Ferrari 458/Speciale/488 GTB
Postovi: 48953
Meet the Ferrari 458 Speciale. Following the path taken by the 360 Challenge Stradale and 430 Scuderia (not to mention the lesser-spotted 348 GT Competizione), it’s a harder, faster and stronger version of Ferrari’s V8, mid-engine supercar, in this case the 458 Italia.
Its central stripe (seen here running down that trademark Ferrari rosso paint) is an unsubtle nod to those iconic forebears. Initially rumoured to be called the 458 Monte Carlo, it has instead been called the Speciale.
The 458’s 4.5-litre V8 engine has been tuned from 562bhp to 597bhp, resulting in a specific output of 133bhp/litre, Ferrari claiming this as the highest ever achieved by a naturally aspirated road car engine. It helps edge closer to its arch rival – the 616bhp McLaren 12C – a car which uses twin turbochargers on its V8.
The 458 Speciale’s 1290kg dry weight is 90kg lighter than a standard 458 Italia’s, and endows it with a 470bhp/ton dry power-to-weight ratio. This figure surely aids its sensational performance; 0-60 takes less than three seconds, with 0-62mph completed in 3sec dead, 124mph hit in 9.1sec and a 1m23.5sec lap of Ferrari’s Fiorano test track 1.5sec quicker than standard, 0.5sec quicker than the 599 GTO and just 0.5sec slower than the 730bhp F12 Berlinetta. At 1.33g, Ferrari is claiming the highest lateral acceleration of any of its road cars.
It’s not just more power and less weight, though, with new aerodynamic elements. The front grille treatment has changed, there’s a more sculptured front bonnet, with more ventilation, and the rear is more racecar-like with a bigger diffuser and two integrated tailpipes replacing the 458’s trademark central triple pipes. The aero elements are active and help make this Ferrari’s most aerodynamic road car yet.
A new Side Slip Control system (SSC) ups the acronym count, using the the F1-Trac traction control and E-Diff electronic differential to shuffle torque between the driven rear wheels to control slides more accurately. Also boosting balance and traction is a set of bespoke Michelin Pilot Sport Cup2 tyres.
Ferrari claims some of the 458 Speciale’s technology will make it onto its future road cars, with SSC and that active aero seeming dead certs.
The Ferrari 458 Speciale will make its world debut at the 2013 Frankfurt motor show, when we can expect more details, including its price, top speed and production numbers. North of £200,000 and a good chunk over 200mph seem very good bets, though…
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: Ferrari 458 Speciale
Post od perfiko »
Ništa ovo ne valja. Gde je zelena traka?
Postovi: 11463
Što bi rekao Maminjo "Kad god vi mene ...."
http://www.youtube.com/watch?v=HyF-1TjQW7s
Scuderia
Postovi: 13495
Post od Scuderia »
Ode moj nick u penziju :(
Nek ti promeni Trojke nice u "Specijalac" :kezo:
Sent using Tapatalk
Scuderia
Postovi: 13495
Post od Scuderia »
:kezo: :kezo:
Scuderia
Postovi: 13495
Post od Scuderia »
Postovi: 48953
Scuderia napisao:Ode moj nick u penziju :(
I dalje ti ostaje F1 tim :)
Postovi: 10085
Evo jedan koji sam ufotkao u MC, covek ga je tek isterao iz salona...
Tapatalk Post
Postovi: 48953
458 Spider Speciale
NidzaV8
Postovi: 591
Pridružio se: 17 Okt 2013, 09:50
Post od NidzaV8 »
http://youtu.be/3EsKkZO2_yM
Postovi: 48953
Ferrari 488 GTB, 661 KS.
Markoni napisao:
Tapatalk Post
I dalje pašu bočni žmigavci od Yuga?
Postovi: 11463
Re: Ferrari 458/Speciale/488 GTB
Najžešći atmosferac ikada ode u istoriju i najbolji na neki način...dalje se više nije moglo sa ovakvim normama... :uplakan:
Ipak, barem su po svom starom običaju sačekali šta drugi imaju da ponude, a onda podelili šamare ovaj put Hurracanu i NSX i utvrdili autoritet da se zna ko je ko.
