Zanimljivi oglasi
Re: Zanimljivi oglasi
Ovaj jedan je svetu dovoljan, ostali ne moraju da se muče za džabe :D
Postovi: 10115
Dabome, Bogotac, ima ga i na oglasima, da ne bude da offtopikujemo :kezo:
Postovi: 28267
Malo je samo boja zenskasta na tom sa oglasa :mrgreen:
Sent from my Sony
Postovi: 10115
Pa to da ne bude bas ubica, nego ubica mekog srca. :)
Postovi: 28267
Hahaha, Kazanova, jebac presretac :D
Sent from my Sony
Postovi: 10115
Da bre, smeker, jebac i karatista. :D
milosg
Postovi: 1970
Garaža: XC90 D5
Post od milosg »
Sad sam pogledao na polovnim automobilima, pretpostavljam da je to taj "GTD 2.0 TDI 184 KS". Koliko dobro izgleda! Na koju foru je ovoliko dobro sačuvan za 100k km :o
Postovi: 10115
Pa covek je vozio svakodnevno bas velike ture, a voli takva kola. Pre ovoga je imao G6 GTD, sad A3 Sedan 2 0 TDI 184 KS S line, svi crveni. :)
milosg
Postovi: 1970
Garaža: XC90 D5
Post od milosg »
Strava, oduševio sam se kad sam video fotke. :doubleup:
Postovi: 11472
Vrlo interesantna je priča oko ove verzije...auto za ljubitelje dobre vožnje
http://www.polovniautomobili.com/putnic ... si-m-paket
Designed to comply with FIA homologation regulations, only 2,600 cars will be sold worldwide. All feature a hand-built four-cylinder engine made at BMW's engine plant at Hams Hall, near Coventry. The high revving 2.0-litre unit delivers 173hp at 7,000rpm (before reaching its red line at 7,300rpm) and 200Nm of torque at 4,250rpm.
This engine powers the BMW from zero to 62mph in 8.1 seconds and, if left unchecked, onto a top speed of 140mph.
This high level of performance has been achieved using BMW's motorsport technology. Compared with the 'standard' BMW 320i, the engine has been significantly modified with larger induction and exhaust valves to increase airflow. The cylinder bore has increased by 1mm to 85mm while the stroke has been reduced by 2mm to 88mm.
The compression ratio of the engine has also been increased from 10.5:1 to 11.0:1, helping to boost power by 23hp over the 320i. Additionally, instead of running with grey-cast-iron cylinder liners, the pistons run in special aluminium-alloy liners in the cylinder block. Engineers have also decided to remove BMW's patented VALVETRONIC induction system, reverting to a conventional throttle due to the higher engine speeds demanded by a racing engine.
In a direct link with BMW's motorsport programmes, the cylinder head is cast at BMW's Landshut foundry alongside Formula One engine blocks. Additionally, to save approximately 10kgs of weight and lower the car's centre of gravity, the cylinder head cover is made of carbon fibre.
The new BMW 320si mates its high levels of performance with World Touring Car looks. The specification of the 320si is based on the 3 Series M Sport model that includes front and rear aerodynamic body styling, sports seats, sports suspension and aluminium interior trim. Additionally, the BMW 320si features Touring Car-style alloy wheels with BMW Motorsport motif. The front wheels are 8J x 18 fitted with 225/40 R18 tyres while at the rear the 8.5J x 18 wheels are fitted with 255/35 R18 tyres. Finally, mirror caps finished in satin chrome differentiate the car from a standard 3 Series.
Postovi: 10115
Uh da, Si, tako rado bih ga posedovao. Secam se kad se pojavio da sam rekao to je to.
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
baš je lep, čini se da je u sjajnom stanju (bar na slikama)...
Postovi: 8251
Pa i nije neko trkalo, 173HP na 7,000 uz blokadu na 7,3k i
0-100 za 8,1s...
Nevera da nisu imali bolje za limitiranu seriju.
veljabandit
Postovi: 704
Pridružio se: 13 Okt 2015, 22:23
Garaža: Cupra SC 280 dsg ........... CBR 1000 RR HRC
Post od veljabandit »
...odlican a jos je i plave boje :D
...duga svetla i pun gas... https://www.youtube.com/watch?v=AhasvhqxLME" onclick="window.open(this.href);return false;
Malo torqua :cool!:
