Koncepti
profesorPROST
Postovi: 3281
Koncepti
Post od profesorPROST »
Tema za koncept automobile
Izgleda da DS3 dobija konkurenciju :smesko:
Kia Trackster Concept
Never Say Never Again
ZAXSPEED
Postovi: 216
Pridružio se: 26 Jan 2012, 16:43
Garaža: Passat B7 , Clio IV 1.5 dci
Re: Koncepti
Post od ZAXSPEED »
Meni ovo izgleda preterano. I nije samo DS3 dobio konkurenciju :doubleup: :doubleup:
ZAXSPEED
Postovi: 216
Re: Koncepti
Post od ZAXSPEED »
HYUNDAI NUVIS
SlikaSlikaSlikaSlikaSlikaSlika
Hyundai's Nuvis Concept, making its world debut at the 2009 New York show, is yet another hybrid-crossover dream car designed to blend utility with small-car fuel-economy and sci-fi futuristic styling.
Penned at Hyundai's design center in Irvine, California, its SUV-style body gives the Nuvis the passenger and cargo room of a large sedan, while its wide stance and low roofline lend it a sporty appearance. Powered by a parallel hybrid system backed up by a 270-watt lithium-polymer battery, the Nuvis delivers an estimated 34 mpg city and 35 mpg highway according to Hyundai, meeting the Ford Escape Hybrid's city mileage and beating its highway mileage by four mpg.
Hyundai's Hybrid Blue Drive system operates on a principle similar to Toyota's Hybrid Synergy Drive, wherein the gasoline engine is mated to an electric motor that reduces the load on the engine, increasing efficiency. In this case, Hyundai's 228-hp Theta II 2.4L inline four-cylinder engine is mated to a 30 kW electric motor that can get the vehicle moving from a stop and provide extra power for accelerating and passing.
That's no ordinary Theta II engine, either. The engine has been optimized to minimize efficiency-robbing friction, as has the entire drivetrain. Hyundai also massaged the engine management software for efficiency wherever possible in order to further boost fuel economy. Meanwhile, the fourth, fifth and sixth gears of the six-speed automatic transmission have been extended for better highway fuel economy. Hyundai says its lithium-polymer battery pack, stored under the rear cargo floor, is more space-efficient and durable than the nickel-metal hydride or lithium-ion battery packs of other hybrids. The smaller battery pack helps reduce weight as well, and the Nuvis tips the scales at just 3400 lb, according to Hyundai.
When you look at the Nuvis, though, fuel efficiency probably won't be your first thought. Hyundai says the Nuvis draws many of its styling cues from the motion of running water, which makes it appear as though it's always moving. While the lines themselves are graceful, a few too many of them run into each other for our taste. Things get cleaner as you work your way from the pinched nose along the sides to the back, where it's less busy. Regardless of which angle you choose, though, it will be hard to miss a hint of Mazda's Nagare design cues in the body lines.
Read more: http://www.motortrend.com/future/concep ... z1lyeY8KIB
http://www.youtube.com/watch?v=_xnrsY5x ... r_embedded
zuzazu
Postovi: 4656
Re: Koncepti
Post od zuzazu »
Gosn. Profesor me je pretekao. Ali evo jednog Renoa, CAPTUR. Tu je, do 4,1m. Sa smelim dizajnom, kao i gore navedeni koncepti, pokazuje de ce industrija pratiti uspeh koji je zabelezio Juke.
Postovi: 13473
Re: Koncepti
Izgleda odvratno, a rezultat je saradnje Renoa sa Nisanom
ZAXSPEED
Postovi: 216
Re: Koncepti
Post od ZAXSPEED »
Bogami, staviš na krov Browninga od 13 mm i možeš u rat! :censored:
swemir
Postovi: 3886
Re: Koncepti
Post od swemir »
McGruja napisao:Izgleda odvratno, a rezultat je saradnje Renoa sa Nisanom
:plusone:
mr.Big
Postovi: 2355
Lokacija: Bgd
Re: Koncepti
Post od mr.Big »
zuzazu
Postovi: 4656
Re: Koncepti
Post od zuzazu »
Nissan ce 2013 da izbaci ovaj model. Manji od Juke, sa motorima do 1500ccm
ZAXSPEED
Postovi: 216
Re: Koncepti
Post od ZAXSPEED »
Pa di"š manje od Juka?? :kuku: :kuku: Al ova Mazda Takeri izgleda preterano!! :doubleup:
kvcali
Postovi: 3007
Garaža: Omega B2 2.0
Lokacija: Kraljevo
Re: Koncepti
Post od kvcali »
Opel Tigra Concept
Postovi: 11567
Re: Koncepti
Zagato Alfa Romeo TZ3 Stradale
Zagato Alfa Romeo TZ3 Corsa
Postovi: 49231
Re: Koncepti
2012 Range Rover Evoque Convertible Concept
Postovi: 49231
Re: Koncepti
Infiniti Emerg-E Concept. Nezvanično planirani konkurent Nissanu GT-R.
Postovi: 28267
Re: Koncepti
Ako nista drugo,bice lepsi :D
Mada ne kapiram da ista firma izbacuje konkurenta sebi :zbunjen:
