development of the E-6, the TACAMO mission was undertaken by land-based transmitter and later EC-130G and Q Hercules aircraft, which had Very Low Frequency radios for communication with navy submarines. Interestingly, France also operated its own TACAMO aircraft until 2001, four modified Transall C-160H Astarté transports, which maintained VLF communications with French ballistic-missile submarines.
The first of sixteen E-6s entered service between 1989 and 1992. These were the last built in a very long line of military variants of the venerable Boeing 707 airliner, in particular the 707-320B Advanced, also used in the E-3 Sentry. Bristling with thirty-one communication antennas, the E-6As were originally tasked solely with communicating with submerged Navy submarines. Retrofitted with more fuel-efficient CFM-56 turbojets and benefiting from expanded fuel tanks, the E-6A could remain in the air up to fifteen hours, or seventy-two with inflight refueling.
To use its Very Low Frequency radios, an E-6 has to fly in a continuous orbit at a high altitude, with its fuselage- and tail-mounted VLF radios trailing one- and five-mile-long wire antennas at a near-vertical attitude! The VLF signals can be received by Ohio-class nuclear ballistic-missile submarines hiding deep underwater, thousands of miles away. However, the VLF transmitters’ limited bandwidth means they can only send raw data at around thirty-five alphanumeric characters per second—making them a lot slower than even the old 14k internet modems of the 1990s. Still, it’s enough to transmit Emergency Action Messages, instructing the ballistic-missile subs to execute one of a diverse menu of preplanned nuclear attacks, ranging from limited to full-scale nuclear strikes. The E-6’s systems are also hardened to survive the electromagnetic pulse from nuclear weapons detonating below.
Between 1997 and 2006, the Pentagon upgraded the entire E-6A fleet to the dual-role E-6B, which expanded the Mercury’s capabilities by allowing it to serve as an Airborne Nuclear Command Post with its own battle staff area for the job. In this role it serves as a backup for four huge E-4 command post aircraft based on the 747 Jumbo jet. The E-6B has ultra-high-frequency radios in its Airborne Launch Control system that enable it to remotely launch land-based ballistic missiles from their underground silos, a task formerly assigned to U.S. Air Force EC-135 Looking Glass aircraft—yet another 707 variant. The E-6’s crew was expanded from fourteen to twenty-two for the command post mission, usually including an onboard admiral or general. Additional UHF radios give the E-6B access to the survivable MILSTAR satellite communications network, while the cockpit is upgraded up with new avionics and instruments from the 737NG airliner. The E-6B can be distinguished in photos by its additional wing-mounted pods.
The Mercury’s abundant communications gear allows it to perform nonnuclear Command, Control and Communications (C3) operations as well. For this reason, E-6s have at times been deployed to Europe and the Middle East to serve as flying C3 hubs. For example, VQ-4 was deployed in Qatar for three years from 2006 to 2009, where it relayed information such as IED blast reports and medical evacuation requests from U.S. troops in Iraq who were out of contact with their headquarters.
Two Navy Fleet Air Reconnaissance Squadrons currently operate the E-6: VQ-3 “Ironmen” and VQ-4 “Shadows,” both under the Navy Strategic Communications Wing 1. These have their home at Tinkers Air Force Base in Oklahoma, but also routinely forward deploy out of Travis AFB in California and Patuxent River Naval Air Station in Maryland. At least one E-6 is kept airborne at all times. E-6s on the submarine-communication mission often fly in circles over the ocean at the lowest possible speed—for as long as ten hours at a time. Those performing the nuclear command post mission typically remain on alert near Offutt Air Force Base in Nebraska. The E-6’s nuclear mission has also made its operations occasional fodder for conspiracy theorists and foreign propaganda outlets.
The E-6 platform should remain in service until 2040 thanks to a service-life extension program and continual tweaks to its systems and radios. While the Mercury has demonstrated its usefulness as an airborne communication hub for supporting troops in the field, the airborne command post will be considered a success if it never has to execute its primary mission. The heart of nuclear deterrence, after all, is convincing potential adversaries that no first strike will be adequate to prevent a devastating riposte. The E-6s are vital component in making that threat a credible one.
Sébastien Roblin holds a master’s degree in conflict resolution from Georgetown University and served as a university instructor for the Peace Corps in China. He has also worked in education, editing and refugee resettlement in France and the United States. He currently writes on security and military history for War Is Boring.
Sebastien Roblin
April 23, 2017
http://nationalinterest.org/blog/the-bu ... have-20305
delano
Postovi: 304
Pridružio se: 30 Nov 2015, 12:30
Re: Ratna tehnika
Post od delano »
kvcali napisao:Cudi me da su izabrali 5.56 kad ova puska moze da se poruci i u kalasnjikov kalibru
To je neka nova verzija sa 7.62x39 ?
