MICHELIN PILOT SPORT 4 S
Sve vezano za gume i felne
Laki021
Postovi: 13095
Garaža: BMW 540i xDrive
Lokacija: Zurich
Post od Laki021 »
Ne znam da li imamo neku djuture temu o gumama, no posto se svakako radi o mozda najboljoj civilnoj gumi danasnjice svakako zasluzuje svoju temu.
Eventualno sam razmisljao da stavim u temu o Alfi Giuliji, jer se tamo svakako vodi diskusija o gumama na najvisem nivou na ovom forumu :)
Dakle Michelin je u Parizu prikazao novu MICHELIN PILOT SPORT 4 S, s obzirom da je i stari PS bio lider ili u samom vrhu logicno je ocekivati da ovaj bude najbolja guma na trzistu, sto i prvi nezavisni testovi potvrdjuju (cak nestvarno dobro).
http://www.bmwblog.com/2016/09/29/miche ... otor-show/
Since 2011, the MICHELIN Pilot Super Sport has dominated the max performance tire category and has been the benchmark for street performance tires since the day it was released. Even recently, it won a showdown between some of its nearest competitors. But winners don’t rest on their laurels, so Michelin went back to the lab and have developed something better, and today at the Paris Motor Show, they unveiled the MICHELIN PILOT SPORT 4 S.
Designed for sports cars and high performance saloons, the MICHELIN PILOT SPORT 4 S offers unparalleled driving pleasure thanks to its exceptional steering precision and directional stability. It provides maximum performance and safety on all surfaces due to its optimized tread footprint which grips the road in all situations, even the most extreme.
The MICHELIN PILOT SPORT 4 S also displays excellent braking performance on both dry and wet surfaces, thanks to the use of ‘bi-compound technology’. The outer part of the tread uses a new hybrid compound that promotes grip on dry ground while the inner part uses a new compound with silica and functional elastomers which allows the tire to offer consistent grip on wet ground. This high performance on dry and wet surfaces, often conflicting characteristics in the world of super sports tires, here have advanced together.
The MICHELIN PILOT SPORT 4 S is the result of a unique know-how developed by engineers passionate about their work and redefines the standards of the category. Adapted for driving at the highest levels on road and on track, it has already positioned itself as the number one in its class. In tests conducted by the independent organization TÜV SÜD in Germany, the MICHELIN PILOT SPORT 4 S surpassed its five major competitors in the different workshops, and has become the first ultra-high performance tire to dominate several key testing criteria simultaneously.
Wear tests conducted by the Dekra Test Center demonstrated that the new MICHELIN PILOT SPORT 4 S has the best longevity in its class, and it was the only tire to break the 50,000 km (31,068 miles) barrier.
The MICHELIN PILOT SPORT 4 S is also among the first tires in this category to score an A rating on the European labelling scale (19 inch tire) in braking distance on wet surfaces. This label is intended to inform tire buyers of the performance of the tires they are planning to buy and also gives them information on the energy efficiency of the tire and road noise level. The MICHELIN PILOT SPORT 4 S also passes a new milestone in terms of reducing road noise, while providing good levels of driving comfort.
Postovi: 22132
Re: MICHELIN PILOT SPORT 4 S
Fina guma, ali je to sve na testu performansi klasu ispod gume sa kojom se isporučuje QV tako da bi sa njom verovatno bila sporija.
Sem toga, hvala za link. Sačekao bih još koji test i rado je stavio na svoj auto. Ovo što iznad vidim obećava.
Postovi: 10062
Ceka se Dag :cool!:
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Nema na cemu :)
Ja bih bas voleo da je odmah nabacim na auto :)
Em bolesne performanse em neverovatno dugo traje. Lepo rekoh da dobra guma moze i preko 50 000km da traje.
Tacno se poklapa i sa mojim iskustvom da se Continetal SC uzasno brzo trosi, najgori su od sve dece ovde.
Svakako slazem se treba sacekati jos par testova no ovi ovde su vec iz renomiranih izvora.
Ceka se jos Heroj da nam potvrdi da li ova guma moze lepo i po mokrom da se vozi :)
Postovi: 28267
Eto meni sledece gume :)
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Dajte da organizujemo neko grupno forumsko narucivanje da dobijemo popust :)
Postovi: 14332
Ne moze da najbolje drzi, bude najtisa i da najduze traje, jednostavno ne ide.
Postovi: 22132
Zašto ne može? Tehnologija napreduje.
Sve gume sa spiska bolje do svih guma sa spiska iz generacije od pre 10 godina, ukupan zbir performansi je napredovao i napreduje i dalje. Ostavlja realnu mogućnost da se pojavi guma čiji zbir performansi ponovo malo odskoči.
Ne kažem da nisu potplatili DEKRA Francuzi za ovaj konkretan slučaj, Nemci su najveći doktori na svetu po pitanju trgovine statistikom. Treba sačekati još testova.
Postovi: 14332
Jednostavno takva je hemija. Zamisli kad bi napravili gumu koja drzi kao zagrejani slik na suvom, kao wet guma na mokrom, da ne mora da se zagreva, da traje 50k km na stazi, da je najtisa guma sto postoji i jos da moze po snegu. Moze da prodje i hiljadu godina tako nesto nikad nece biti moguce napraviti.
Postovi: 22132
U suštini si u pravu da je zbirna karakteristike gume kompromis svih navedenih parametara koje si spomenuo, da ih ne citiram, ali zbir parametara je veći iz generacije u generaciju, jer tehnologija napreduje, hemija napreduje, "fizika" napreduje. :)
Dobar primer imamo u jednoj drugoj temi gde je spomenut Pirelli Zero Corsa sistem, odnosno komplet guma koje su kombinacija asimetrične i simetrične šare, guma koja po kiši radi odlično, a po suvom drži bolje od većine poluslikova. Pritom, traje duže. Znači -moguće je, tj. i ovaj Pilot Sport 4S je moguć, nije fikcija.
To da li traje 50 hiljada ili ne je Laki paušalno procenio, u šta lično ne verujem. Nijedna tako performantna UHP guma toliko ne traje.
Laki021
Postovi: 13095
Lokacija: Zurich
Post od Laki021 »
Nisam pausalno procenio:
Postovi: 22132
Obnevideo sam.
Strava guma ako je ovako, šta drugo reći, koju posluku porati. Sačekati da pobedi i na još nekom testu.
Postovi: 7674
Kao i CC sto je svemoguca pa se posle godinu i par meseci vidi gde je.
Ne verujem u bajke.
Postovi: 22132
Ja nisam video testove CC nego samo njihov PR.
Ovo je test. Crno na belo. DEKRA takođe nije neka dunđer agencija.
Postovi: 28267
A sta je CC?
Gledah malo o gumi, pa nadjoh jos testova gde je prva PS4, a S pretpostavljam jos bolja.
Ovaj recimo:
http://www.autoexpress.co.uk/accessorie ... t-4-review
