Formula 1 - sezona 2017
Formula 1, WRC, Moto GP i ostalo
Postovi: 48887
Dosta ranije, ali sa dobrim povodom. Za 2017. godinu se najavljuju radikalne izmene u pogledu dizajna bolida, a prvi prikaz budućeg Mercedesovog trkača je pred vama.
https://www.youtube.com/watch?feature=p ... PcZ51eWEMM
First look at F1's 'fastest ever' 2017 cars
http://www.motorsport.com/f1/news/tech- ... =1&q=Piola
Formula 1's 2017 cars are set to deliver more downforce than any other time in the sport's history, according to early data produced by the teams.
Motorsport.com's technical editor Giorgio Piola has drawn the above impression of what the new cars will look like – featuring the wider wings and tyres that have been a hallmark of the concept.
Early indications suggest that the cars will produce around 30 percent more downforce than the current 2015 challengers – which are already close to delivering at historic peaks.
It is estimated that drag levels will only increase by 10 percent too – contributing to the step forward in speed that was the key motive for the new design.
Wider machines
Although some details of the cars may yet be changed, the basic dimensions have been agreed by teams following months of discussions.
The tyres will be wider, going up to 300mm at the front (from 245mm) to 400mm at the rear (from 325mm).
The overall width of the car will increase from 1.8 metres to 2m, with the nose of the car being 20 centimetres longer.
The front wing will be 180cm and more rounded, with the rear wing widening from 80cm to 95cm – and being lowered to just 80cm from the ground.
Downforce will also be boosted by a much larger diffuser, which goes back to the kind of performance that was delivered prior to the 2014 regulations.
The flat bottom will end 33cm in front of the rear axle – rather than in line with it as happens now. It will also be deeper – 22 centimetres high rather than the 12.5cm we have now.
There will also be more scope for design innovation around the sidepods, with strict rules on the floor dimensions.
Harder to drive
The ultimate aim of the design is not only to make the cars faster, but also much more difficult to drive.
Williams performance chief Rob Smedley said recently that he was in no doubts the current cars were not challenging enough for drivers.
“They are a lot easier to drive, without a doubt. They are significantly easier to drive,” he said.
When asked if the challenge of harder cars was vital, he said: “I think it is important probably from a sport entertainment point of view.
“If the cars are too easy to drive, then perhaps we don't see the difference between the naturally talented driver and a mediocre driver.
“They are not as physically demanding, the braking points are a lot earlier, corner speeds and techniques are slower and easier respectively.
"So I think whether or not it is a good thing or a bad thing, you have to answer from that point of view. Are we seeing the difference between the drivers we should be seeing?”
Postovi: 48887
Re: Formula 1 - sezona 2017
Prvi testovi sa pneumaticima za narednu sezonu.
Postovi: 48887
speedy stikis
Postovi: 2120
Post od speedy stikis »
Videmo sta ce da bude sa motorima?
Kako ce da ide razvijanje, nadam se napretku nekome jer je ovo ocaj od F1 poslednjih 10 godinu dana
Postovi: 48887
https://www.facebook.com/C4F1/videos/306537873050496/
https://www.youtube.com/watch?feature=p ... lFUwOpC2yE
Postovi: 15313
Esteban Ocon i Sergio Perez su potvrdjeni kao vozaci Force Indie za sledecu sezonu:
http://www.formula1.com/en/latest/headl ... -2017.html
I da prenesem iz druge teme jer je vest o sezoni 2017:
Potvrdjeni su Valteri Bottas i Lance Stroll kao vozacka ekipa Williamsa za sledecu sezonu.
http://www.skysports.com/f1/news/12433/ ... ms-drivers
Postovi: 15313
Potvrdjen je kalendar za sezonu 2017.
March 26 - Australia (Melbourne)
April 9 - China (Shanghai)
April 16 - Bahrain (Bahrain)
April 30 - Russia (Sochi)
May 14 - Spain (Barcelona)
May 28 - Monaco (Monte Carlo)
June 11 - Canada (Montreal)
June 25 - Azerbaijan (Baku)
July 9 - Austria (Spielberg)
July 16 - Great Britain (Silverstone)
July 30 - Hungary (Budapest)
August 27 - Belgium (Spa-Francorchamps)
September 3 - Italy (Monza)
September 17 - Singapore (Singapore)
October 1 - Malaysia (Sepang)
October 8 - Japan (Suzuka)
October 22 - USA (Austin)
October 29 - Mexico (Mexico City)
November 12 - Brazil (Sao Paulo)
November 26 - Abu Dhabi (Abu Dhabi)
Postovi: 22077
http://www.skysports.com/f1/news/12433/ ... ampionship
Neočekivano, Rozberg ne vozi za Merc 2017.
Risto
Postovi: 6023
Lokacija: Klagenfurt, AT
Post od Risto »
Srećan put i ne misli na manastir :)
Postovi: 15313
:D
naslon za ruku
Postovi: 13
Pridružio se: 18 Dec 2016, 12:07
Garaža: Renault Laguna Grandtour 1.5 dCi
Post od naslon za ruku »
Haha, genijalno.
No, stvarno je pitanje tko će voziti za Mercedes. Wehrleina očito ne žele, Ocon otišao u Force Indiju (vjerojatno dečko ne želi prekršiti ugovor kad je u tako mladima danima karijere), Alonso i Vettel ne mrdaju, a zanimljiv je razvoj događaja oko Valtterija Bottasa. Mercedes bi ga mogao komotno uzeti, ali čini mi se da ga Williams ne pušta. Zamislite npr. ovu situaciju. Martini je naslovni sponzor momčadi, idete na neku manifestaciju, a na događaju će vam, ajmo tako reći, promotori biti Lance Stroll (18) i Pascal Wehrlein (22). A jbg. Martini ipak nije piće kao što su Vranac, Ribar ili ostala smeća od vina, to ipak treba promovirati netko ozbiljniji, koji izgleda malo starije i ima isksutva. Sad se spominje da se Massa vraća u Williams, što bi po meni bilo loše. Nema više što za ponuditi.
naslon za ruku
Postovi: 13
Malo sam čitao o povijesti sporta ovih dana, ima zanimljivih članaka.
Francois Cevert
http://www.f1puls.com/14937/le-prince/
Povijest razvoja bolida
http://www.f1puls.com/14936/zimska-stan ... -dio-80-e/
Meni se ta Formula iz starih dana činila nekako prirodnija nego ova danas. Što se vama čini? Ima li kojih starijih pratitelja sporta?
Postovi: 22077
Naravno da ima, samo to nije ova tema. :)
U ovoj temi pravimo doček nove sezone. Još 88 dana, 14 sati, 2 minuta do trke.
naslon za ruku
Postovi: 13
A u kojoj temi možemo onda o tome ako ne u ovoj?
Do predstavljanja novog Ferrarija još 58 dana, ne mogu dočekati. A onda tri dana poslije toga slijedi prvo predsezonsko testiranje.
Postovi: 48887
BEHIND CLOSED DOORS: The Williams F1 heritage collection
https://drivetribe.com/p/IRCaA7nWTz20Jx ... ps-QH7nbAg
