BMW 7 F01
Postovi: 24620
BMW 7 F01
Dosao je red na restyle:
7-Series update 2012
The 7-Series has received a mid-life update. Up front, the bumper has been restyled, accompanied with a revised kidney grille which has fewer vertical elements. However, these subtle changes are nowhere comparable to those made to the mechanical side. 5 out of 7 existing engines have been reworked to boost power and fuel efficiency simultaneously while one more powerful diesel engine joins the range. Moreover, all cars finally adopt ZF 8-speed automatic instead of the old 6-speeder. In addition to the now-default Eco Pro fuel-saving mode, the BMW flagship limousine is far greener than ever. Below is the summary of all revised engines:
730d: the 3-liter turbo diesel straight-six has its output increased from 245 hp / 398 lbft to 258 hp / 413 lbft. It returns a class-leading 50.4 mpg and 148 grams of CO2 per kilometer, down 17 percent from the old car;
740d: improved from 306 hp / 443 lbft to 313 hp / 465 lbft. Emission is reduced by 17 percent as well;
750d xDrive: this is a new addition to the range. It shares the same tri-turbo diesel straight-six with M550d xDrive. 381 horsepower and a spectacular 546 lbft of torque plus a compulsory 4WD system guarantees 0-60 mph in 4.7 seconds only.
740i: it actually suffers from a slight drop of power, from 326 hp to 320 hp, thanks to switching from the twin-turbo N54 to single-turbo N55 3.0 straight-six turbo. However, 332 lbft of peak torque is unchanged, and it is available slightly earlier at 1300 rpm. Valvetronic helps registering 21 percent of improvement in emission.
750i: as in 6-Series, the new version of 4.4-liter twin-turbo V8 is now equipped with Valvetronic and its output is pumped up from 408 hp / 442 lbft to 450 hp / 479 lbft. 0-60 mph now takes only 4.6 seconds, while carbon-dioxide emission is reduced by a remarkable 25 percent to 199 g/km.
ActiveHybrid 7: the performance-oriented V8 hybrid powertrain has been substituted with economy-oriented straight-six hybrid, i.e. practically the same unit powering the smaller ActiveHybrid 5. The N55 engine produces 320 hp, while an electric motor generates another 55 hp and 155 lbft to make a system output of 354 hp and 369 lbft. CO2 emission is dramatically lowered from 219 g/km to 158 g/km as a result, accompanied with a combined consumption of 41.5 mpg. Performance suffers a little though.
In the chassis, the most important revision is to improve its notorious ride quality by fitting air suspension at the rear axle as standard, and by revising rear dampers, bushings, bearings and ball joints. On the road, the updated car does ride a little smoother on rough surfaces, but still it can't match a good old Mercedes S-class for ride comfort. Neither can it match a Jaguar XJ for agility and driver engagement. This mean the big BMW still fails to leapfrog them in AutoZine Rating, even though it has the best powertrain lineup in the class.
http://www.autozine.org/Archive/BMW/new ... .html#2012
Postovi: 28232
Re: BMW 7 F01
Pa ne smeju da dozvole da im se modeli razlikuju... Cim je izasla 3-ka sa novim linijama,moraju i ostali da se obnove istim tim linijama :kezo:
7footer
Postovi: 628
Pridružio se: 19 Jan 2012, 17:53
Garaža: Lexus GS 450h, Chevrolet Trax, Yamaha Stryker
Lokacija: Svet
Re: BMW 7 F01
Post od 7footer »
Ала га "похвалише" S класа удобнији а Jaguar XJ возачки настројенији. :)
Мој избор би био 740i!
Иначе остајем при томе да је е38 последња лепа седмица.
На овој ми се никако не допада предњи део. Огроман грил, мали фарови, ауто има некако збуњен и стондиран поглед... Са стране изгледа мало чудно, задњи део делује старије него ли на претходној рестилизованој. У ентеријеру скоро па серија 5, врхунски материјали, али можда мало досадан.
