AC 378 GT Zagato
Postovi: 48952
AC 378 GT Zagato
AC has unveiled the production version of the 378 GT Zagato at the Geneva Motor Show.
Designed to be the ultimate long distance cruiser, the car has a steel space frame chassis, a composite body, Brembo brakes and 20-inch alloy wheels.
Power comes from a GM-sourced 6.2-liter V8 engine with 434 hp (324 kW / 440 PS) and 583 Nm (430 lb-ft) of torque. It is connected to a six-speed manual transmission which enables the 1,465 kg (3,230 lb) coupe to accelerate from 0-60 mph in less than four seconds and hit a top speed of 185 mph (298 km/h).
The 378 GT Zagato is currently available for order in the UK and Germany where it is priced from £89,990 and €109,990 - respectively. It will be built in South Africa and the first deliveries are scheduled to occur later this year.
perfiko
Postovi: 2213
Garaža: Fiat Croma
Lokacija: BG
Re: AC 378 GT Zagato
Post od perfiko »
Meni se baš dopada.
Postovi: 11463
Lep je, ali se vidi da su kopirali sami sebe sa Aston Martin Zagatom.
Postovi: 11483
Na sličnu foru je i Alfa Zagato TZ3 Stradale ;) a meni se takav dizajn sviđa :)
