Biciklizam
branja
Postovi: 3726
Lokacija: Pančevo
Re: Biciklizam
Post od branja »
Danas sam vozio po nasipu u Ivanovu uz Dunavac. Kul. Lepo ide, mada se i dalje plasim kad predjem preko kamencica malko vecih.
Hah pala je prva zrtva na bajk. Drugarica bivse, inace vozi Cube, kad je videla kenjca oma trazila broj, pa kao da vozimo zajedno (sreca pa veliki kukuruzi). Sad sam skrenuo misli sa oguljenog slova.
Nego cuje mi se dok pedalam? Nista se nije culo ranije, sad nekako cangrlja. Ranije je bilo na najvecem zupcaniku, sad se i na srednje pocelo cuti (mislim na prednje zupcanike). Sta je problem?
Poslato sa Lumia 925
zuzazu
Postovi: 4656
Re: Biciklizam
Post od zuzazu »
nikaragva napisao:Danas sam umreo na fg
I ja sam umreo. 60km po ravnom ali medju milionima dece i neopreznih setaca. Smarno....
Moj tocak ne moze da primi vecu gumu od 25mm. I ovo je nategnuto....
Ako mi ikada pukne zica na ovom fensi tockicu, prvo ce mi osteti ram, onda cu se vratim kuci pesaka i na kraju cu morati da bacim tocak :mrgreen:
Al tako to ide u savremenom drustvu :djavo:
When one spoke breaks in a low spoked wheel it will go much further out of true than a normal spoke wheel - so much so that it could be unridable.
If you think these boutique wheels are great, just check the price and availability of those fancy spokes that hold them together. They're spokes specially made for those wheels. You'll get a shock when you ask the bike shop for a couple of spares - or worse still - ask if they can fix a broken spoke wheel for Sunday's ride. Check on the availability and cost of a replacement rim too. The chances of a replacement spoke being in stock is close to zero and the chances of a replacement rim is an almost certain zero. With "normal" wheels you'll be out the door with a $0.75 spoke in your hand and with this guide, be able to fix it yourself in about five minutes.
Postovi: 14756
Re: Biciklizam
Koliko mm je široka felna?
Na ovom mom prilično usko sve deluje, spram prednjeg koji je 40c. Sada je na njemu 32mm, ali to je onako baš usko. Mislim da mogu bez problema i 40 da stavim.
Bilo bi dobro da ima čovek dva seta, jedan recimo 32mm, i jedan 44mm :)
Pa menja u zavisnosti kuda ide. Jeftinije nego imati dva bicikla.
Morao sam malo da pritegnem kočnice, toliko da mi se gumica ona nabija sada i zaglavljuje, računam da je skinem uskoro, koji će mi ...
Ove moje žbice ako ikad pukne ijedna, bataliću biciklizam. Da je malko deblje, bilo bi kao na tomosu :D
zuzazu
Postovi: 4656
Re: Biciklizam
Post od zuzazu »
Kod mene je problem sto do podsedalne cevi I lancane cevi ima par mm.
U mom slucaju sirina felne nije prepreka nego gde sve to ubudziti.
Postovi: 14756
Re: Biciklizam
Aha, kapito :)
Jbg, brusilicu u ruke i skini malo :kezo:
Postovi: 49221
Re: Biciklizam
nikaragva napisao:Danas sam umreo na fg. Nisam još dovoljno spreman.
Divoš ka partizanskom putu me pocepao.
Inače ja imam nazad sada 32mm gumu, naduvana na 5 i kusur bara.
Put je na nekim delovima užasno loš, pa sam se pokajao zbog širine gume. Svi ostali su imali mtb i upijali su bolje neravnine. Međutim po normalnom asfaltu klizi odlično, odmah mi se vrati smešak na lice.
U pojedinim trenucima sam mislio da ću ga skršiti pošto sam šibao 40-50 nizbrdo, a put kao granatiran.
Međutim dt swiss od 2mm i izgleda dobro i čvrsto, ali i radi posao profesionalno. Točak je u vinklu posle ~50km, ni nm se nije pomerio.
Mislim da je za ovakve puteve ipak 37mm, možda čak i 40mm. Ali bude ti žao kada odeš na dobar asfalt.
branja
Postovi: 3726
Lokacija: Pančevo
Re: Biciklizam
Post od branja »
Haha, realno.
Zu kao da si vozio u Bgu. Ako ti pukne tocak kupicu ti na kilo :)
Ja cu sad kod mene izmedju sela da teram. U Banatu postoji kultura bicikli, tako da vozaci paze i na uskom putu, a sve je relativno ravno.
zuzazu
Postovi: 4656
Re: Biciklizam
Post od zuzazu »
Odoh na jos jednu ravnicarsku. Nema guzve ko nedeljom.
Juce nas je bilo preko 20 mil u gradu a danas smo na redovnih 17 mil.
Lakse se dise :mrgreen:
Postovi: 11039
Re: Biciklizam
Postovi: 14756
Re: Biciklizam
Da malo nerviramo zuzazua :D
Ta uzbrdica na 30om kilometru me je bacila na kolena :)
zuzazu
Postovi: 4656
Re: Biciklizam
Post od zuzazu »
Sace Bajker da se vrati sa svojih putesestvija.
Ako je kojim slucajem instalirao ove decije radosti, i ako postuje svoje puteve, nagibe, i duzine voznji - bice bruka da se dalje "hvalite".
A njegovu bih statistiku voleo da vidim.
srdjanyo
Postovi: 3598
Re: Biciklizam
Post od srdjanyo »
Danas vožena ruta po rumunskom Banatu.
Kikinda-Comlosu Mare-SanNicolau Mare-Lovrin-Gottlob-Comlosu Mare-Kikinda.
Celih 89,15km za 6 sati.
Odličan magistralni put,obeležen kolovoz,vozači motornih vozila koji nam ne sviraju.Vreme nas je poslužilo,vedro i vetar od 2 m/s.
Rumunski Banat prilično talasast,ako ga uporedimo sa našim.
Evo par slika.Hronološki.
Postovi: 11039
Re: Biciklizam
zuzazu napisao:Sace Bajker da se vrati sa svojih putesestvija.
Ti baš nisi sam u glavi.
AcaKayak
Postovi: 4865
Re: Biciklizam
Post od AcaKayak »
Zuazu, mogli smo se trkati malo, čisto da se spustiš na zemlju :)
branja
Postovi: 3726
Lokacija: Pančevo
Re: Biciklizam
Post od branja »
Srdjane to je slicno kao kod mene. Sva sela uz Dunav su malo talasasta. Malena brdasca.
Bajker kad se vrne treba prvo da mi uradi servis, pa onda nek se hvali koliko hoce :)