Heineken
Postovi: 6433
Lokacija: Šid, Srbija
Re: Ratna tehnika
Post od Heineken »
Predstavljene PZH2000 u HR, dve su stigle..
https://www.youtube.com/watch?v=pWaLxST_C5I
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Mislim da su izabrali u 5.56 mm zato što SKAR-L je:
- laka (čak i sa montiranim dodacima),
- skoro da nema trzaj pa omogućava izuzetno precizno rafalno pucanje (naravno misli se na kratke rafale),
- može se poneti dosta municije (za razliku od većih kalibra)
- pouzdana,
https://www.youtube.com/watch?v=rwmEhf5ejyk?t=1m40s
Dok ona jača verzija ima neospornu probojnu moć ali "udara" propisno pa čini vrlo teškom rafalnu paljbu, ima manji magacin, očito je veća i teža, i vojnik mora poneti manje municije jer je teška:
https://www.youtube.com/watch?v=jOvJUdJlkNk?t=14s
delano
Postovi: 304
Re: Ratna tehnika
Post od delano »
Ovaj drugi je svakako 7.62x51 nato.
Ja ne znam da postoji verzija 7.62x39 sem aftermarket modifikacija.
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Vidim da na Wikipediji piše da Ameri u Avganistanu masovno koriste težu varijantu SCAR-H (7.62x51) zbog kombinacije preciznosti i zaustavne moći u pucanju na većim distancama (više se puca precizno, jedinačnom paljbom preko optike, nego što postoji potreba za kratkim rafalima).
Routasydan
Postovi: 660
Pridružio se: 09 Mar 2013, 11:28
Garaža: Audi A4 B7
Lokacija: Vojvodina
Re: Ratna tehnika
Post od Routasydan »
Da li bi neko od vas upućenih mogao da mi objasni zašto su se naši odlučili za kalibar 6,5 Grendel?
Pošto to meni nema nikakve logike ni zdravog razuma, i sve mi liči na scenu da se neki političar umešao struci u posao, i onda našao "kompromisno" rešenje između istoka i zapada, pa umesto 7,62 ili 5,56 izabrao "mudro" sredinu i karabinski, lovački kalibar koji ne znam da li uopšte koristi neka armija na svetu. Da ne spominjem problem menjanja cevi, prilagodjavanja, zaliha municije, starih pa novih..... ne miriše mi nikako na pametan potez, nadam se da grešim.
"Čovek koji gleda porniće ne može da bude loš čovek! To je duša od čoveka! Taj gleda i uživa u tuđoj sreći" (Ivo Andric)
maxer
Postovi: 6672
Lokacija: Zaječar
Re: Ratna tehnika
Post od maxer »
Vidi viewtopic.php?p=633770#p633770 poslednja rečenica.
Routasydan
Postovi: 660
Garaža: Audi A4 B7
Lokacija: Vojvodina
Re: Ratna tehnika
Ovo objašnjenje im je jadno ... ali dobro, neka objasne Rusima i Amerima da nemaju pojma, oni suotrili da lovački karabinski metak je bolji :glavomuzid: I nabili su državi ogroman trošak i eventualni problem kod snabdevanja prvih linija municijom
Sećam se neke priče još dok sam bio u vojsci, radili su na uniformisanju kalibara, da bi se olakšalo dopremanje iste na prve linije. Tada je konstruisana snajperska puška koja je koristila metak od M84 (7,62 X 51), i sviđala mi se ta strategija, ali sad vidim uvode totalno nov kalibar koji niko živ na svetu ne koristi. Valjda znaju šta rade ....
delano
Postovi: 304
Re: Ratna tehnika
Post od delano »
Nije tek tako odluceno da se testira grendal. Bar su na toj pusci radile pametne glave, a sto se tice logistike bas zato je i modularna, ako nema grendala uopste ne mora da se koristi, za par minuta stavis drugu cev i pucas 7.62
Sve se i dalje testira i nece ni uci u upotrebu ako ne bude valjalo.
Dusan
Postovi: 4285
Lokacija: Wien
Re: Ratna tehnika
Post od Dusan »
delano napisao:A ustvari ih imaju 10 :mrgreen:
10 super nosacaca i 9 assault ships, za koje bih svakako rekao da su takodje nosaci aviona, sa obzirom da sa njih takodje polecu avioni i helihopteri. :)
kvcali
Postovi: 3007
Garaža: Omega B2 2.0
Lokacija: Kraljevo
Re: Ratna tehnika
Post od kvcali »
Nosaci aviona su danas prevazidjena stvar, oni su samo predmet uvodjenja "demokratije", . u ozbiljnom sukobu sa pravim armijama bili bi na dnu okeana u roku od odmah
Re: Ratna tehnika
Sto bi bili prevazidjeni, ako uzmemo u obzir Americke potrebe?
Dusan
Postovi: 4285
Lokacija: Wien
Re: Ratna tehnika
Post od Dusan »
kvcali napisao:Nosaci aviona su danas prevazidjena stvar, oni su samo predmet uvodjenja "demokratije", . u ozbiljnom sukobu sa pravim armijama bili bi na dnu okeana u roku od odmah
Evo dobrog tekst o tome. Jbg nije na Ruskom, ali valjda ces se snaci. :kezo:
Heineken
Postovi: 6433
Re: Ratna tehnika
Post od Heineken »
delano napisao:Nije tek tako odluceno da se testira grendal. Bar su na toj pusci radile pametne glave, a sto se tice logistike bas zato je i modularna, ako nema grendala uopste ne mora da se koristi, za par minuta stavis drugu cev i pucas 7.62
:plusone:
Nista jos nije odabrano..testira se uveliko i verovatno da od toga u VS nema nista ..
btw
Scar je nabavljen i prosli su TOC..
