Ratna tehnika
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
https://www.youtube.com/watch?v=K5dxCTScVhI
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
Povodom "Nuk" krize sa Severnom Korejom, podsetnik kako je to izgledalo kada je SSSR grunuo svoju prvu Atmosku bombu.
https://www.youtube.com/watch?v=sXwSbkdVQro
Iinteresantna korelacija sa mnogim događajima koji su viđeni u kasnijim dešavanjima tj. Ameri se odmah bune što i neko drugi ima ono što su dotle samo oni imali i odmah je to nasilnik koji se sprema za rat protiv ostatka sveta i sl. budalaštine.
Naravno, ne branim ja ovde S.Koreju, taman posla, jer je tamo pravi Diktator na vlasti i taj "ludak" je spreman na "sve" ako samo i pomisli da mu neko "radi o glavi". Dotičnog treba likvidirati što pre, dok ne napravi neko sranje.
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
Kako pompezno sročene vesti
"America tests 'the most dangerous nuclear bomb ever produced, B61-12: F-15 drops $1trillion super-nuke that has an adjustable yield and is more accurate than ever
The bomb is described as the most dangerous nuclear device ever produced because its yeild can be adjusted between the equivalent of 50,000 tons and 300 tons of TNT. It is also more accurate than ever."
"Russia Fears New U.S. Nuclear Arms Make Bombing More Likely
Russia’s Ministry of Foreign Affairs fears updated, high-precision U.S. models of nuclear bombs will lower inhibitions to use nuclear weapons in combat ..."
'B61-12 gravity bombs, without a nuclear warhead, were dropped from F-15E fighter jets at Tonopah Test Range in Nevada on August 8. The tests were intended to check the bomb's 'non-nuclear functions and the aircraft's capability to deliver the weapon,' according to an NNSA statement.
The B61-12 will replace the B61 gravity bomb, one of the main pillars of the US Air Force’s nuclear arsenal and one part of the so-called air-land-sea triad, which also includes Ohio-class submarines and B-52 strategic bombers. The first production of the bomb is scheduled for March 2020."
Phil Hoover, an engineer at Sandia National Laboratories, shows off a flight test body for a B61-12 nuclear weapon
https://rs-lat.sputniknews.com/svet/201 ... be-nevada/
Čeka li nas nova Hirošima: SAD izvele dve nuklearne probe
Nacionalna uprava za nuklearnu bezbednost (NNSA) Ministarstva energetike SAD zajedno sa vazdušnim snagama zemlje izvela je početkom meseca dva testa modifikacije nuklearne bombe B61 u državi Nevadi, objavljeno je na zvaničnoj internet stranici NNSA.
Testiranje bombe B61-12 izvršeno je 8. avgusta na poligonu u gradu Tonopi. Bomba, koja nije bila opremljena nuklearnim bojnim glavama, bačena je iz lovca F-15E. Tokom testiranja su ocenjene nenuklearne funkcije bombe, kao i sposobnost lovca da isporučuje oružje.
U saopštenju se navodi da su testovi sprovedeni u okviru programa produženja roka upotrebe B61-12. Prvi takav test izveden je u martu.
Uprava navodi da će prva proizvodna jedinica modifikacije B61 biće završena do marta 2020. godine.
Ranije je saopšteno da je testiranje nuklearne bombe B61 bez bojevog punjenja izvedeno 15. marta sa bombardera F-16 na poligonu Nelis u američkoj državi Nevadi. U saopštenju je navedeno da će B61-12 biti pogodan za avione B-2A, B-21, F-15E, F-16C/D, F-16 MLU, F-35 i PA-200.
Bomba B61 predstavlja osnovno nuklearno naoružanje strateških nuklearnih snaga SAD.
Re: Ratna tehnika
Dodali krilca za upravljanje?
Ipak, situacija nije naivna - Rusi se boje da će preciznija mala avionska bomba dovesti Amerikance u iskušenje da počnu da je koriste u svojim "misijama" širom sveta. Nuclear desire: Does the new US B61-12 bomb make nukes more tempting to use? https://www.rt.com/news/401363-b61-nuclear-bomb-danger/
Postoji još jedna stvar koja ovu bombu čini opasnom - 180 ih se nalazi u zemljama NATO i avioni/piloti tih zemalja su sposobni da je koriste (link iz prethodnog teksta: https://fas.org/blogs/security/2014/03/ ... ear-costs/ ). Ima ih 20 u Belgiji, 20 u Holandiji, 20 u Nemačkoj, 70 u Italiji (50 Aviano + 20 u drugoj bazi) i 50 u Indžirliku u Turskoj.
Re: Ratna tehnika
Kazan za rakiju?
Heineken
- Postovi: 6462
- Lokacija: Šid, Srbija
Re: Ratna tehnika
Ja ne vidim sliku..
Ja ne vidim sliku..
Re: Ratna tehnika
Po drugi put, kazan.
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
Biće ovde rata, kaže tata.
Re: Ratna tehnika
Ma nece, on je ozbiljni ludak sa ozbiljnom bombom, a zapadne koalicije ne idu protiv takvih... Nije on ni blizu lud koliko izgleda...
Re: Ratna tehnika
Zašto bi ratom pokvario raj koji je nesledio?
Prodaće se za zilion tona mesa i žita, a svom narodu će da priča kako su Ameri podvili rep i eto njemu mirne vladavine još 50g.
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
Hajde da pogledamo hronologiju događaja:
- 1989. satelitski snimci -
Američki satelitski snimci otkrili su postojanje nuklearnog centra u Jongbjonu, severno od Pjongjanga. Vašington je optužio Severnu Koreju da razvija nuklearno oružje, što je komunistički režim opovrgnuo.
