Peugeot 208
Postovi: 49009
Re: Peugeot 208
Re: Peugeot 208
Aiiii romalen ... šljašteći ram cajgera. :kuku:
Incognito
Postovi: 611
Re: Peugeot 208
Post od Incognito »
Nikad mi se nije dopadala rasveta u enterijeru kod bilo kog francuskog automobila.Sve je to uvek nekako previse "drecavo" i zamorno za oci. :-|
nuk
Postovi: 7607
Garaža: Renault Espace 2.0dCi
Lokacija: Ns
Re: Peugeot 208
Post od nuk »
Mislis na enterijere Francuskih diskoteka?
Sent from my BlackBerry using Tapatalk
Postovi: 49009
Re: Peugeot 208
After sedans , the GTi , the crossover 2008 Peugeot would now create a open version of its small 208. While 206 and 207 were transformed into roadster , the future of small discoverable Lion adopt a soft top . The project of a discoverable 208 is still under consideration at Peugeot . If the French manufacturer has popularized the little roadster with the 206 CC and 207 CC , he would this time create a convertible soft top . Indeed, compared to a coupe -cabriolet at any retractable hardtop , this architecture shows many advantages: a lower cost of returns , lower weight and also the possibility of keeping intact the model line . And today, with a triple thick top , we get almost the same acoustic comfort with a retractable hardtop . Finally, thanks to advances in technology (materials, strength calculation ... ) the difference between a roadster and a cabriolet, in terms of rigidity , is less important than before. One would think that Peugeot resume his account the same recipe as the Citroën DS3 Cabriolet , the soft top slides between two arches , well no, Peugeot wants to once again differentiate itself from its partner PSA . Fully automatic hoodTaking a base 208 three doors and showing substantially the same size, convertible future will be a four-seat passengers and the rear seat does not necessarily have the same space as the 208 sedan. Same for the loading volume of the trunk that will be reduced. Regarding equipment, small discoverable resume the sedan , including the touch screen will be available from the very first level of finish. As regards the hood , it will be automatic and could even be operated from outside the vehicle by pressing the remote opening of doors . For engine , this convertible resume the same engines as the 208 three doors, including block 200 hp version of the GTi . If all goes well , the 208 Cabriolet is expected to hit the market towards the end of 2015 , after a presentation at the Frankfurt Motor Show 2015.
http://www.caradisiac.com/Peugeot-prepa ... -93298.htm
Postovi: 49009
Re: Peugeot 208
Peugeot 208 GTI 30th
Postovi: 49009
Re: Peugeot 208
Re: Peugeot 208
Strašno.
Postovi: 49009
Re: Peugeot 208
Postovi: 49009
Re: Peugeot 208
http://www.youtube.com/watch?feature=pl ... URQFfxH14U
Postovi: 49009
Re: Peugeot 208
http://www.youtube.com/watch?feature=pl ... zTheyLIvRc
Postovi: 49009
Re: Peugeot 208
FL
EB0 : 1.0 12V VTi 68 ch (50 kW) – BVM5
EB2 : 1.2 12V VTi 82 ch (60 kW) – BVM5
EB2 : 1.2 12V VTi 82 ch (60 kW) – ETG5 S&S
EB2 DT : 1.2 12V THP 110 ch (81 kW) – BVM5 S&S
EB2 DT : 1.2 12V THP 110 ch (81 kW) – EAT6 S&S
EP6 FDT : 1.6 16V THP 165 ch (121 kW) – BVM6 S&S
EP6 FDTX : 1.6 16V e-THP 208 ch (153 kW) – BVM6 S&S
https://www.youtube.com/watch?feature=p ... xHILITHxTY
https://www.youtube.com/watch?feature=p ... i6uUNk8RJs
GT Line
GTI
Postovi: 49009
Re: Peugeot 208
Motori za FL.
ivica122
Postovi: 1526
Garaža: Honda Accord CL7
Lokacija: Pirot, Србија
Re: Peugeot 208
Post od ivica122 »
FL deluje jos zenstvenije.
Re: Peugeot 208
Gadan je ko što je i bio. 205, 206 pa i 207 se obrću u grobu kako mi je ružan potpmak.