Pozdrav
Postovi: 28232
Re: BMW 7 F01
Jaguar... :doubleup:
Stefan Sobot
Postovi: 617
Pridružio se: 05 Feb 2012, 12:11
Re: BMW 7 F01
Post od Stefan Sobot »
Ne gotivim uopste ove ladje,dok mi 7-ica najantipaticnija od svih,valjda zbog one Bangle baljezgarije.Ako bih bas morao uzeo bi S400h.
Sad ga zakomplikuj!
Postovi: 10984
Re: BMW 7 F01
Nema boljeg mesta za promociju necega kao sto je Serija 7 od Moskve :)
Postovi: 24620
Re: BMW 7 F01
Stefan Sobot napisao:Ne gotivim uopste ove ladje,dok mi 7-ica najantipaticnija od svih,valjda zbog one Bangle baljezgarije.Ako bih bas morao uzeo bi S400h.
F01 vec nije dizajnirao Bangle.
Stefan Sobot
Postovi: 617
Re: BMW 7 F01
Znam,al od kako sam video E66 (?) zivot mi se smucio i ne mogu da smislim ovakva kola.Nasi politicari ne pomazu uopste po tom pitanju kao ni 'posteni' ljudi sto zauzmu tri parking mesta i 'nenormalan' narod nema gde da se parkira. :/
Sad ga zakomplikuj!
Scuderia
Postovi: 13495
Re: BMW 7 F01
Post od Scuderia »
Stefan Sobot napisao:Ako bih bas morao uzeo bi S400h.
Ima jedan u NSu, neka zlatno/braon-perla boja, felne 'zbicare', krem enterijer, facelift sa onim dioda stopaljkama, izuva kako izgleda. Bas bas surovo elegantan :klanjamse:
Postovi: 24620
Re: BMW 7 F01
To mi je komsija. Ima tablice sa ZL na kraju.
Scuderia
Postovi: 13495
Re: BMW 7 F01
Post od Scuderia »
Puniji, celav lik? :D Ne secam se tablica, cesto ga sretnem kod caribica na bulevaru.
Postovi: 24620
Re: BMW 7 F01
Off topic
Nikad nisam video vozaca. Ali sad da bas ima puno metalik braon W221 sa krem enterijerom u NS, ne verujem. :)
Scuderia
Postovi: 13495
Re: BMW 7 F01
Post od Scuderia »
:doubleup:
Re: BMW 7 F01
U planu je 728i Hybrid sto bi znacilo kombinaciju 2.0 R4 motora (N20B20) i elektromotora...
http://www.bimmertoday.de/2012/09/24/bm ... 3-f01-f02/
7footer
Postovi: 628
Lokacija: Svet
Re: BMW 7 F01
Post od 7footer »
7footer napisao:Ала га "похвалише" S класа удобнији а Jaguar XJ возачки настројенији. :)
Tačno godinu dana kasnije menjam mišljenje. :)
Restyle je definitivno odlično legao. Auto treba videti iz blizine gde def. osvaja. Enterijer iako manje-više isti kao u 5series je posebna priča, i definitivno treba sesti u oba da bi se videla razlika. 7series je daleko prostraniji, imas utisak da si u avionu. :) "Drvenariju" na vratima da i ne pominjem. Drugo, enterijer je vrhunskog kvaliteta, Iako konceptualno podseća na e38, sve je na dohvat ruke, svaki taster se aktivira podjednakim pritiskom... Jednostavno okružen si vrhunskim materijalom, vozački nastrojenim. :) Ovaj je bio 750Li i on je definitivno prava mera za njega
Isti dan sam sedeo u najnovijoj S klasi, tek stigla u Minhen, iako spektakularnog dizajna enterijera, nisam primetio znatno kvalitetnije materijale. Ona mi više ide da budeš vožen, dok je BMW za vozača egoistu koji želi da bude okružen vrhunskim kvalitetom i opremom. :)
Pozdrav