- 1994. umro Kim Il Sung -
21. oktobra, tri meseca posle smrti severnokorejskog čelnika Kim Il Sunga kog je zamenio sin Kim Džong Il Pjongjang je s Vašingtonom potpisao bilateralni sporazum. Severna Koreja se obavezala da će ukinuti svoj vojni nuklearni program u zamenu za gradnju civilnih reaktora.
- 2002.-2003. raskid odnosa -
U oktobru 2002. Vašington je optužio Pjongjang da ima tajni program obogaćivanja urana, kršeći time sporazum iz 1994. U decembru, Severna Koreja proterala je inspektore Međunarodne agencije za atomsku energiju (IAEA).
U januaru 2003. povukla se iz Sporazuma o neširenju nuklearnog oružja, a u junu priznala da želi da razvije nuklearno oružje. Dve godine kasnije objavila je da ga poseduje.
- 2006. prvi test -
Severna Koreja sprovela je 9. oktobra prvi nuklearni test. Savet bezbednosti UN-a izglasao je uvođenje sankcija, koje su proširene u nekoliko navrata. U junu je Severna Koreja izvela eksperimentalna lansiranja sedam projektila, uključujući projektil dalekog dometa Taepodong-2.
- 2007. nafta u zamenu za razoružanje -
Pjongjang je 13. februara pristao da ukine svoj nuklearni program i primi inspektore IAEA-e u zamenu za milion tona goriva i skidanje sa američkog spiska terorističkih država. U maju, IAEA je objavila da je nuklearni kompleks u Jongbjonu zatvoren.
- 2009. novi raskid odnosa, drugi test -
Severna Koreja lansirala je 5. aprila raketu dalekog dometa koja je pala u Tihi okean. Za Vašington, Tokio i Seul, reč je bila o prikrivenom testiranju projektila Taepodong-2. Pjongjang je napustio pregovore s pet velesila (Južna Koreja, Kina, Rusija, SAD i Japan) pokrenute u avgustu 2003. Odlučio je da reaktivira svoj nuklearni program i prekine suradnju s IAEA-om.
Severna Koreja objavila je 25. maja da je "uspešno" izvela drugi podzemni nuklearni test.
- 2011. Kim Džomg Un -
Kim Džong Il umro je 19. novembra. Njegov mlađi sin Kim Džong Un, mlađi od 30 godina, preuzima njegovo mesto.
-2013. treći test -
Severna Koreja izvodi 12. februara treći podzemni nuklearni test, manjih razmjera.
- 2016. četvrti i peti test -
Severna Koreja izvodi 6. januara četvrti podzemni nuklearni test. Tvrdi da je testirala hidrogensku bombu, u šta je većina stručnjaka sumnjala. SB UN usvaja do tada najstrože sankcije protiv Pjongjanga.
Pjongjang je potom 9. septembra objavio da je izveo peti nuklearni test, male nuklearne bojne glave koja se može staviti na projektil. To je bio "najsnažniji" test do tada, po Seulu.
- 2017. šesti i sedmi test -
3. septembra izvedene dve nuklearne eksplozije, koje su izazvale zemljotrese od 6.3 i 4.6 stepeni Righerove skale, na 0 mnv tj. na površini zemlje. S.Koreja tvrdi da je izvela eksplozije Hidrogenske bombe, dovoljno male da može da stane u ICBM.
Očito je da su sve vreme vukli Amere za nos, sve dok nisu napravili operativno male (da stanu u ICBM) ali dovoljno jake (hidrogenski tip) nuklearne bombe (ili su bar blizu toga, što je verovatnije).
Sada Ameri više nemaju gde da popuštaju ... ovi će uskoro imati u potpunosti gotove te bombe "malih" dimenzija i ne, ne plaše se Ameri da će ih oni lansirati na njih jer su Ameri previše daleko, već se plaše da će S.Koreja prošvercovati nuklearne bojeve glave u Ameriku i postaviti ih na nekoliko lokacija u velikim Američkim metropolama.
To za sada Kim Džong Un ne spominje ali će pre ili kasnije to reći ... i to je najobjektivnija i najverovatnija opasnost od S.Korejskog nuklearnog oružja.
Ameri neće čekati da do toga dođe, već će pre toga udariti po njima.
To je moje viđenje budućih događaja.
U svemu tome najviše me brine kako će reagovati Kina na Američki vojni udar po S.Koreji.
Nukovača na Korejski način:
- 2006. prvi test -
-2013. treći test -
Re: Ratna tehnika
Ma gdje ce udarati sad kad su na vrhuncu programa. Da su htjeli ranije bi to radili.
Puno bi ljudi zrtvovali, + sto bi ovi imali pomoc i podrsku od Kineza i Rusa.
P.s. kakve veze ima sto su daleko ako ovi imaju ICBM?
Re: Ratna tehnika
Sve samo predstava...
Kinezi su bili jasni pre par dana.
http://www.blic.rs/vesti/svet/kina-odbr ... -u/wc0tgwb
- maxer
- Postovi: 6672
- Lokacija: Zaječar
Re: Ratna tehnika
Taj Kineski stav me i brine.
Ameri će ih udariti pre ili kasnije (S.Koreju) i tu je pitanje šta će uraditi Kina ... ako ona udari na Amerikance ... neće na dobro da izađe.
HKS,
Pa imaju ICBM koji nije sposoban da dobaci do L.A. a kamo li do NY ili Bele kuće. Eventualno bi mogao da dohvati nešto na Aljasci.
HKS,
