BMW X5 (F15) 2014
BMW X5 (F15) 2014
The next generation of BMW X5 is indeed coming in 2013, and our second batch of spyshots have revealed what looks to be a bigger grille and some bigger headlights hidden under a lot of camo. It looks like these will be connected to the grille a la F30 3-Series. These will probably also get the full-LED treatment, while at the back T-shaped clusters will give more character to the SUV.
Down the side, you’ll probably see a combination of convex and concave shapes distinguished by bold character lines.
The F15’s platform will feature a more modular design that will allow it to be stretched to create a longer X5 L to take on the bigger Audi Q7. Rumor has it that the new X5 will be light enough to even use four-cylinder engines, while the ActiveHybrid will combine a 2.0-liter diesel with an advanced electric system.
stefan
Postovi: 21
Pridružio se: 23 Jan 2012, 23:53
Garaža: Opel Corsa D 1.3cdti ECOflex
Lokacija: London
Re: BMW X5 (F15) 2014
Post od stefan »
Dizajin podseca na novog Mercedesovog ML-a. :D
STOCK
Scuderia
Postovi: 13495
Post od Scuderia »
stefan napisao:Dizajin podseca na novog Mercedesovog ML-a. :D
:plusone:
Postovi: 24873
Postovi: 23565
Bljak ako bude ovakav..
stefanan
Postovi: 9520
Garaža: Fiat Stilo 1.9 mjet
Post od stefanan »
Nema sanse da bude ovakav,nesrazmeran je nekako i previse obican
Postovi: 24873
Opet spojeni farovi sa maskom. Ccc BMW :naughty:
stefanan
Postovi: 9520
Post od stefanan »
Dok ne vidim uzivo ne komentarisem, em me brine kakvi ce farovi biti em mi i ove izduvne cevi izgledaju nekako maleno...
AcaKayak
Postovi: 4865
Post od AcaKayak »
Mislim da sadasnji dizajn mogu samo da pokvare...
Cemu tolike predrasude unapred? :zbunjen:
Aktuelni je vec postao dosadan...
AcaKayak
Postovi: 4865
Post od AcaKayak »
Moj post se odnosi na (po meni) sjajan izgled prethodnog modela. Nisam nista rekao za novi, samo tesko zamisljam da nesto sa njihovom sadasnjom filozofijom farova izgleda bolje od sadasnjeg X5. Ipak, ne sumnjam da dizajneri imaju bolje ideje od mene, samo kazem da ja mislim da ce tesko ponoviti ono sto su uradili sa sadasnjim X5.
Aktuelni model je super...u to nema sumnje.
To je prvi SUV (SAV) za koji sam rekao da bih mogao da vozim (pod uslovom da gledam tu klasu)...posle se pojavio i X6 :)
Fora je sto verujem da tako dobar i uspesan proizvod fabrika sigurno nece upropastiti vec ce biti bolji...u to sam uveren.
I aktuelnu trojku su mnogi pljuvali zbog spojenih farova a prodaja je odlicna, pozitivni komentari stizu sa svih strana...naravno uvek ce biti ljudi kojima se nece svideti, pa sta sad.
Ja imam drugara koji i dan danas nemoze da prihvati to sto je BMW jos 90ih izbacio duple farove :D
