Birani postovi prevedeni sa Google translt.
That's when VW is a rough road chassis is factorial, but the Polo I know only that the cross has a raised suspension, normal is de ground clearance even 10.2 cm and now I have searched the following configurators and nothing in the normal Polo, not even found as an option, which indicates there on a rough road chassis;
- Spain
- Russia
- Czech Republic
- Slowwakei
- Estonia
- Latvia
- Poland
But if it is not there, then where have all had 10.2 cm of ground clearance available. What's the different countries from time to time was that at least the ESP series is not over and a few other things differently.
Then you would have to in a bad way accidentally blocked his suspension from the Cross, which is 12.5 cm of ground clearance, which would indeed be the devil, but nothing is impossible, but you would have noticed it. Did you maybe when specifying a Zahelndreher made, as this is the one to explain or what has been wrong in the keyboard or checked or clicked.
http://www.motor-talk.de/forum/schlecht ... 56387.htmlApparently the rough road chassis no demand in Germany has found. Because when you could actually order a 9N rough road chassis (It cost as much as the sports suspension). This was placed 15mm higher than the standard suspension, not anymore, so no other reinforcements and such.
But that does not get updated very often when 6R more now, at least in Germany! In any country, but apparently it must give the 6R with rough-road suspension, as far as I can remember when I stumbled in ETKA 6R ever on rough road shock absorbers and springs. And that was not the the Cross, because they are listed separately and others PR and part number.
It has been mentioned with the Eastern countries, this is a very unique model Polo (think 60 or 61 instead Kurbezeichnung 6R) which bassiert on our EU Polo.
For this polo, it's even an extra SSP (447 - The Polo, 2011) it is for suspension, that this suspension systems, like the Polo, 2010 (ie the EU, 6R) on the 2004-spec Polo (If the 9N3 to be) based, but the harder local conditions (road and air), adapted, and 15mm was set higher.
So after the SSP have all these polos, so not an optional, but serienmäsiges rough road chassis.
