Nisu @pajo, cak se moze reci da im prija pritisakpaja napisao:OO nikad nisu ugrožena na biciklu ako imaš uske gaće, bile one bici ili ne. Na sedištima stradaju guzne kosti tj tkivo oko njih i koren ponosa jer je tu glavni oslonac.Ji 4Tze napisao:kako ti ne otpadnu mošnice od ovog sedišta (položaj pre svega)?
The graphic below is a thermogram which compares sitting in a chair vs. sitting on a bike seat. When you are sitting in a chair, the pressure is distributed across the meaty part of your bum. But when you are on a traditional bicycle seat, you are leaning forward and almost all of the pressure is on the base of your penis or vulva, with none of the pressure being shared by the broader back part of your butt (red indicates maximum pressure).
Not only do traditional bike saddles crimp the artery that supplies most of the oxygen to the penis, but they also compress the nerves against the pelvic bone for a possible double whammy.
As for the newer seats with cutouts, they appear to make matters even worse, given that they focus the pressure on an even smaller area.
